Old April 28th, 2017, 03:42 PM   #1
skip
skip's Avatar
Motorcycle(s): 2009 250r
revs lag coming back down
Anyone know why and no air leak and carb is clean set to 2.5 turns
skip is offline   Reply With Quote
Old April 28th, 2017, 04:46 PM   #2
One of those is not true...
Old April 28th, 2017, 05:13 PM   #3
skip
skip's Avatar
Oh my boy it's true
Old April 28th, 2017, 06:56 PM   #4
Lazarus
Lazarus's Avatar
Motorcycle(s): 2008 Ninja 250
Then you wouldn't have rev lag....but you do....
Lazarus is offline   Reply With Quote
Old April 28th, 2017, 07:30 PM   #5
skip
skip's Avatar
Quick lesson in mechanics 101 ::: out of sync carbs, valve adjustment off, throttle cable lube and adjustment, lean lean ohh so mean free of charge
Old April 29th, 2017, 02:10 AM   #6
Lazarus
Lazarus's Avatar
A lesson is supposed to teach something? You just named a bunch of potential solutions to your problem.
Old April 29th, 2017, 03:33 AM   #7
skip
skip's Avatar
Lesson learned .
Old April 29th, 2017, 04:08 AM   #8
Mohawk
Mohawk's Avatar
Motorcycle(s): ZZR250, VFR800
I had a second hand bike that did that. Turned out that the previous owner had fitted on carb needle above the holder so the needle took a while to settle back as it was inside the spring !!! But either way you have excess fuel or air.
Old April 29th, 2017, 11:30 AM   #9
ducatiman
ducatiman's Avatar
^ surprised it even started
Another issue, leaking decel valve vac hoses....either at the valve (upper) or between the carbs (lower) If original, sometimes harden, swell and leak vac when hot. If they are simply present...most folks check them off as "ok".
I've found otherwise....what I describe is fairly common.
Try and pull them off the valve...that'll quickly, easily reveal whether loose.
My personal preference.....I want any/all vac hoses to be *tight*.....no leaky.
gordon@customcarbservices.com
Custom Carb Service
www.customcarbservices.com
[motogp.com] - Baz: “I’m really happy about coming back” Ninjette Newsbot Motorcycling News 0 July 12th, 2016 02:23 AM
thinking of coming back to the ninjette's mike12 2013 - 2017 Ninja 300 General Discussion 46 July 22nd, 2013 05:49 PM
Track Rider Coming Back to the 250 Knolly New Members 10 April 28th, 2013 08:42 PM
F1 back in the US, and coming to.....Austin, TX camaroz1985 Off-Topic 10 November 23rd, 2011 08:10 AM
[roadracingworld.com] - Repsol Honda Team Looking To Bounce Back At Mazda Raceway Lag Ninjette Newsbot Motorcycling News 0 June 30th, 2009 06:50 AM
