December 3rd, 2016, 09:46 PM | #1 |
Physics question
Hey here's an interesting question. Not sure if anyone can answer it or not, but here we go.
Approximately how much downward force is applied to the surface of the tarmac through the front tire contact patch when braking hard in a straight line? I'm sure there is a formula for calculating this and to most people it probably seems like trivial information but I'd still like to know. Suppose a bike weighs 375lb, with a 150lb rider -- that would be 525lb riding on the front and rear tire contact patch if the bike was travelling in a straight line. If the rider was accelerating, more of the weight would be on the rear tire. If the rider was braking very hard with the front brake, all of the weight would shift onto the front tire and the rear would come up off the ground. That would mean 525lb on the front tire contact patch alone, which would be roughly 18in^3 or 18sq inches. However, that still wouldn't account for the fact that the bike was in motion -- and actively slowing down (from 80mph to 25mph for example) which would exponentially increase the amount of downward force applied to the tarmac. Is anyone handy with physics formulas? As with everything there are numerous variables involved like tire pressure which would affect the size of the front tire contact patch area, bike and rider weight, and speed the bike was travelling and decelerating from/to etc.. Anyone?
Just batshit crazy. All his posts are endless diatribes. Some are actually entertaining but mostly batshit crazy. |
December 3rd, 2016, 09:50 PM | #2 |
For the sake of discussion, let's assume that the bike had sticky race tires and the coefficient of friction was high enough between tire/track that the rider could routinely brake hard enough before a corner entry to lift the rear wheel off the surface of the track while travelling in a straight line before entering the corner and turning the bike.
December 3rd, 2016, 10:11 PM | #3 |
The downward force cannot exceed the combined weight of the motorcycle and the rider. Braking applies force to the road in the direction of the motorcycle's travel. Having a high coefficient of friction makes it possible to apply very high forces, but they will still be in the direction of travel.
As a check, the force applied by the motorcycle downward on the road must equal the force the road applied upward to the motorcycle, but the directions are opposite. If this force were to be greater than the weight of the motorcycle and rider, the motorcycle would have to accelerate upward, but if this were to happen, the tire would lose contact with the road! |
4 out of 4 members found this post helpful. |
December 4th, 2016, 11:38 AM | #4 |
Join Date: Jun 2013 Motorcycle(s): 2010 Ninja 250 Posts: 596
https://theses.lib.vt.edu/theses/ava.../CHAP3_DOC.pdf
You're asking for a dynamic number that is suited for excel/matlab. A rough limiting number will be (friction coefficient) x (ground reaction force). On ideal tires and dry asphalt, your downforce won't exceed about 0.8 x combined weight of rider and bike. This is a very very rough number that changes w/ the changes in suspension geometry and a whole load of other stuff. |
December 4th, 2016, 11:44 AM | #5 | ||
Deceleration is that rate of change respect to time and it is translated into force when combined with the total mass of bike, fluids and rider. Quote:
http://www.dinamoto.it/dinamoto/index_eng.html https://en.wikipedia.org/wiki/Equations_of_motion In order to simplify the problem that you are questioning, forget all the parts of the bike, suspension, etc. You have a spatially located center of mass, two points of support against the tarmac and the vectors related to gravity and deceleration. Tire pressure has only a small influence on the rate of deformation of the front contact patch, and subsequent gripping, as the area can only grow a little more than what it is when there is no braking.
December 4th, 2016, 12:20 PM | #6 | |
(vehicle weight)(0.8) so if the combined weight is 500 lbs, in this case the maximum stopping force would be 500lbs x 0.8 = 400lbs, applied horizontally to the road, not downward. The downforce is simply the combined vehicle and rider weight. |
December 4th, 2016, 08:03 PM | #7 |
Wow this is way over my head! I love science though so I find it very interesting.
December 4th, 2016, 09:40 PM | #8 |
n00bie to wannabie
Join Date: Sep 2015 Motorcycle(s): 2012 250R (Red), 2005 VFR800A (Red), CRF450X (Red), 2012 F800GS (Wants to be Red!) Posts: A lot.
MOTM - Nov '15
Damn it Jim! I'm a Doctor, not a bricklayer!!!
The Smart Money: #1 - ATGATT, #2 - Training (machine skills and survival skills), #3 - The bike; whatever floats yer boat with the money you have left over |
December 4th, 2016, 10:29 PM | #9 |
Perhaps I was mistaken but I was under the impression that the downforce applied to the track would actually exceed the weight of the vehicle/driver.
Now that I think about it -- it seems understandable that the total downforce of the vehicle would not exceed the weight of that vehicle. Gravity only works in one direction. I understand that equal upward force would be applied in proportion to downward force otherwise the earth would move or the road would collapse. Anyways, interesting stuff. Thanks for the replies. I'll come back to this thread.
