September 11th, 2012, 09:07 PM | #1 |
Jigglin' your Jiglets
MOTM - Apr '13
Putting 100mi on New Tires
Is it all that necessary or is it just a rule of thumb. Here's my thoughts on it, the unscrubbed parts of the tire don't grip well. The middle of the tire is broken in rather quickly possibly within a mile. It's recommended you go slow for the first 100mi so that the contact patch stays mostly on the scrubbed in part and as you slowly do a bit more turning it slowly scrubs in more and more of the tire.
Is that sort of the idea with the recommended 100mi on a tire? If so, in experienced hands would it be possible to fully scrub in the tire in say 20mi? 10mi? 5mi? I'm sure some track junkies will come in and say you dumb**** I put this **** on my bike and then go drag knee
September 11th, 2012, 09:18 PM | #2 |
Ride carefully till it's not shiny. (1 day yo) and you'll be fine.
New tires stick like glue once they're warm. |
September 11th, 2012, 09:20 PM | #3 |
I UPGRADED to a YZF-R6 Mods: Shermoto LF7 Levers / Proton Flushmounts / Puig Smoked DB / Woodcraft Sliders / Tech Spec C3 Tank Grips / Rizoma Grips / Jardine |
September 11th, 2012, 09:21 PM | #4 |
...and you felt the need to quote me why?
September 11th, 2012, 09:53 PM | #5 |
Join Date: Jan 2012 Motorcycle(s): Ninja 250r - Track whore, Ninja 300 - SOLD, KTM RC390 - Orange Hulk, Ducati 899 Panigale - Red Devil. Posts: A lot.
Coz he wubs you...
September 11th, 2012, 10:14 PM | #6 |
Join Date: May 2010 Motorcycle(s): Current: '11 ZX-6R; Previous: '09 Ninjette; '08 ZX-6R (Ex-Wife '09 TU250X) Posts: 981
My tires were fine within 30-40 miles with no issues whatsoever.
Like you said, a good chunk of the tire is scrubbed in quickly simply from riding. Just don't toss it in too fast to begin with and I recommend you take it down a road you can ride with your eyes closed a couple of times. Increase the lean angle and done.
R.I.P EthioKnight (Alex) |
September 11th, 2012, 10:16 PM | #7 |
MOTM - Apr '13
Sounds good, I'm having new tires put on thursday and then going on a 220mi group ride saturday. Just want to make sure I got all the traction I need to drag cupholder
September 11th, 2012, 10:19 PM | #8 |
The A Team
Join Date: Aug 2012 Motorcycle(s): Z50, CB125, RZ500, MC22, R3. Posts: 394
2 laps and the nipples are gone, its up to temp and good to go.
Enjoy that new rubber while its in its prime. |
September 11th, 2012, 10:36 PM | #9 |
Done here.
myth. doesnt apply to modern tires. fresh / brand spankin new tires, when warmed up to the correct temp and set up with optimal psi, has just as much (infact even more) grip than "scrubbed in" tires.
weaving in pit lane like a retard is another myth. if u wanna warm up your tires, accelerate smooth but hard and then heavy break on a straight line. then take 2 somewhat easy laps. then blast away! |
September 11th, 2012, 10:39 PM | #10 |
MOTM - Apr '13
This is for the street not the track everybody! Thanks though!
September 11th, 2012, 10:50 PM | #11 |
crash 250, get supersport
Join Date: Apr 2010 Motorcycle(s): 2010 250R SE (Sold 6/9/14), 2009 ZX-6R (Sold 6/25/14), Subaru BRZ Posts: A lot.
What are ze new tires?
September 11th, 2012, 10:52 PM | #12 |
MOTM - Apr '13
Diablos
September 11th, 2012, 10:54 PM | #13 |
Hot diggity winsauce.
September 11th, 2012, 11:16 PM | #14 |
I hate driving...
Join Date: Jul 2010 Motorcycle(s): 13 Triumph Street Triple R, 09 Ninja 250r (Sold 4/20/12) Posts: A lot.
