Old April 1st, 2020, 06:41 AM   #1
ssrsupermoto
Motorcycle(s): 2004 Ninja 250
2004 headlight bulb upgrade
Looking to upgrade my headlight bulb to something brighter. Want something that will drop in with little to no modification. Some of the LED headlight bulbs have a giant cooling fan on them and I don't know if the stock rubber grommet will fit over them. Let me know what you guys have used.
ssrsupermoto is offline   Reply With Quote
Old April 1st, 2020, 09:07 AM   #2
Only high-quality H4 halogen bulb will work. Avoid HID or LED bulbs as they are not designed for specific reflector headlight on bike. Will end up with lots of above-horizontal glare into eyes of oncoming traffic. Making for very dangerous situation for you. Unfortunately there's no better replacement headlight, which is usually the best upgrade to start with.
Narva and Flosser bulbs are good. Vosla, Osram Nightbreaker or Philips are good. .
Avoid Sylvania Silvertars, those are crap.
Avoid boutique coated bulbs like PIAA, 4 out of 5 filaments are out of place on those things.
Look at lumens output ratings
All you need to know about lighting: https://www.danielsternlighting.com/home.html
Try to find Osram Rallye H4 70/65w bulb. Its higher efficiency puts out 2000/1850 lumens, about 50% more than regular H4 bulbs. Got one about 2-yrs ago and it's best output out of them all*.
Last futzed with by DannoXYZ; April 1st, 2020 at 04:02 PM.
Old April 1st, 2020, 05:04 PM   #3
For better light output, bulbs makes least difference and should be upgraded last.
1. Best upgrade is to replace headlamp with more modern reflector design such as e-code. For bikes with 7" headlamps, it's simple to replace with Cibié e-code lamp.
https://www.ninjette.org/forums/show...33#post1255133
Even better and more modern upgrade is to do HID retrofit with matching HID reflector and HID bulb.
https://www.ninjette.org/forums/showthread.php?t=335983
https://www.ninjette.org/forums/showthread.php?t=64230
2. Next best upgrade is short heavy-duty harness taking power directly from RR for highest voltage before it's split off to charge battery and run other lights and accessories. Factory wiring has power leaving battery-terminal where it's already lowered by sharing with charging battery. Then it goes to ignition-switch and back to fusebox, through headlight-relay and finally back front to high/low-beam switch and finally to headlight. Peel back rubber cover behind headlight and measure voltage at back of headlight socket with bike running and headlight on. If you're not getting 13.5v at headlight socket, you're leaving A LOT of light on table.
Here's example of Cibié e-code headlight upgrade and heavy-duty 10ga relay harness using exact SAME bulb before & after. No bulb alone can spread out light-beam and give you more lumens on road.
3. Finally upgrade bulb to get +50% more lumens onto road. Without previous mods, you'll still have flashlight-beam output and brighter bulb just gives you brighter spot in middle; not as useful as wider beam.
headlight bulb james250ninja 1986 - 2007 Ninja 250R Tech Talk 1 September 4th, 2014 05:36 AM
What headlight bulb are you using? agentbad 1986 - 2007 Ninja 250R Tech Talk 16 May 22nd, 2014 08:44 PM
headlight bulb recommendation eddiekay General Motorcycling Discussion 13 July 2nd, 2013 09:26 PM
New headlight bulb??? set608 1986 - 2007 Ninja 250R Tech Talk 2 May 8th, 2013 10:09 AM
Headlight bulb question skilletmo 2008 - 2012 Ninja 250R Tech Talk 5 November 22nd, 2012 08:11 PM