December 5th, 2016, 05:43 AM | #10 |
Join Date: Dec 2013 Motorcycle(s): Ducati 999 2012 Ninja 250r Ducati748 Yellow finally running 2003 SV650 S (SOLD) Posts: A lot.
Please correct me if im wrong but there would have to be more weight pushed down into the track than the weight of the bike and rider. The energy from the forward momentum would be focused down as the vehicle decelerates and therefore would be over 1G. Bikes can accelerate at approx. .8G but they stop faster than they go (Some models at least).
They claim 1.6G in Moto GP. I know they are not "regular" bikes but I think the same principals apply. I tried to copy the link but it would not work. Just Google "Max stopping G forces on a motorcycle. 1.6G would = 1.6X vehicle weight-----now I am not sure how much of that is directly applied to the track. |
December 5th, 2016, 08:22 AM | #11 | |
Maybe there's confusion about what you mean by "pushed down into the track". The force straight down can't exceed the bike+rider weight, but the total force of weight plus braking will exceed the weight. In your example of 1.6 for the coefficient of friction, if you assume the combined weight is 500 lbs, the motorcycle will apply 500 lbs directly downward, and 1.6x500=800 lbs in the forward direction. These forces can be combined into a singe vector with Sum of forces = √ (500˛ + 800˛) = 943 Angle = arctan (500/800) = 32 degrees So the result can be thought of as a single force of 943 lbs, applied to the road at an angle of 32 degrees down from the forward (horizontal) direction. |
December 5th, 2016, 09:53 AM | #12 |
Join Date: Jun 2012 Motorcycle(s): 2013 Ninja 300 Posts: 718
I really wanted to chip in on this thread, but Jim has nailed.
DISCLAIMER: I generally have no idea what I'm talking about. |
December 5th, 2016, 06:01 PM | #13 |
Since all the science-y answers have already been given, I'll just leave this here....
How much force? All of it.
December 6th, 2016, 10:33 AM | #14 |
n00bie to wannabie
MOTM - Nov '15
Curious: how can you have a coefficient of friction greater than 1? Isn't 1=100%? If there is100% friction; there is no slip/maximum grip which is maximum force which would equal and be a product of the size of contact patch and coefficient of friction between the two materials (in this case: rubber and road surface).
December 6th, 2016, 11:07 AM | #15 |
A coefficient greater than one simply means that the force require to cause slipping between the surfaces is greater than the force "creating" that friction (in this case, the weight of the bike and rider). It's not an unusual thing to come across.
December 18th, 2016, 10:11 AM | #16 | |
What I didn't seem to understand in the initial post is law of motion etc.. every action/equal opposite reaction. Gravity is a constant, and the angle of force would change dependent on rate and direction of deceleration. For some reason I was thinking that during maximum braking, a vehicle would actually exert more than it's own weight in downward force against the surface on which it was travelling. After the matlab examples, I see that is absolutely not the case. The reason I made this thread is to gain a better understanding of roadway and track construction. All race tracks show their first surface imperfections on the most common entry lines into turns. Now I understand that it is because each and every vehicle braking before entering the turn (if braking to the maximum capability of the vehicle) is exerting close to it's own weight on the surface of the track in an area as small as the front tire contact patch.
December 18th, 2016, 11:58 AM | #17 |
Not to mention the large braking force on the track in the direction of travel, which is probably worse than the down force, since it tends to tear the track surface.
December 18th, 2016, 01:34 PM | #18 |
vampire
Join Date: Feb 2011 Motorcycle(s): 2 many 2 list Posts: A lot.
The contact patch of the tire could constantly changing, difficult to determine a specific number for the forces acting on all aspects of the bike slowing down... negating air resistance, possibility of lift effects from rider's aerodynamics at particular speed of travel, among other forces that are constantly acting on the bike/rider as a whole..
Personally, in real world operations, I use the brake as little as possible; they only slow you down and limit your options for escape route. |
December 18th, 2016, 08:44 PM | #19 |
Participant
Join Date: Oct 2012 Motorcycle(s): '94 K75 std Posts: Too much.
Friction and traction are not the same thing.
December 19th, 2016, 06:07 AM | #20 |
dirty boy
MOTM - Apr '14
.... a duck.
December 19th, 2016, 07:38 AM | #21 |
So... if the bike and rider weigh the same as a duck...?
December 19th, 2016, 08:47 AM | #22 |
Yup, you have a witch!
December 19th, 2016, 04:13 PM | #23 |
December 19th, 2016, 11:39 PM | #24 | ||
December 20th, 2016, 02:24 PM | #25 |
What in your opinion are the rest of the fractions that complete available traction?
December 20th, 2016, 02:31 PM | #26 |
n00bie to wannabie
MOTM - Nov '15
Fear!
December 21st, 2016, 07:52 AM | #27 |
Friction is the only force providing traction. Without friction, the tire would simply slide across the pavement.