Honestly I felt pretty comfortable with those tires after just 15-20 miles. I went straight to the track after that though, a warm up lap or two, and bam time to set records. At first I was trying to slowly increase my lean but then I just said f it after the tires were warmed up and went at it and they stuck real well.
09 ninja 2fiddy SE Driving slow things fast |
September 11th, 2012, 11:17 PM | #15 |
MOTM - Apr '13
Well, I suppose slippery diablos are still better than IRC's
September 11th, 2012, 11:24 PM | #16 |
Done here.
What I said applies for street too.
Infact street tires warm up faster so you're all good. Just do the accelerate and brake hard thingy and you should be set to go. The scrubbing in myth comes from the old days when tires weren't molded perfectly and had small holes / imperfections in them. They used to spray these tires to fill up those holes with a material that was slippery. You had to scrub off this material before tires were considered safe. Now they apply the spray only on the sidewalls so that the brand name and specs are all nice and legible. They don't do it on the actual surface. I wish I could find the link to this article I read. I'm pretty much passing along the exact same info. It's a great read. |
September 11th, 2012, 11:24 PM | #17 |
Done here.
September 11th, 2012, 11:26 PM | #18 |
Join Date: Aug 2012 Motorcycle(s): 2012 Ninja 250R Posts: 27
Ok i work in the tyre industry and have have quite a bit of experience in tyre production.... Tyre moulds have teflon on them to help the mould and tyre separate. Its common knowledge that they retain some of the coating before you scrub it off.
It wont take long as its only the surface but YES you shouldnt trust BRAND NEW tyres to grip as much as scrubbed tyres.. Oh dont forget they need to be heat cycled sevearal times too
Carpe Diem, then the throttle |
September 11th, 2012, 11:51 PM | #19 |
Done here.
guess you dont work at pirelli then.
let us know who u work for so i can avoid that brand awww jk but yeah "tire industry" care to share which brand? |
September 12th, 2012, 12:27 AM | #20 |
Ive read the pirelli report and several others plus ive contacted bridgestone and dunlop, They all tell me that tyre heat cycling is important for the tyre to grip consistently.
Not to mention they still SPRAY the sidewall of tyres with release compound which is VERY slippery. It would only take a little oversprayto break traction if you start layin a tyre over straight from new. See http://www.tyre-technology.com/index.php/heat-cycling
September 12th, 2012, 12:39 AM | #21 |
MOTM - Apr '13
100 miles on new tires?
September 12th, 2012, 12:48 AM | #22 | |
Done here.
You read what I posted first |
September 12th, 2012, 12:48 AM | #23 |
Done here.
Jigglet (can i call u that?)
I love you for posting that. lol |
September 12th, 2012, 12:53 AM | #24 |
Heat cycles requires heating and cooling several times, read the article. Theres no point arguin with someone who cannot take advice nor see if someone else is correct. Carry on o mighty gurklord with your almighty article you posted vs my 15 yrs expreience in this industy
PS You do know what Overspray is dont you??
September 12th, 2012, 01:25 AM | #25 |
MOTM - Apr '13
You can call me whatever you want
September 12th, 2012, 01:32 AM | #26 | |
Done here.
The info is coming from "Cristoph Knoche, the Racing Manager for Pirelli Tire North America's Motorcycle Division" I mean jesus christ... It's not you vs me. It's you who worked "15 yrs in tire industry" (pretty vague. I still don't know who you actually worked for or what kind of tires you made). VERSUS GOD DAMN RACING MANAGER FOR PIRELLI. Anyway... I've done my part here And I'll take gurklord thank you. lol beats "gurk off" |
September 12th, 2012, 01:40 AM | #27 |
MOTM - Apr '13
I like gurked chicken
September 12th, 2012, 02:42 AM | #28 |
The A Team
Listen to choneofakind, once you've roughened the surface of the new tyre and got it up to temperature its good to go, that can happen in a couple of corners regardless of whether its on a country road, track or where ever.
