Old August 8th, 2013, 10:12 AM   #1
juanpak87
Motorcycle(s): ninja 250
best shocks?
Any recommendations on what shocks i should get for my 99' 250r?
juanpak87 is offline   Reply With Quote
Old August 8th, 2013, 10:25 AM   #2
The easiest route is a new gen shock
The next easiest is a gsxr shock with custom bones, bolts and spacers
The rest is a function of your budget lol
Old August 9th, 2013, 08:14 AM   #3
agentbad
agentbad's Avatar
Can't you get a used ninja 300 shock and put it on a 250 or would a new gen be better?
Old August 9th, 2013, 12:50 PM   #4
Lychee
sail away
Lychee's Avatar
I have a 300 shock in my pregen and the 300 shock is an easy plug and play option as far as installing it goes. Compared to the pregen shock it is much stiffer, and has an adjustable preload. There are no other adjustments.
As far as comparing to the newgen shock, the numbers behind the 300 shock are a bit hard to find. From opinions on the internet and a second hand opinion of one of Race Tech's riders it is supposed to be stiffer over all than the newgen due to changed damper valving (or damper rod holes/oil weight/oil amount/whatever). It also supposedly has the same spring rate as the newgen, except with a longer spring, which allows for an extra preload setting. I haven't been able to confirm these findings and some marketing websites say that the shock is softer, in direct conflict with this information.
For reference, Race Tech says the new gen has a 9.3 kg/mm spring rate and the ninja 250 faq says the pregen has a 440 lb/in spring rate which equates to 7.86 kg/mm.
Old August 9th, 2013, 01:16 PM   #5
I run a newgen shock. Not bad little change considering it only cost me $40. I might go with a 300 shock once I do emulators and heavier oil in my forks. Who knows?
Like chris said, it's really a function of budget when considering 'the best'
Old August 9th, 2013, 01:18 PM   #6
KawiKid860
KawiKid860's Avatar
Isn't the 500 shock a common swap on the pregens? Or is the newgen/300 kit better than the 500s?
Old August 9th, 2013, 01:38 PM   #7
500 shocks are shorter, have softer springs, and require tons of preload. Some people swear by them, but I think the newgen/300 shocks are better options because they're newer and are designed for nearly the same bike with nearly the same suspension geometry.
Old August 9th, 2013, 02:45 PM   #8
quarterliter
Motorcycle(s): 2004 Ninja 250
The 500 shocks aren't an upgrade.
Old August 9th, 2013, 04:01 PM   #9
agentbad
agentbad's Avatar
I don't need the best just something that will do better then the stock pre gen since I'm a bigger rider.
Old August 12th, 2013, 08:57 AM   #10
juanpak87
Is there a website where i can purchase one of these shocks?
Old August 12th, 2013, 02:42 PM   #11
FvnnyL3tt3r1ng
FvnnyL3tt3r1ng's Avatar
Motorcycle(s): Ninja 250 2001
Ebay is the cheapest. I think buying them new is gonna cost you like 5-10x more.
Mods: Offset clutch pressure plate
Old August 12th, 2013, 02:51 PM   #12
Lychee
sail away
Lychee's Avatar
Craigslist. There is one on sale locally actually.
Old August 12th, 2013, 08:20 PM   #13
Monkeytofu
I told you bro
Monkeytofu's Avatar
+1 to newgen shock.
Newgen shock is definitely what you're looking for. Cheap, easy to install, makes the bike a hair taller, and can be adjusted to fit your weight.
Old August 15th, 2013, 10:39 AM   #14
spc2125
Motorcycle(s): 10 Ninja 250
whats people inputs for quality of ride with new shocks? Able to handle more weight with a passenger? Better over bumps? etc.
spc2125 is offline   Reply With Quote
Old August 15th, 2013, 11:02 AM   #15
Lychee
sail away
Lychee's Avatar
@spc2125 All of the above. The pregen shock is really bouncy, like an old Cadillac. They tended to hydraulically bottom out if you were on a downward part of its oscillation and hit a bump. It squats very low with a passenger. On a side note. if you upgrade the rear shock only, you will really notice how crappy the front suspension is as well. Same problems as the rear, except that the squat comes from breaking instead of a passenger.
Old August 15th, 2013, 02:59 PM   #16
tc.young
Motorcycle(s): '89 klr 650, '00 250r
i say newgen, 40 bucks, preload. made mine a bit firmer. also reminded me the front needs a bit of improvement.
tc.young is offline   Reply With Quote
Old August 15th, 2013, 04:40 PM   #17
FvnnyL3tt3r1ng
If you're gonna be carrying a passenger definitely buy the new-gen or 300 shock (or anything other than the stock). It is definitely stiffer and a used one is a pretty cheap upgrade. I wouldn't ever go back to stock. The one thing I've noticed is it is a tad bit easier to lock up the rear wheel during heavy braking.
Old August 16th, 2013, 06:30 AM   #18
Crriiissss
Crriiissss's Avatar
Motorcycle(s): 2009 Ninja Thunder Blue(sold), 2004 Suzuki GS500f(sold), 2006 Ninja 250, 2013 Ninja 300 SE
Here you go
http://www.ninjette.org/forums/showthread.php?t=145651
Crriiissss is offline   Reply With Quote
Old August 23rd, 2013, 06:42 AM   #19
7oxSin
MSF Coach!
7oxSin's Avatar
Motorcycle(s): 2003 ninja 250
Time for a bump, im bitting the bullet and upgrading my shock, i have a list of shocks and prices. it would kick monumental amounts of ass if yall could let me know which on of these would fit/be best. been trying to google with no luck.
