October 6th, 2014, 05:47 PM | #1 |
Join Date: Mar 2011 Motorcycle(s): 09 Ninja 250r Posts: 634
Emulators worth the money or are springs good enough?
to give you guys a background I'm a season rider who has put 50,000+ miles on my 09. I ride hard, 80% of the time at 9000+ rpm's and I love twisties and do some trackdays as well.
Since I'm with my bike for the long run I've done tasteful mods, such as rearset adjusters, clip ons, Akrapovic exhaust, shim/snorkel delete. I like how my bike is now, the only thing lacking is suspension. Its all stock and has been beat to **** at this point. I was thinking of getting Race Tech springs for my weight and then started looking into the emulators as well. Springs are about $120 and can easily be popped in while doing a fork oil change. Emulators on the other hand will cost a lot more, about 180 for the parts and 2-3 hours labour (its not something I'd do myself). I have a good relation with my local shop and the mechanic there who is an ex WSBK racer said pop in the springs and leave it at that...emulators are not worth it, especially on a bike with no front adjustment. He said since I've ridden 6 seasons on stock settings proper springs a rear shock will be a huge improvement for me. I'd also save a few hundred bucks. So, to guys who have done this or have knowledge of this mod, are springs alone a good enough upgrade or is worthwhile to invest in emulators as well? PS: Looking at the spring rate calculator when I put in my weight on the street setting it gives me a spring rate of .75kg/mm on track its .80kg/mm. What is the difference between street and track settings? Is it accounting for harder riding style or extra weight from full track gear? I ask this because even on the street I ride HARD and am usually fully geared up.
”Any man dies with a clean sword, I’ll rape his f***ing corpse!”- The Hound |
October 6th, 2014, 08:01 PM | #2 |
Emulators are somewhat useless without the proper spring rate. Go with springs first and emulators down the line. You will notice a big change in handling with the proper rate springs. I went with the ricor intiminators for a good deal and handling did improve in bumpy situation but I still bottomed out under hard braking.
October 6th, 2014, 08:17 PM | #3 |
^^^ yep, springs will get you 80 for 20. Thing is, the 20 percent is personal feel and rider needs. You can always add the emulators or intimidators later if you can't get the suspension action you as a rider are after. imho, the biggest front end setup issues are springs, preload spacer length and the weight of oil for "you".
October 7th, 2014, 07:39 AM | #4 |
Fighting Texas Aggie '05
Correct springs are far more important that the emulators, but emulators can provide you another method of fine tuning your suspension action over the standard orifice fluid damping you get from the stock setup. It is personal preference as to how much money and time you want to put into your setup. You can make lots of headway with correct rate springs, setting your sag via preload properly, then tuning what you can with air gap and oil weight.
October 7th, 2014, 07:43 AM | #5 |
and just FYI - if your not comfortable with doing the emulator install yourself, chances are you are its not worth the cost of paying someone else and your not going to be pulling and adjusting the emulators to get it "perfect" anyways. Just go with springs, spacers, and up your oil weight. Sounds like close enough for what you need.
October 10th, 2014, 06:17 AM | #6 |
Join Date: Jan 2012 Motorcycle(s): Race bikes:08 Ninja 250,11 R6,16 ZX6,SV650.3 HD-1947,2-2003,2010. 1946 Indian and a lot of dirt bikes.2 Posts: 999
I have 2 Ninjas race bikes without emulators and one with. I find NO difference with the emulators, actually my fastest laps have been on the bike witout!
October 10th, 2014, 07:34 AM | #7 |
Join Date: May 2014 Motorcycle(s): 09 Ninja 250 Posts: 46
Agree with everybody else. Swapped my stock springs to Sonic Springs the other day and went for a ride last night. Night and day difference!
new springs, emulators, springs sound noisy? | subxero | 2008 - 2012 Ninja 250R Tech Talk | 6 | April 19th, 2014 04:14 AM |
BR i-DTIS worth the money? | Bob2010 | 2008 - 2012 Ninja 250R Tech Talk | 2 | September 4th, 2012 06:46 PM |
WTB: PREGEN cartridge emulators/springs | espacef1fan | Items Wanted | 0 | July 12th, 2012 10:11 PM |
Why MSF is soooo worth the money (like you needed proof) | Gurk | Riding Skills | 10 | August 17th, 2011 08:36 PM |
$99 modular helmet worth the money? | Liquidtoon | Motorcycle Gear | 8 | August 1st, 2011 07:12 PM |
