Old July 22nd, 2011, 08:27 AM   #1
Davey
Davey's Avatar
Motorcycle(s): Ninja 250R 2010 fuel injection model. 1989 Tzr125
Top Speed
i recently placed a full aftermarket leo vince exhaust on my ninjettte and a k&n filter an have had a top speed of 112 on the motorway at 13K revs. rather it was an accurate reading or not i dont know.
however seeing i didnt have my license when i had the bike stock i was wondering if there is much of a difference in speed between aftermarket n stock n wat other top speeds everyone else has had??
Davey is offline   Reply With Quote
Old July 22nd, 2011, 08:35 AM   #2
/moved to new-gen tech
The speedometers are quite optimistic. The rev limiter in top gear (without any gearing changes) is around a true 105 mph.
Old July 22nd, 2011, 10:52 AM   #3
i have an aftermarket speedometer that reads 1,000 MPH at 13k/6th on my bike... top that!
Old July 22nd, 2011, 10:54 AM   #4
dubojr1
dubojr1's Avatar
Pictures or your lying...
Old July 22nd, 2011, 12:04 PM   #5
greg737
Motorcycle(s): -
It's been proven by a number of people using GPS systems that the EX-250 (both old generation and new generation bikes) have about an 8% speedometer error, and that error is "optimistic" meaning it says you're going faster than you think you are.
A few more scientifically-minded EX-250 riders have determined that the speedo error isn't 8% across the board. Rather, we generalize by saying it's an 8% error but in reality it's a bit less than 8% at lower speeds and about 8% at medium speeds and a bit more than 8% at the bike's highest speeds.
So I'd imagine that it would be realistic to say that at an indicated 112 mph you're probably seeing about a 9% error. So that would put you at 102 mph.
Beyond that, I see your bike is a European Fuel Injected model. When you put the free-breathing exhaust and intake on the bike did you also put in a Power Commander chip or do anything to re-map the fueling tables in the bike's ECU? If you didn't then the bike would be running lean because it's flowing more air but nothing has been done to cause it to inject more fuel (more air with the same fueling table equals a lower fuel/air ratio which means a leaner burn).
Running lean air/fuel ratios during high engine load conditions (wide open throttle) is a bit of a dangerous thing with respect to engine health. A lean air/fuel ratio means there's more oxygen left over after the fuel is burned inside the combustion chamber. That extra oxygen is always looking for something to combine with (burning fuel is really just oxidation that happens really quickly, as opposed to rust which is really slow oxidation of iron). The problem is that oxygen can combine with (oxidize) really hot aluminum, which is what your pistons are made of.
Old July 22nd, 2011, 02:32 PM   #6
Racer x
Racer x's Avatar
MOTM - Sep '18, Feb '16
It all has to do with power .it takes 40hp to go 120 mph .30 hp will hit about 112 and the stock bikes go 110 down hill with a tailwind.but it takes a long time to reach that speed. Stock bolt on parts you will hit an honest 105.
Old July 22nd, 2011, 04:08 PM   #7
almost40
ninjette.org Monkey Spank
almost40's Avatar
http://www.ninjette.org/forums/showthread.php?t=77557
Black 250R
Full Area P QC
Old July 22nd, 2011, 10:47 PM   #8
blink
Always.
blink's Avatar
Motorcycle(s): '08 Ninja 250, '05 GSX-R600
Not sure, but couldn't go any faster...then a cop pulled out infront of me and I slammed on the brakes. He continued driving away and my heart could breath again, =]
blink-182
blink is offline   Reply With Quote
Old July 22nd, 2011, 11:38 PM   #9
SES2009
Glad the police left you alone but I would get your heart checked out because last I heard your heart should be beating not breathing
SES2009 is offline   Reply With Quote
Old July 23rd, 2011, 12:34 AM   #10
kaiserz
There's a limit to s2pdty
kaiserz's Avatar
good eye
Old July 23rd, 2011, 07:01 AM   #11
Davey
Davey's Avatar
im going to get it remapped after the weekend. i was told by the company i bought the exhaust off that nothing will need done to the bike for it to work properly but since its been on, the bike now makes a crackling sound now n then
Old July 23rd, 2011, 07:07 AM   #12
Davey
Davey's Avatar
jst got a quote there for the power comander and to get it remapped on the dyno. freaking £380 quid
Old July 23rd, 2011, 08:12 AM   #13
SSR
Just a heads up that this is a public forum and we do have our names and locations in our profile. You never know when a cop from your area could be browsing this forum...
From here...to everywhere!
SSR is offline   Reply With Quote
Top Speed? Mike K 1986 - 2007 Ninja 250R Tech Talk 16 September 2nd, 2014 03:51 PM
Top Speed higear223 2008 - 2012 Ninja 250R Tech Talk 14 August 3rd, 2014 09:59 AM
Top speed? uKER 2013 - 2017 Ninja 300 General Discussion 27 July 20th, 2013 11:33 AM
Top Speed Help!!!! Black Rabbit 2008 - 2012 Ninja 250R Tech Talk 68 September 3rd, 2012 03:30 PM
Top Speed? peter330 2008 - 2012 Ninja 250R Tech Talk 30 May 29th, 2010 03:02 AM