Preemptive thanks!
01 zx6r 20$
09 ninja 650 25$
05 636 23$
96-03 zx7r 25$
08 zx6r 25$
99 zx9r 20$? (no buyout only bids)
these are what i have found so far, any input would rock, im still looking around for newgen or 300 shocks but i would rather spend 25 then 40 if i can.
Hey Unregistered wanna ride the dragon? Ninjette group ride! May 16th-20th
Join the Ride!!http://www.ninjette.org/forums/group.php?groupid=35
7oxSin is offline   Reply With Quote
Old August 23rd, 2013, 12:17 PM   #20
7oxSin
MSF Coach!
7oxSin's Avatar
Bump cuz its time sensitive?
Old August 23rd, 2013, 12:48 PM   #21
Lychee
sail away
Lychee's Avatar
These shocks may require modification to fit into the 250. I recommend you research before you push the buy button. Anything will fit with enough time and money.
Old August 23rd, 2013, 01:33 PM   #22
7oxSin
MSF Coach!
7oxSin's Avatar
yeah im hoping some one here has done it, just dont wanna pay 40-50$ for a shock upgrade, rather put some of that money towards more needed parts.
Old August 23rd, 2013, 01:51 PM   #23
ninjamunky85
Que Buenos Son!!!
ninjamunky85's Avatar
MOTM - Nov '14
I put swapped the shock in my 300 for one from an '07 gixxer 600. I'd imagine it would work with a pre-gen.
Old August 23rd, 2013, 02:33 PM   #24
7oxSin
MSF Coach!
7oxSin's Avatar
hmm is the 300 backwards compatible with the pregen? if so did the gsxr use the same bolts? and also did it change your ride height?
Old August 23rd, 2013, 02:50 PM   #25
Lychee
sail away
Lychee's Avatar
Yes it is, I have Ryan's 300 shock in my pregen lol. If there was a change in ride height I did not notice it. The gsxr shock requires modification.
Old August 23rd, 2013, 02:56 PM   #26
your weight:
below 120lbs: no change
below 150lbs: newgen or 300 shock
above 150lbs: gsxr shock
annual income above 75k: ohlins, baby. ohlins.
Old August 23rd, 2013, 03:32 PM   #27
7oxSin
MSF Coach!
7oxSin's Avatar
your weight:
im 195 and i 2up my wife atleast 4 times a week.
Old August 23rd, 2013, 03:41 PM   #28
cool
Old August 24th, 2013, 06:44 PM   #29
FvnnyL3tt3r1ng
I would recommend the gxsr shock. I have personally never ran it but the newgen shock is still too soft for my preference, as stiff as it is (on stiffest setting).
Old August 24th, 2013, 07:31 PM   #30
fr1dayn1ght
fr1dayn1ght's Avatar
Motorcycle(s): '07 Ninja 250 (sold), 2013 CB500F
after reading this and some of the threads about shock upgrade i went on ebay and grabbed a newgen shock for 40 buck exciting!
quick question though: where can i get that special wrench to adjust the shock? or can you do it without??
fr1dayn1ght is offline   Reply With Quote
Old August 24th, 2013, 07:41 PM   #31
It's called a spanner and they can be purchased used from OEM toolkits or you can also get them at cheapcycleparts.com
Old August 24th, 2013, 07:55 PM   #32
7oxSin
MSF Coach!
7oxSin's Avatar
when i dont have my wife on the ninja with me will a super stiff shock **** me up?
Old August 24th, 2013, 08:02 PM   #33
FvnnyL3tt3r1ng
I think a softer shock would f you up more by giving you more upset in turns and what not. It will probably be more jerky I mean you don't have to set it all stiff you can have sag I just personally would go stiffer. Think about it less momentum is gonna be absorbed and more is gonna be transfered to your tires. At least that's how it feels....?
Old August 25th, 2013, 12:01 AM   #34
7oxSin
MSF Coach!
7oxSin's Avatar
cool, guess its time to chop up my ninja. need to do some more research before that.
Old August 25th, 2013, 09:12 AM   #35
I don't think so, maybe ride a bit rough and give you a lot of feedback over the bump. But I think the worst of it will be leaned over riding over bumps, that may feel a little less planted and somewhat spooky.
There is not gunna be a setting that is perfect for both 1up vs 2up, only an acceptable middle ground. But you should lean toward the harder settings vs the softer ones. After you get accustom to the harder settings, I bet you will prefer them even while riding solo.
My R6 is set so hard, it barely moves when I mount up. But at pace, it rides like a magic carpet. lol
Old August 25th, 2013, 10:01 AM   #36
FvnnyL3tt3r1ng
Oh yeah turning in is gonna be more difficult so make sure your on point there.
For those with GSX or other oem shocks Somchai 2008 - 2012 Ninja 250R Tech Talk 2 July 7th, 2012 06:50 AM
[topix.net] - From Twin-Tube Single Shocks to Single-Tube Twin Shocks: Ohlins... Ninjette Newsbot Motorcycling News 0 June 5th, 2012 04:30 AM
another question on replacing shocks Luvninja 1986 - 2007 Ninja 250R Tech Talk 3 March 25th, 2012 10:52 PM
Shocks and Rear set GB ztrack157 Motorcycle-related 15 August 2nd, 2011 10:05 PM
What Rear Shocks Will Fit Dano 2008 - 2012 Ninja 250R Tech Talk 2 March 30th, 2010 08:44 AM
