Old December 14th, 2014, 10:17 AM   #1
Lookmomimaninja
Motorcycle(s): 2012 Kawasaki ninja 250
Unhappy New bike won't start. PLEASE HELP!!
Hello everyone thank you for your help in advance!! I am new to bikes and the forum so I really appreciate every bit!!
Ok so I got a bike for doing some work for a police officer on her sons car. It is a 2012 Kawasaki Ninja 250. I've wanted a bike for a while and the 250 is perfect to learn better on especially because I got it for only 500 worth of parts.
First off if there is ANYONE in Vegas as well please let me know or tag them etc!!
So her son dropped it and she didn't want him to have it anymore after that. He broke the key when it fell so I had to buy a new ignition switch for it. I just got it in the mail, hooked it up and tried to start it. No luck. It's trying to but doesn't start. So I figure the starter itself is good. I took after the airbox to find out it was filled with what looks like gas and maybe some oil in it. I removed the airbox (it was a PAIN) then did a little research and seen that if the airbox filled then I need to drain the carbs too. So I did. Still no luck.
What typically can get damaged when it's dropped. I know a lot is protected by the frame but from impact anything could happen to my knowledge.
I need to buy a new bracket for the rear brake set. So if you know where I can get just the bracket for the low please post the link to it for me please.
Also the handle bar bent a little bit and the throttle doesn't snap back I have to open and close it manually.
Someone please help me out. First bike and I want to learn the mechanics of things so I can do things myself.
Thank you all!!
Armani
Lookmomimaninja is offline   Reply With Quote
Old December 14th, 2014, 10:24 AM   #2
The more information you post about what it's doing, the more folks may be able to help out with suggestions. With any luck, we can help get you running.
- When you turn the key, do the dash lights come on?
- When you press the start button, does the starter spin the engine, but it won't catch? Or is it not spinning the engine at all? edit: just read that you posted that it is trying, which sounds like it is spinning a bit. Does it sound like it is spinning reasonable fast, or does it sound like it's struggling?
There is no tipover switch on these, so there is nothing that should need to be "reset" after a drop for it to work again. It could be as simple as clogged carbs from sitting that long, which would mean cleaning them out and potentially replacing any clogged jets.
Old December 14th, 2014, 10:26 AM   #3
Welcome Armani!
Old December 14th, 2014, 10:30 AM   #4
Lookmomimaninja
The lights do come on. It sounds like it is spinning. Honestly I'm not sure how it should sound so I don't know if it's struggling for spinning fast.
Actually what I can do is go outside and do a video of it. I'll put it on YouTube then post the link here so everyone can see what it's doing. I really want to get it running!
Old December 14th, 2014, 10:31 AM   #5
Lookmomimaninja
Welcome Armani!
Thank you.
Old December 14th, 2014, 10:44 AM   #6
Lookmomimaninja
Here is the video:
http://www.youtube.com/watch?v=W8BUyDOatow
Old December 14th, 2014, 10:51 AM   #7
cbinker
Track Clown
cbinker's Avatar
MOTM - Sep '15
bad fuel in the lines. Drain fuel from tank and replace with new fuel. Open choke all the way, pump the throttle a couple times, try to fire it up again with the throttle open.
TEAM ALFALFA
www.apexassassins.com
Old December 14th, 2014, 10:56 AM   #8
Lookmomimaninja
It is brand new fuel in it. I use 91 from chevron
Old December 14th, 2014, 11:14 AM   #9
NevadaWolf
Certified looney toon
NevadaWolf's Avatar
MOTM Jul '13, Jul '14
Howdy and welcome neighbor from the cold northern half of the state.
Can't help ya with your problem, but do want to comment on this.
No need to be buying the expensive stuff. Our bikes run fine on standard old 87.
I refer you to this thread: https://www.ninjette.org/forums/show...t=15904&page=4
<-- Linky
Old December 14th, 2014, 11:17 AM   #10
cbinker
Track Clown
cbinker's Avatar
MOTM - Sep '15
there is still old fuel in the lines, did you try the choke and pumping the throttle a few times?
TEAM ALFALFA
Old December 14th, 2014, 11:18 AM   #11
Lookmomimaninja
It's a habit. I put 91 in all my cars so figured I'd do the same for my bike.