If your riding is good, body postion is good then start comparing tyres. have seen alot of noobs say how **** the IRC's are... I wonder how hard they really pushed them? I did a few thousand km of road trips then 4 track days on them and yeah they were nothing compared to the 003's I run, but always knew when they were getting loose as they had alot more feel than super sticky ones. End of the day your riding style is about a billion times more more important untill you get to a level where you are really melting them off and pushing to limits that 99% of 250 riders bever get to. |
September 12th, 2012, 05:05 AM | #29 |
Join Date: Aug 2012 Motorcycle(s): Silver 2005 Ninja 250 - Available for free mustache rides. Posts: 842
I was just asking about (also getting new tires on Thurs), so I actually know stuff now!:
Back in the day the used to use an oil-based thing (I'm really good with the technical) to get the tires out of the mold. Now they use Teflon. Teflon rubs off exponentially faster, so it's takes a lot less time than it used to to get the slippery to go away. |
September 12th, 2012, 05:29 AM | #30 |
When I get a new set of Q2's for street next season my tire guy is gunna slap em on, then look at me and say "go fast and take chances". What does your's say?
September 12th, 2012, 07:25 AM | #31 |
Wartown, USA
Join Date: Nov 2009 Motorcycle(s): 2009 Ninja 250R SE, 2007 Ninja 650R, and assorted other bikes Posts: A lot.
September 12th, 2012, 07:32 AM | #32 |
Something like this maybe, hahahaha
September 12th, 2012, 10:49 AM | #33 |
MOTM - Apr '13
@Aufitt the ircs are **** but I still rude the piss out of them
September 12th, 2012, 10:56 AM | #34 |
that video is incredible
September 12th, 2012, 04:02 PM | #35 |
Join Date: Dec 2011 Motorcycle(s): 2011 GIXXER 600 Posts: 381
when i picked up the ninja the dealer didnt say much and the tire looked dry... when i picked up the gixxer.. i had to watch videos and had everyone in the service and sales warnings me about the tires.. and the tire looks wet
but it was the show model on a tilted display.. i would guess they shined um.. almost ate it like the guy in the vid but i was able to upright and keep going it doesnt need 100 but a good few depended on the road
"You see it's not the blood you spill that gets you what you want. It's the blood you share, your family, your friendships, your community. These are the most valuable things a man could have." |
September 12th, 2012, 04:41 PM | #36 | |
seriously though. its not the tires that need conditioning. its the rider.
September 12th, 2012, 04:44 PM | #37 |
MOTM - Apr '13
I remember reading someones post when I was new about how they got new tires put on and went to leave the dealership and their back wheel promptly slipped out from under them as they were leaving the driveway.
Been scared of new tires ever since
September 12th, 2012, 04:51 PM | #38 | |
so if you go and try to do a wheelie on FOB tires you will probably do a burnout, and if you do a burnout when you are expecting a wheelie and dont really know how to do a burnout, chances are you're gonna crash and then blame the tires how they were covered in slick crap... but really its your own fault for not understanding how rubber works. besides it only takes one slide on the part of the tire to expose fresh rubber. so if you know how to not drop it like a squid you'll be fine after a lap around the lot.
September 12th, 2012, 04:53 PM | #39 |
Lays er down
Join Date: Apr 2012 Motorcycle(s): 2008 Lime green Ninja 250R Posts: A lot.
so do a burnout to scrub new tires?
September 12th, 2012, 04:53 PM | #40 |
MOTM - Apr '13
Good to know, I'll warm em up hit some easy twisties and then prepare for my ridiculously long group ride
Not putting this bike back together. | Alex | Videos | 37 | July 11th, 2015 03:58 AM |
Should I grease forks before putting them on? | Insane Pie | 2008 - 2012 Ninja 250R Tech Talk | 10 | May 10th, 2014 07:22 AM |
Putting Ninja on Trailer | userjh160 | General Motorcycling Discussion | 13 | July 31st, 2012 07:19 PM |
The NT after 100mi. | Sailariel | The Ex-Ninjetters Lair | 25 | December 1st, 2010 06:40 PM |
