Old August 23rd, 2020, 09:06 PM   #1
arthury
arthury's Avatar
Motorcycle(s): 2008 Ninja EX250J; 2005 CBR1000RR
Boiled my rear brake fluids: practicing Gymkhana moves
I was pushing the rear brakes quite a bit practicing Moto Gymkhana figure-8 moves and I think I boiled the brake fluid. All of a sudden the rear brake pedal went down to the floor when I depressed it.
Stopped, investigated and I could not see anything wrong with it. So, I decided to head home with only the front brake in my 5 min journey. While I was heading back the rear brake slowly returned to normal.
When I got back, I flushed the rear brakes totally. I'll resume practice tomorrow and see what happens.
2 Wheelers: 2008 Ninja 250R; 2005 CBR1000RR
4 Wheelers: 2018 M3; 2015 M235xi
arthury is offline   Reply With Quote
Old August 23rd, 2020, 11:17 PM   #2
SteveL
old git
SteveL's Avatar
Motorcycle(s): BMW K1300S
You must have had air in the system for it to do that.
Steve
Some mistakes are too much fun to make only once.
SteveL is offline   Reply With Quote
Old August 24th, 2020, 07:27 AM   #3
You sound concerned...
If you are using the rear brake enough to overheat it, you may want to start working more with the front brake.
It's the business-end when it comes to braking.
I use the rear only for slow speed maneuvering and low traction conditions.
With good tires in good conditions, and proper technique, the front brake should unload the rear enough that the tire's contact is minimal - and so is it's braking ability.
Old August 24th, 2020, 07:55 AM   #4
arthury
arthury's Avatar
In Moto Gymkhana, the key to success is to make sharp turns at as high a speed you can possibly get away with because you are timed. The bike spends most of its time in 2nd gear.
I am not an advanced Gymkhana practitioner yet. So, I'm not at the stage where my skills are good enough to manage an ultra-compressed fork in a turn. Thus, my use of rear brakes for beginners, learning self-steering at speeds in tight corners.
Anyway, the issue is moot, now that the brake fluids were refreshed. No issues this morning with fresh EBC fluids.
Old August 24th, 2020, 08:17 AM   #5
Good for you with practice! But be careful about developing bad habits that may be difficult to break later. Don't worry too much about speed on straights. Practice adjusting speed with throttle only and faster tip-in on corners. Similar to "the pace" on mountain rides, you want to set up a rhythm that doesn't upset chassis too much.
Old August 24th, 2020, 08:23 AM   #6
That's a cool video.
Old August 24th, 2020, 08:32 AM   #7
arthury
arthury's Avatar
Good vid.
Yes, no pressure on the handle-bars. Just lean and the bike will steer itself.
Let go brake half-way through turn and the bike will wake up from leaning automatically.
Old August 24th, 2020, 10:27 AM   #8
I get Gymkhana, but dropping the front-end with front braking is going to help you get around a tight corner quicker.
This is a classic motorcycle Gymkhana video -
He has his finger on the front brake lever the entire time, and looks to be applying it smoothly when entering a turn where braking is required.
Old August 24th, 2020, 01:59 PM   #9
What's that lifting of upper-body for when he's entering corners?
I noticed he's got more upright (and narrow) bars for more leverage and taking weight off hands.
Old August 24th, 2020, 05:10 PM   #10
arthury
arthury's Avatar
Shifting weight to rear wheels to boost contact patch and short burst acceleration.
Old August 24th, 2020, 05:14 PM   #11
arthury
arthury's Avatar
Yes, this is the famous advanced competitor with his CBR600.
It's easy to crash doing heaving pushing on front brakes into a corner; albeit, if you do it right, it's very effective. It's usually done in a smooth action: applying during pre-turn entry and letting go upon entry, followed by releasing rear brakes halfway in the turn.
I'm not there yet ... I'm a newbie to Gymkhana.
Old August 24th, 2020, 05:18 PM   #12
arthury
arthury's Avatar
Here's a more recent one using a liter bike and taller handle-bars.
https://www.youtube.com/watch?v=uaty...&index=13&t=0s
Old August 24th, 2020, 05:21 PM   #13
arthury
arthury's Avatar
This is the crazy French guy that started the ball rolling for me ...
https://www.youtube.com/channel/UCJh...0lCehzALrzF46Q
Kintaro has a whole series on becoming one with the bike rather than fighting the bike.
Old August 24th, 2020, 09:24 PM   #14
Sure, you can do that after apex of turn and coming out. But he’s doing it before going into turn.
Old August 25th, 2020, 05:17 AM   #15
arthury
arthury's Avatar
That's what I've been saying... there's an acceleration before the curve entry point, followed by applying front + rear brakes, leaning, releasing front brakes just before entry point.
Old August 25th, 2020, 07:54 AM   #16
I downloaded Jay's video and watched it in slow-mo. On acceleration sections, he's leaning forward and down to keep from wheelying. Then, he's definitely yanking up at end of straight after all acceleration has already been done. He's yanking up after braking and before diving in and turning. Maybe that's a forceful countersteering effort to make bike dive into turn.
Old August 25th, 2020, 08:13 AM   #17
Respect to those who possess the predisposition to make bikes turn like that at slower speeds.
I can't get my bike to turn that sharp in the garage while pushing it. lol
Old August 25th, 2020, 10:20 AM   #18
arthury
arthury's Avatar
There should not be counter-steering. If one is applying pressure on the handle-bars, one has missed the spirit of Moto Gymkhana.
Old August 25th, 2020, 12:04 PM   #19
Huh? How do you believe the bike is flipping from one side to the other that quickly?
Old August 25th, 2020, 06:52 PM   #20
Honestly, I'm surprised the fast guys are using such large cycles.
Since there's no significant amount of speed, and minimal acceleration area, a small light cycle seems like it would be an advantage.
How does the rear brake pad rattle clip go in place on my rear brake for 1987-2007? Wanderer 1986 - 2007 Ninja 250R Tech Talk 14 May 8th, 2017 11:26 AM
Rear Brake Lever Travel is Excessive and Rear Brake won't Lock Tire. N-m 1986 - 2007 Ninja 250R Tech Talk 14 July 17th, 2014 04:13 AM
[roadracingworld.com] - Lucas Oil Companyâ??s DOT 3 and DOT 4 Brake Fluids Ninjette Newsbot Motorcycling News 0 May 5th, 2013 08:40 PM
Fluids Xsavior 2008 - 2012 Ninja 250R Tech Talk 5 November 13th, 2012 06:21 PM
