Old June 3rd, 2013, 08:47 PM   #1
kawasaki-guy2008
kawasaki-guy2008's Avatar
Motorcycle(s): 2010 Kawasaki Ninja 250r
Turn signal problem
I have a 2010 ninja 250r that I bought used. I am the second owner. The original owner replaced the old signal lights with led's. the lights don't blink properly or won't blink at all. I disconnected the front lights and now the rear ones work perfect. Now I know a little about electrics but aren't quite sure what the problem really is. My inspection is about due so I have to fix this. If anyone knows how to fix this please let me know.
Thanks
kawasaki-guy2008 is offline   Reply With Quote
Old June 3rd, 2013, 08:52 PM   #2
NevadaWolf
Certified looney toon
NevadaWolf's Avatar
MOTM Jul '13, Jul '14
Are all four LEDs? They may not be pulling enough power to trip the stock flasher. You may need an electronic flasher and some relays.
If you skim through the "Similar Threads" at the bottom of this page, you might find better instructions on how to fix it.
<-- Linky
Old June 3rd, 2013, 09:01 PM   #3
kawasaki-guy2008
Yes, they are all LED.
Old June 4th, 2013, 08:23 AM   #4
NevadaWolf
NevadaWolf's Avatar
This might help you out. @CThunder-blue has a lot of LED lights for our bike on his site and is a massive help for making sure they are installed correctly. You may be able to extract some info from his posts to fix your problem.
http://www.ninjette.org/forums/showthread.php?t=79621
<-- Linky
Old June 4th, 2013, 09:07 AM   #5
CThunder-blue
ModMy250.com
CThunder-blue's Avatar
It does sound like you need a new/better relay. Not sure if a diode kit has been installed, but you will want to install one too.
The www.ModMy250.com guy
Turn Signal indicator problem! Kevin2109 2008 - 2012 Ninja 250R Tech Talk 12 March 22nd, 2014 09:17 PM
Turn signal problem ChickenRun 2008 - 2012 Ninja 250R Tech Talk 11 June 9th, 2013 05:44 PM
Turn signal problem PistolPete93 2008 - 2012 Ninja 250R Tech Talk 19 July 17th, 2012 10:54 AM
Turn Signal Problem shawn57187 2008 - 2012 Ninja 250R Tech Talk 3 June 17th, 2011 02:13 PM
Turn signal problem!!! danjaho 2008 - 2012 Ninja 250R Tech Talk 1 March 23rd, 2011 07:25 AM