Old December 14th, 2014, 11:19 AM   #12
Lookmomimaninja
Yes. I pulled the fuel lines and ran about 1/4 gallon through it then drained again. Then filled up
Old December 14th, 2014, 11:47 AM   #13
cbinker
Track Clown
cbinker's Avatar
MOTM - Sep '15
Have you adjusted the idle screw on the left side of tank?
TEAM ALFALFA
Old December 14th, 2014, 02:13 PM   #14
.......... Someone please help me out. First bike and I want to learn the mechanics of things so I can do things myself............
Welcome, Armani !!!
Don't go crazy about starting that thing up.
I would first replace that right handlebar: do not attempt riding like that; riding with impaired throttle and front brakes is dangerous.
You have several things to verify and do before starting up is possible:
https://www.ninjette.org/forums/showthread.php?t=208758
http://faq.ninja250.org/wiki/Troubleshooting
Old December 14th, 2014, 02:27 PM   #15
chrly
chrly's Avatar
Motorcycle(s): 2013 Kawasaki EX300 , 1999 Kawasaki ZRX1200.
Sounds like the battery is too week to fire the ignition..I have found that several Kawasaki models , suffering from a weak battery, just will not start..It is imperative to have enough juice, I think it is 11.5 volts minimum, otherwise it will just spin the motor.. If that bike has been sitting for awhile it is very possible it is in a weakened state..
IBA # 59523
chrly is offline   Reply With Quote
Old December 14th, 2014, 03:07 PM   #16
cuong-nutz
cuong-nutz's Avatar
If you bought the knockoff chinese ignition switch then that's why it doesn't work. If the previous owner broke the key off than you can remove the broken piece out and get a new key made. Got any pictures of the stock ignition lock?
HalfFast Racing Team
Old December 14th, 2014, 03:22 PM   #17
Lookmomimaninja
I'm going to upgrade and replace the battery this week
Old December 14th, 2014, 03:26 PM   #18
Lookmomimaninja
The key isn't inside it anymore but the locksmith said that it damaged the inside prongs I think lol. So I had to order a new switch. The new one cuts everything on properly, bike just isn't turning over.
Old December 14th, 2014, 03:29 PM   #19
cuong-nutz
cuong-nutz's Avatar
Did you buy an OEM Kawisaki ignition or the chinese one off of ebay for $13?
Old December 14th, 2014, 03:34 PM   #20
Lookmomimaninja
No I bought one from mad hornets that was like $43 and it wasn't the right one. It was a 6 pin. So I found someone locally that was selling parts from a 250 and I bought theirs. I wish he had the gas and cargo locks too smh
Old December 14th, 2014, 03:36 PM   #21
Lookmomimaninja
Yes. I twisted it both ways and tried several times
Old December 14th, 2014, 05:02 PM   #22
bdavison
Wartown, USA
bdavison's Avatar
As the old saying goes "It needs three things to work, air, fuel, and fire...if one's missing the thing wont run."
Concentrate your efforts on those three areas.
Make sure the airbox is clear of any debris or trash, and that the filter is clean and oiled properly.
Make sure the carbs are clean, and that the moving bits (diaphragms, needles, floats, etc) are moving smoothly and not gummed up with residue from old gas sitting in the bike under long term storage.
Check the fuel lines for clogs, and the fuel filter too.
Check the sparkplugs, and make sure they are not gapped wrong, or trashed.
Check to make sure when you hit the ignition, that the plugs are actually sparking (don't zap yourself doing this)
Old December 14th, 2014, 05:41 PM   #23
cbinker
Track Clown
cbinker's Avatar
MOTM - Sep '15
Im stumped, unless I was there to put my hands on it, i got nothing.
TEAM ALFALFA
Old December 14th, 2014, 07:10 PM   #24
snot
sammich maker
snot's Avatar
MOTM - Apr '15
I am going with battery.
Welcome and good luck.
Old December 14th, 2014, 07:16 PM   #25
cbinker
Track Clown
cbinker's Avatar
MOTM - Sep '15
it turns over in the video, just doesn't start. so not likely battery.
TEAM ALFALFA
Old December 14th, 2014, 09:38 PM   #26
Lookmomimaninja
U said 3 things then named 4 lol jk. But I just found out it's not sparking. I replaced the spark plugs because they were ****. still no spark. Then I checked the coils and they gave no readings. Going to change those then try again.
