Old March 13th, 2016, 12:03 PM   #1
Mike K
Mike K's Avatar
Motorcycle(s): 2014 Ninja 300 track bike, 2007 Suzuki GSXR 750 track bike, 2002 Yamaha R6, 1995 CBR600RR f3 track bike
GSXR Shock Conversion Ninja 300
Is there a step by step GSXR shock conversion thread for the 300 on here? I can't find it.
Thanks
EDIT: I made one with pics in my 2014 Track Build thread
https://www.ninjette.org/forums/show...8&postcount=19
https://www.ninjette.org/forums/show...0&postcount=20
Track, track, track
Last futzed with by Mike K; March 19th, 2016 at 09:11 PM.
Mike K is offline   Reply With Quote
Old March 13th, 2016, 12:52 PM   #2
Unless I have missed a thread, this is about as close as we have to a diy. Can't imagine it being too much different on a 300.
https://www.ninjette.org/forums/showthread.php?t=59486
Old March 13th, 2016, 01:27 PM   #3
Mike K
Mike K's Avatar
I've read through that one. If it's the same or similar then it looks relatively easy. If I order it today I might just have time to install it before Summit on the 26th.
Track, track, track
Old March 13th, 2016, 04:53 PM   #4
subxero
dirty boy
subxero's Avatar
MOTM - Apr '14
https://www.ninjette.org/forums/show...1&postcount=27
some useful in in those links and the actual thread that that post is made in here
https://www.ninjette.org/forums/show...831#post817831
Some info in this thread as well
https://www.ninjette.org/forums/show...=168447&page=2
Oh yeah this one
https://www.ninjette.org/forums/showthread.php?t=170747
Old March 13th, 2016, 05:45 PM   #5
Ghostt
Ghostt's Avatar
http://faq.ninja250.org/wiki/GSXR600_shock
violente et ignorantia
ZX-2R BLOG
Old March 13th, 2016, 07:05 PM   #6
Mike K
Mike K's Avatar
Someone at Team ProMotion gave me this link to a 300 shock thread: http://www.kawasa***************/for...s/36809?page=1
Track, track, track
Old March 14th, 2016, 06:03 AM   #7
subxero
dirty boy
subxero's Avatar
MOTM - Apr '14
Link doesn't work for me?
Either way, all the info you could possibly want/need is in the links listed above. It is really quite simple.
buy shock, drill out holes to 12mm, grind U bracket at bottom wider, buy 12mm nuts and bolts and "spacers", buy/make new dog bones. Put it together.
I have a gsxr shock laying around i would give away but it needs oil, bled and nitrogen charge plus all the holes are drilled out to 1/2" which isn't ideal so IMO it isn't worth the cost of shipping vs buying a functional used one off ebay for $25 $30
Old March 14th, 2016, 01:13 PM   #8
Mike K
Mike K's Avatar
I just tried to post the link again but it does not work. I posted it because it was actually a step-by-step instructional. It is dead simple though as stated above.
I'll do a step-by-step with pics in my race bike build thread.
Track, track, track
Old March 19th, 2016, 05:25 PM   #9
toEleven
Slower than you.
toEleven's Avatar
Motorcycle(s): CBR600RR, CB750, EX300 (半蔵)
MOTM - May '16
Originally Posted by subxero View Post
I'm surprised that thread, titled "DIY - GSX-R Rear Shock", isn't the first thing people find when looking for a GSXR conversion thread. The only thing I encountered that might be different on the 300 is the plastic undertray. All the important bits matched the 250 instructions.
DISCLAIMERv1.0: There may be more info on the topic than this forum post. Conduct your own research.
If another thread is linked or quoted, go read it yourself.
toEleven is offline   Reply With Quote
Old March 19th, 2016, 08:08 PM   #10
Mike K
Mike K's Avatar
I installed it yesterday. Took about two hours. Hardest part of the install was cutting away the plastic undertail above the shock and that only took about three minutes with a Dremel with a router-type bit. I'll post pics in my track build.
Track, track, track
Old March 19th, 2016, 09:09 PM   #11
Mike K
Mike K's Avatar
Track, track, track
Old March 20th, 2016, 09:57 AM   #12
subxero
dirty boy
subxero's Avatar
MOTM - Apr '14
did you use the stock dog bones?
Old March 20th, 2016, 09:58 AM   #13
Mike K
Mike K's Avatar
Yes I did.
Track, track, track
Old March 21st, 2016, 04:05 AM   #14
Yamahawk
Chaplain
Yamahawk's Avatar
Motorcycle(s): 75 RD350 race bike, 82 XZ550RJ Vision, 81 XV920RH, 89 VTR250 Interceptor race bike, 06 Concours, 86 EX250E1
Hey Mike,
Nice conversion thread(s)! I installed one on a pregen 1986, and the dogbones look like they will clear the spring! Not sure if the dogbones are different than the later pregen/newgen/300, but they have a spacer/protrusion on each end on the inner part where they bolt up, and initial inspection tells me they may clear the spring no problem.
Let me know how it handles/rides with the stock GSXR spring! I am looking at getting an Eibach spring 8.3kg and swapping it in.
P.S>- my stock 86 rear shock had an adjustable preload collar too... unlike the later pregens!
