Old April 9th, 2014, 08:54 AM   #1
brownninja
Motorcycle(s): Ninja
150/60/17 rear tire do i need to change the front
Hey guys its time to replace my rear tire and i am pretty much set on getting a michelin pilot power 150/60/17 for the rear because it is cheaper than the oem replacement AND it looks way better from the research ive done. what i would like to know is if i keep the front the same since it isnt worn out would it make a difference with the pilot power being a radial tire
brownninja is offline   Reply With Quote
Old April 9th, 2014, 08:57 AM   #2
Some say to never mix bias-ply with radial. Others say it doesn't matter as long as you don't outride your weakest tire. Others say go with the best tire in the front. Which makes you most comfortable?
Old April 9th, 2014, 09:03 AM   #3
brownninja
well I do not want to change the front tire since they are not worn out plus I'd rather wait than spend a 100 on the front tire. I wanted to know if safety would be an issue and how would it affect the ride with the two different tires
Old April 9th, 2014, 09:14 AM   #4
Is there a safety issue? No, but note handling could be somewhat different than what you're used to. I fall into the 2rd group, don't outride your weakest tire. In your case, the grippiest tire will be in the rear. So ride accordingly and you can swap the front out as you see fit.
Old April 9th, 2014, 09:16 AM   #5
allanoue
allanoue's Avatar
MOTM - Sep '14
Edit:
Go with it and see how it feels. If you don't like it, get a new front.
Old April 9th, 2014, 09:23 AM   #6
rojoracing53
Fast-Guy wannabe
rojoracing53's Avatar
MOTM - Jan '13
If your still running the stock front tire for gods sake change that b***h to a race profile radial. I'm tired of repeating myself on this subject so your going to have to just trust me on this or search my old posts.
Old April 9th, 2014, 10:21 AM   #7
brownninja
hey i tried searching for ur old posts but you have too many so if u dont mind can u tell me if the pilot power 110/70 or the 120/60 is good for the front after i get the 150/60 for the rear and why is it not good to ride the stock in the front
Old April 9th, 2014, 10:27 AM   #8
lgk
i would not cheap out, by changing only one tire.
imo, the front irc feels terrible when the rear has more grip.
Old April 9th, 2014, 10:27 AM   #9
rojoracing53
Fast-Guy wannabe
MOTM - Jan '13
Fair enough, do try and help as many members here as I can, others I just tend to F**K with their heads. Go with the 110/70 because it'll fit your stock narrow wheel better, I ran a 120 on my stock front for several thousand miles and I felt fine as well. As for why the OEM front is s**t, well once you get the new radial on the front it will all become very clear. It has to do with stability in ALL conditions.
Old April 9th, 2014, 10:36 AM   #10
BoBO
BoBO's Avatar
Motorcycle(s): SC28 Fireblade
It should not be a problem if you are just commuting. However, its good to ride on oem tire size. Pus one in the back is OK, my bike came with 150/120....I will say it's OK on low speed, but the steering felt a bit heavy on the freeway. I'm happy I got rid those super wide tires. Instead I got some sport demons on oem sizing and it feels better all around. It's not like cars where the wider tire gives better grip. And mixing radial with Bias Ply is not the best thing either.
94 900RR
04 BMW Z4 2.5 M Package
01 R170 AMG Sport Package
BoBO is offline   Reply With Quote
Old April 9th, 2014, 10:46 AM   #11
brownninja
thanks
Old April 9th, 2014, 10:50 AM   #12
capt_bugaloo
motorcycle rider
capt_bugaloo's Avatar
IMHO...
Never be cheap with your tires or brakes. You can get away with being cheap with the things that make you go, but not the things that make you stop.
150 Rear Tire TheJimmyEnglish 2008 - 2012 Ninja 250R Tech Talk 27 August 4th, 2011 09:58 PM
150/60 REAR Tire Upgrade! SilentNinja 2008 - 2012 Ninja 250R Tech Talk 60 June 4th, 2011 10:26 PM
150/60/17 Rear tire onepeon 2008 - 2012 Ninja 250R Tech Talk 91 February 6th, 2011 12:04 PM
WTB: 150 rear tire...;) Plasma Items Wanted 0 October 3rd, 2009 04:09 PM