Old December 14th, 2014, 09:39 PM   #27
Lookmomimaninja
That's exactly what I need. I can't find anyone who rides out here that knows anything about what they are riding smh
Old December 14th, 2014, 09:40 PM   #28
Lookmomimaninja
Battery is sitting on the trickle charger for the night then I'm going to change the coils and try it then.
Old December 14th, 2014, 09:42 PM   #29
Lookmomimaninja
That's what I was thinking. If that part works like a cat and I'm sure it does then it can't be the battery. Granted the battery was low it still gave it enough to turn. But I did the ohm reading on the coils and they are flat lined. So I def need new coils. Praying that works sigh
Old December 15th, 2014, 07:55 AM   #30
Are you sure you tested the coils properly?
It would be really odd that both coils failed at the same time. I would check wiring and connectors that supply power to the coils, and check the voltage at the coil. Maybe someone can confirm, but I believe you should see battery voltage on the main terminal when the ignition is on.
That battery is too low to get decent cranking, and maybe too low to get a decent spark.
Old December 15th, 2014, 08:49 AM   #31
cuong-nutz
cuong-nutz's Avatar
Can you take pictures of your old and new ignition lock switch?
Old December 15th, 2014, 11:57 AM   #32
I was wondering about the switch too. Do different years have different pin configurations in the connector?
Old December 15th, 2014, 09:04 PM   #33
Lookmomimaninja
Yes I will in a few. Someone on another forum just told me that the new switch may not have the 100 ohm resistor that is needed to kick the Cdi on. Is there anyway to see if the new one has it?
Old December 15th, 2014, 09:14 PM   #34
Lookmomimaninja
I replaced the coils and guess what...still no spark
Old December 25th, 2014, 06:34 PM   #35
chrly
chrly's Avatar
If the battery drops below a certain level it will NOT trigger teh ignition even tho it will turn the motor over. If the ignition is not triggered you will get no spark..Do you know how to use a spare spark plug to check for spark?
IBA # 59523
Old December 25th, 2014, 07:10 PM   #36
Yup...
Old December 25th, 2014, 08:25 PM   #37
Hero Danny
Inline 4!!!
Hero Danny's Avatar
His battery seems fine to me, sounded like it had some juice. I'd put my guess on a bad wire, possibly a ground?
Be careful. Remember you are
invisible
Old December 29th, 2014, 12:10 AM   #38
cuong-nutz
cuong-nutz's Avatar
Old January 2nd, 2015, 03:21 PM   #39
ninja250r81
ninja250r81's Avatar
Motorcycle(s): 2012 ninja 250r se
Get a multimeter that has continuity tester and start probing wires.
Put +ive and -ive on either end of the wires you are checking it should "beep".
Much saver than checking the "hot" version. Connecting a battery one end and looking for power.
Some thing is not getting a signal to switch or activate.
Should always probe before replace less costly in replacing good parts when its a wire or a terminal.
ALWAYS DISCONNECT THE BATTERY
Safe probing :-)
ninja250r81 is offline   Reply With Quote
Old September 4th, 2015, 10:50 PM   #40
nathan1
Motorcycle(s): none
Hey ive got the similar issue with my bike. No seems to make any sense or actually answer the question thats been asked or help with the problen at hand. Info seems to be everywhere.
I need help from a pro.
Like i said same thing as this guy. No spark. The same trying to start noise. I've replaced coils etc so don't give the same obvious answers. 3 new oem ignition switches stock. No spark. Tested it all.
Is there a certain setup within the ignition switch? How is the resistor setup supposed to look? Theres a grey wire connected with a resistor. Is there another wire that should be with it?
09 kawasaki 250r carb version.
Thanks for the help if anyone can help.
And yes carb, stator etc are all good just to save a nuisance of having to answer the same stuff a thousand times.
If you've been through similar stuff and fixed the issue could you let me know please. Ta
nathan1 is offline   Reply With Quote
Bike Won't Start momoru 1986 - 2007 Ninja 250R Tech Talk 6 June 18th, 2014 08:34 AM
bike won't start. tried everything rabies 1986 - 2007 Ninja 250R Tech Talk 17 September 22nd, 2013 04:46 AM
Bike Won't Start! jmgrande 2008 - 2012 Ninja 250R Tech Talk 3 March 12th, 2012 05:52 PM
Bike won't start joyinc 2008 - 2012 Ninja 250R Tech Talk 21 May 31st, 2010 09:10 AM
