November 30th, 2015, 10:36 AM | #1 |
Join Date: Aug 2015 Motorcycle(s): 05 Ninja 250, 04 KTM 625 SMC, 01 Xc250 Posts: A lot.
2 into 1 exhaust header options
I contacted area p about buying a set and they said in order to be interested in selling a pair they would need a group buy of 25 or more. Being realistic, the only option I see is doing some math, getting some pipe, and making a pair myself. Does anybody know of any other options?
November 30th, 2015, 10:46 AM | #2 |
Whoa! If Kerry would really do another run of pregen pipes then you just might get a GB order of 25. It is kinda understood around here that AreaP will not be making any more pregen pipes.
Can you confirm that he would in FACT do a production run and sale?
November 30th, 2015, 10:54 AM | #4 | |
Chaplain
Join Date: Nov 2015 Motorcycle(s): 75 RD350 race bike, 82 XZ550RJ Vision, 81 XV920RH, 89 VTR250 Interceptor race bike, 06 Concours, 86 EX250E1 Posts: 153
God chose what the world thinks foolish to shame the wise,what the world thinks as weak to shame the strong,what is despised in the world,what is nothing,to set aside what is regarded as something |
November 30th, 2015, 10:59 AM | #5 |
In my mind two 90s and seven 45s would do the trick, but four 90s and three 45s would be cheaper and still doable. I am not sure on where to best source the pipe, and I am not the best welder, but I can weld mild steel OK.
November 30th, 2015, 11:53 AM | #6 |
Chaplain
Check out this page, 90 and 180 bends could be cut to make the bends you need, ( two 45 ells from a 90 bend cut in the middle) and be economical for that. The 1 1/4" od tube could be what you need, $9 a foot for straight lengths. Then add a few 90 ells and a couple 180's and poof, you have the necessary pre bent and straight tube. They always add about 6" to each end of the bends, i believe also...
http://catalog.woolfaircraft.com/vie...l-bent-elbows? Here is the carbon steel elbows... http://catalog.woolfaircraft.com/vie...l-bent-elbows?
November 30th, 2015, 12:23 PM | #7 |
So far I'm looking at $140+ for the materials for the headers, and I need to touch up on my welding stainless pipe skills. Not bad, but I would prefer to order something dyno proven. Still an option though.
November 30th, 2015, 12:37 PM | #8 |
Chaplain
I just picked up a 2013 EX300 header for $50 on eBay, and I was given a 2012 E250 header, so I will try that and see what I can make, and adapt from those two pieces. Being the EX300 header is 28.6mm, it should flow as well as the current size pipe used on the EX250 pre gen models. I will gut the cat also, as it isn't necessary for our bikes. if I need any pipe, I can order $20 worth from Woolf Aircraft Products. I believe both headers I am going to use are stainless, and should weigh considerably less when I get done than the current exhaust/muffler setup.
November 30th, 2015, 01:02 PM | #10 |
Chaplain
yeah, maybe... but the size is larger than the current postgen header, which is 1" id and that is definitely too small for top end. I think it should be ok.
December 3rd, 2015, 11:37 AM | #11 | |
High quality product, perfect fit on the bike. Many miles with no problems and the stainless steel header, mid pipe and exhaust can are still clean and beautiful. I like the sound of my AreaP stainless steel "long quiet" exhaust canister so much I'm currently talking to Kerry about a custom long quiet canister for my Suzuki GSF400 project bike. |
December 3rd, 2015, 07:51 PM | #12 | |
Chaplain
December 3rd, 2015, 08:45 PM | #13 |
I have a pregen areap system/header hanging in my garage Charlie. I will take some measures for you. Let me know if you need anything specific.
December 3rd, 2015, 08:47 PM | #14 |
If you would give me inner diameter, and the length from the merge point to the exhaust port for both sides it would be much appreciated Chris.
Because Unregistered sucks at riding. |
December 3rd, 2015, 09:06 PM | #15 |
This is an AreaP full race system for a pregen. Cobwebs add .0001 inch. lol
December 3rd, 2015, 09:10 PM | #16 |
K, give me till tomorrow please.
December 4th, 2015, 03:56 AM | #17 |
Chaplain
Hehe they do add some... ya know, it looks like the exhaust port is 1 1/2" OD, but only for the collar where the flanges are. The pipe beyond the collar looks to be smaller than that. Is that correct, Chris? Is there any way you can measure the OD of the header pipes themselves, if they indeed are smaller than the part you are measuring in the picture? Thanks, brother!
December 12th, 2015, 05:19 PM | #18 |
gokartmozart
Join Date: Nov 2015 Motorcycle(s): 250 ninja ,it's realy a ninja motor on a scratch built alum chassis (avatar is my old kart) Posts: 22
2 into 1 optoins
Looks like several people are puzzled over pipe sizes, don't know exactly what a "pre gen" is , might offer to help me here. My pipe OD on my 2004 is 1.25 (1 1/4) , just got an ebay 2 into 1 that was claimed to be a 2010 250 ninja , with a pipe OD of 1" !! . OK, is this a correct pipe size for a 2010 ? my intent was to buttweld my 2004 flange ends to the 2010 header to custom make a 2 into 1 to fit my kart. It's hard to see how a pipe that small goes on a 250.
Will legalized marijuana remove roadrash scars ? |
December 12th, 2015, 05:32 PM | #19 | |
MOTM - Jan '18, Sep '13
New Gen = 2008-2012 ninja 250
My Ninja 300 |
December 12th, 2015, 07:16 PM | #20 |
Freedom for Germany
Some information about the best exhaust in case of the Ninja 250 FI ever.
It also was good for a big power gain for the US-Carb model also, watch the vid https://www.youtube.com/watch?v=wOGOyJyWrG4 And for more technical background read the technicals I attach... (Italians know very well how to create a powerful exhaust) Last futzed with by Somchai; January 23rd, 2016 at 11:38 PM. |
December 13th, 2015, 07:37 PM | #21 | |
Chaplain
January 11th, 2016, 06:45 PM | #22 |
gokartmozart
pre gen head pipe vs new gen vs ex 300
The photo of the areaP head pipe looks VERY similar to what I thought might work for my 2004 ex250 . Will the 1'' dia pipe flow OK ? Have you completed / tested your design yet Your '86 / ex300 build sounds very much like my '04 /'10.
Shorty exhaust/Exhaust options? | GregEvans | 1986 - 2007 Ninja 250R Tech Talk | 14 | November 4th, 2015 07:32 PM |
header options | sharky nrk | Ninjettes At Speed | 3 | August 29th, 2013 10:07 AM |
Exhaust Options | codestp202 | 2008 - 2012 Ninja 250R Tech Talk | 15 | April 3rd, 2012 12:51 PM |
Exhaust hanger options | DR1300R | 2008 - 2012 Ninja 250R Farkles | 31 | May 18th, 2011 06:18 AM |
Looking for cheap exhaust options | NinjetteMan | Items Wanted | 10 | April 9th, 2009 02:20 AM |
