January 6th, 2012, 09:40 PM | #1 |
Join Date: Apr 2011 Motorcycle(s): 2011 Green 250R Posts: 346
Area P Installation Question
Mounting the header to the engine the 4 bolts don't match up perfect,if I squeezed the two pipes together a little by hand I can get all 4 bolts lined up and it slides on about half way,enough to get the nuts started but not enough that the bolts are completely through the nuts.It's still about 1/32"-1/16" from hitting the crush washers.Is this normal or should it seat down all the way by hand. I don't want to torque them the rest of the way and muck something up.
January 6th, 2012, 09:54 PM | #2 |
No, should look like this;
They are not all the way inserted or something is blocking.
January 6th, 2012, 09:59 PM | #3 |
KThanksBye
Join Date: Mar 2011 Motorcycle(s): 2006 zx636r Posts: A lot.
It does take a little bit of moving around but both will sit flush if it was made correctly
----> My Youtube! <---- Unregistered, watch my youtube page! |
January 7th, 2012, 05:22 AM | #4 |
Mine would NOT sit flush, it seemed as if the casting was just a bit off. ( I almost returned my full system due to it ).
I too had a hard time just getting the bolts in the 4 holes, and when it did it was barely on them all. I put the nuts on and proceeded to tighten all nuts equally until it was completely set. |
January 7th, 2012, 06:51 PM | #5 | |
I hate driving...
Join Date: Jul 2010 Motorcycle(s): 13 Triumph Street Triple R, 09 Ninja 250r (Sold 4/20/12) Posts: A lot.
IMG_20111210_211458.jpg I don't want to torque it up more and snap a stud of, but the way it looks seems like it might have a leak there at some point. I also still get a bit of popping on decel after removing the kleen system and exhaust leaks could be the cause. Do any of you remember what you may have torqued it to? or did you just tighten till it was mostly flush
09 ninja 2fiddy SE Driving slow things fast |
January 7th, 2012, 07:25 PM | #6 | |
January 7th, 2012, 07:45 PM | #7 | |
I hate driving...
January 7th, 2012, 08:21 PM | #8 |
I was going to give them a call Monday morning.
January 8th, 2012, 05:25 AM | #9 |
I checked mine several times now for leaks by headers, have not found one yet. I did continue to tighten mine past what I first thought was on. I counted the threads on the bolts and tried to get em all even amounts sticking out the nut.
Those crush washers they provide where the biggest PITA to keep on the header pipe anyway, I think I got mine crushed down good though. Remember to re-seat all the bolts after first ride! |
January 8th, 2012, 07:10 AM | #10 |
Join Date: Nov 2011 Motorcycle(s): 09 250r race bike, 06 R6 race bike, 06 YZ450f Tard Posts: 122
once i took the collector pipe off(where the 2 go into 1) i could line up both pipes to fit nicely, do not tighten them down all the way, leave 'em loose enough to be able to wiggle them to get the collector pipe back on. I struggled for awhile befor i got them to fit square.
January 8th, 2012, 02:24 PM | #11 |
I hate driving...
^Race exhaust? I should have mentioned mine is the 18" quiet core and the entire pipe is one piece. I assume the OP has the non-race exhaust as well.
January 8th, 2012, 03:40 PM | #12 |
Join Date: Nov 2011 Motorcycle(s): 2005 HON CBR1000RR Repsol, 2012 KAW Ninja 250R Posts: 131
I'll be installing my Area P high mount race exhaust later this week... I sure hope I don't run into this issue
January 8th, 2012, 06:01 PM | #13 |
January 8th, 2012, 08:26 PM | #14 |
that would make a difference......
January 8th, 2012, 08:33 PM | #15 |
I hate driving...
Wellz, I guess I'll make a call about it too. I had pm'ed kbryant about it but he didn't say much about the fit of it; mainly just as long as there aren't any leaks its fine. The way it meets up with my head on the left side really doesn't look right (there could be a small leak but I can't tell with absolute certainty). Would have called sooner but I've been quite busy
January 23rd, 2012, 08:28 PM | #16 |
Join Date: Jun 2011 Motorcycle(s): 2011 Kawasaki Ninja 250R (sold), 2007 SV650s (deer wrecked), 2010 Suzuki SV650S Posts: 334
Are there any updates regarding this issue? I'm only curious to see if this affects performance in any way.
January 23rd, 2012, 08:52 PM | #17 | |
(Affecting performance)- bike is winterized,still sitting inside my sunroom. Haven't started it up yet. |
January 23rd, 2012, 08:55 PM | #18 |
Great, thanks!
January 24th, 2012, 12:10 AM | #19 |
I hate driving...
Mines is okay, I had it checked for leaks. I talked to Kerry and he said if any issues occur to just call him up and they will take care of it.
area p tuner question | jaybo | 2013 - 2017 Ninja 300 Tech Talk | 2 | December 26th, 2012 06:23 PM |
Universal Speedometer Installation - question on internal nightlight | Sarhaider | 1986 - 2007 Ninja 250R Farkles | 8 | October 16th, 2012 08:53 AM |
LEDs for body - installation question. | agalloch | 2008 - 2012 Ninja 250R Farkles | 25 | July 22nd, 2012 02:41 PM |
Area P standard exhaust question! | Jiggyfly | Ninjettes At Speed | 2 | December 27th, 2011 02:07 AM |
LED Question (Blue or White + Installation) | AeroXtasy | 2008 - 2012 Ninja 250R Tech Talk | 18 | August 26th, 2011 10:10 PM |