December 21st, 2016, 04:30 PM | #28 |
Let's also not forget that the convention for vehicle mathz says that "traction" is the force used to make the vehicle move; i.e. Tractive forces are the forces that propel the vehicle. "Traction" does not refer to cornering or braking.
For example, when you calculate a vehicle's maximum possible rate of acceleration, you look at two cases; case one assumes the vehicle is power limited and traction is never an issue, while case two assumes the vehicle is traction limited and power is never an issue. Which ever rate of acceleration is greater is the max theoretical rate of acceleration. Seriously, there's some great books written on car physics. I know that we're talking motorcycles instead of cars, but many of the basic concepts are the same. Some of y'all need some help... Try Fundamentals of Vehicle Dynamics by Thomas D Gillespie. It's from the 90's and the example problems are horribly dated, but the concepts never change and it's written out so that it's very easy to follow. To answer Hernan's question: the forces at the tires are generally broken into 3 types of forces. Tractive forces, cornering forces, and braking forces. That's it. The sum of any of these can be equal to or less than the maximum possible friction, which is F=mu*N, where N is the normal force on that tire contact patch and mu is the coefficient of friction between the tire and that road surface. Please note that N changes due to aero effects, as well as weight transfer during cornering, braking, acceleration, etc. This is easily calculated for steady state conditions, but is much more difficult during transitions. |
December 21st, 2016, 04:46 PM | #30 |
Milliken is the man. He's really the go-to expert whenever vehicle dynamics are in question.
However, have you read through his books??? They're about racecar dynamics and F1 and very high level, specific cases. For the basic needs of the nerds here, Gillespie is more than sufficient for answering questions and grasping concepts. Milliken is an amazing 2nd step once you've got the basics. The brutally detailed world of motor sport engineering is not needed for the basic conceptual work here. Gillespie's book is so well laid out and easy to follow. We have people here who don't even know what a free body diagram is or why it is needed. |
December 24th, 2016, 09:26 PM | #31 |
If anyone would like to read those books, they can contact me.
Haven't had the time to read them yet but I've got 'fundamentals of vehicle dynamics' and 'race car dynamics' on the kindle now. Along with a whole bunch two stroke engine theory books which are quite interesting. Anyways this thread has been very informative and interesting. I spend a lot of time behind the wheel of a f350 crew cab with a fully loaded bumper pull trailer attached to it. I weighed a typical load once and I'm in the ballpark of 20k pounds on eight tires when driving that rig. The nice thing about understanding physics is that the knowledge is directly transferable to all other aspects of life. Also in the process of buying another motorcycle, but I don't want to jinx it so I won't spill the beans. I'll make a thread once I have it in my custody. Something truly wild. Thanks guys. I'm gonna re-read all of this again to make sure it all clicks.
December 25th, 2016, 12:20 AM | #32 |
The Violet Vixen
Join Date: Jun 2012 Motorcycle(s): Perigee (250), Hotaru (250), Saturn (300), Pearl (300), Zero (S1000RR), Chibi (Z125), Xellos ('18 HP4R) Posts: A lot.
MOTM - Jun '16
Heh, looks like the forum has this covered.
This kind of math is a huge part of my career as a game developer -- though my aim is feel over accuracy, so I frequently can approximate these things (though that comes up more when you start getting into calculus/PDEs, basic algebraic physics and trig is usually pretty close to reality in a reality-oriented simulation.
"most folks racing this bike get it in a competitive state of being with much less invested than you've already put in Saturn." - Alex |
December 25th, 2016, 02:09 AM | #33 |
MOTM - Jan '18, Sep '13
My Ninja 300 |
December 25th, 2016, 02:17 PM | #34 |
Corky, I think you'll like those books. Great way to get the basics and lots of application. Also do some reading into Bosch and their work with stability control/traction control. It's an interesting topic.
December 25th, 2016, 10:02 PM | #35 |
^ Any recommendations?
December 26th, 2016, 02:33 AM | #36 | |
Ooooh, books! Here are a few to look out for:
December 26th, 2016, 12:31 PM | #37 |
Yay, new stuff to read!
Spoiler for topic:
December 29th, 2016, 10:23 AM | #38 |
MOTM - Sep '14
Keep calm and ride on -Motofool Never quit on a rainy day -ally99 |
The Physics of Motocross | Motofool | Videos | 4 | May 7th, 2015 05:50 AM |
Physics at its best: tank slapper | Motofool | Videos | 15 | November 7th, 2013 06:46 PM |
The Physics of Countersteering | Motofool | Videos | 13 | September 8th, 2013 09:12 PM |
Only for Physics geeks | Motofool | Videos | 19 | March 8th, 2013 11:26 AM |
riding physics. | ADoMinGu3z | General Motorcycling Discussion | 29 | February 14th, 2013 08:54 AM |