God chose what the world thinks foolish to shame the wise,what the world thinks as weak to shame the strong,what is despised in the world,what is nothing,to set aside what is regarded as something
Yamahawk is offline   Reply With Quote
Old March 22nd, 2016, 08:11 PM   #15
Mike K
Mike K's Avatar
I'm running it on Summit Main this weekend with Team ProMotion. I'll post how it feels
Track, track, track
Old March 29th, 2016, 10:51 AM   #16
SpotTheDogg
Motorcycle(s): 2009 BMW F800GS, 2010 BMW G450X, 1989 Hawk GT, 1974 CB360, 1990 VTR250
Originally Posted by Yamahawk View Post
Hey Mike,
How light are you Charlie? I'm pretty sure the stock spring is a 9.3Kg/mm (520lb/in), we put one in the ZZR on the weekend and for my 160lb friend it was too soft. Not dramatically soft but with 16mm of installed preload it had 15mm free sag and 37mm rider sag if I recall correctly. I think a 600lb/in is in order if not a 625
SpotTheDogg is offline   Reply With Quote
Old March 29th, 2016, 01:23 PM   #17
Sirref
Private Joker
Sirref's Avatar
MOTM - Mar '14
@Mike K how did it feel for you? it felt too stiff for me causing the rear to want to come around and push the front a bit rather than allowing the throttle roll on to flow through the chassis. This causing the rear to start to step out at times (which it did when helped by the slick track)
Old March 29th, 2016, 01:30 PM   #18
RacinNinja
Vintage Screwball
RacinNinja's Avatar
MOTM - Mar '16
Have you tried lessening the compression damping? This will get you a bit more squat on throttle application.
Goin' fast on slow bikes!
Old March 29th, 2016, 01:38 PM   #19
Sirref
Private Joker
Sirref's Avatar
MOTM - Mar '14
I did, as well as reducing rebound
it worked better but I only had 10-12 laps worth of feel to go off of going into the race. I had been hoping for a longer shake down to dial the bike in. I think I'll be reducing each a bit more soon but I'll be switching tires first so I'll leave it the same for now (only change one thing when at a time mentality)
Old March 29th, 2016, 01:45 PM   #20
RacinNinja
Vintage Screwball
RacinNinja's Avatar
MOTM - Mar '16
FWIW, I would start at the minimum settings and work your way up. These shocks are meant to dampen a much heavier machine.
Old March 29th, 2016, 02:05 PM   #21
Sirref
Private Joker
Sirref's Avatar
MOTM - Mar '14
will do, sounds like a good idea
Old March 29th, 2016, 08:12 PM   #22
Mike K
Mike K's Avatar
I thought that it felt much, much better than stock but the track felt pretty slick. After we go back to NCBike I'll have a better idea .
FYI-- I turned both adjusters out 3 full turns.
Track, track, track
Old March 29th, 2016, 08:36 PM   #23
Sirref
Private Joker
Sirref's Avatar
MOTM - Mar '14
I started at 3 turns, sitting at 2 now, probably going to switch my emulators to 2 rather than 3 turns as well
Old March 30th, 2016, 04:59 AM   #24
Yamahawk
Chaplain
Yamahawk's Avatar
Hi Scott,
I may just try the spring first, to see what it does. The RaceTech website spring calculator say 9.3Kg. spring for it, which is what it has. I am 180 right now, and I will set sag when I get the bike done and see what it's like. It definitely should be better than the oem shock! With the proper compression/rebound adjustments, it would be ok I think. Did he have to space out the dogbones any to clear the spring? Mine look like they will clear the spring already! Has your friend with the ZZR had it on the track yet? Let me know how he likes it, and whether he changes the spring. I am going to leave the length alone too, and if I need to, I will pull the tubes up in the triple trees to lower the front a little. I already have about 10mm more above the top triple tree to fit my aftermarket clip on handlebars mounted, if I need more I will.
Old March 30th, 2016, 08:29 PM   #25
Mike K
Mike K's Avatar
I didn't know that your forks were done.
Track, track, track
Old March 31st, 2016, 07:53 AM   #26
Sirref
Private Joker
Sirref's Avatar
MOTM - Mar '14
yup I have springs and emulators in there, just don't have preload adjuster caps installed
also fun fact...they weren't re-installed evenly...some of my front end issues may well have been because one fork was sitting higher than the other by a third of an inch. My dumbass thought it was all good when the front wheel spun freely and everything looked relatively even so I didn't double check it closely enough.
I do highly recommend springs, emulators, and preload adjusters in the forks though. They make a world of difference to the feel of the bike when you get it right and you'd probably get it right quicker than me hahaha
GSXR Shock Conversion Trailerboy531 Motorcycle-related 18 April 2nd, 2016 02:20 PM
06 GSXR600 rear shock conversion Yamahawk Ninjettes At Speed 3 December 6th, 2015 03:27 PM
I'm new, already installed gsxr shock. Zombarian 1986 - 2007 Ninja 250R Tech Talk 14 June 17th, 2014 01:06 PM
2006 gsxr shock sidekick10121 1986 - 2007 Ninja 250R Tech Talk 2 March 26th, 2014 04:13 PM
gsxr shock alex.s Ninjettes At Speed 1 October 17th, 2013 12:03 PM
