Old August 20th, 2017, 02:44 PM   #1
Tylorwashere
Motorcycle(s): 2005 Ninja 250
Takes forever to warm up
So I have an 05 ex 250, and once it warms up it runs perfect, however it takes forever to warm up to that point. I have to slowly work off the choke until it will stay running, then let it sit another minute or two until it starts idling at about 1500 rpms, then it will be good to go.
I've had the carbs out and done a pretty basic cleaning, but from what I've been reading it seems like the idle circuit might be clogged? But I feel like if that were the case it wouldn't idle even when warm.
If anyone has any insight it would be great, thanks
Tylorwashere is offline   Reply With Quote
Old August 20th, 2017, 05:30 PM   #2
ducatiman
ducatiman's Avatar
sounds like a good candidate for adjusting the pilot screws provided.....
A: the pilot circuits are, in fact, clear
B: the EPA tamper caps on the pilot screws have been removed
During your clean...did you remove the tamper caps then pilot screws/spring/tiny washer/tiny oring?
gordon@customcarbservices.com
Custom Carb Service
www.customcarbservices.com
Old August 20th, 2017, 07:03 PM   #3
Tylorwashere
The epa caps were removed (one screw was tight closed and the other 3 turns open, they are both at about 3 and a half turns out now). Everything was removed and cleaned with carb cleaner then blown out with compressed air.
Old August 20th, 2017, 08:01 PM   #4
MrAtom
MOTM - July '15
I just ride it gently around the block a few times. It warms right up.
Old August 20th, 2017, 08:06 PM   #5
Tylorwashere
Mine likes to stall when I stop if I do that
Old August 20th, 2017, 09:19 PM   #6
Ram Jet
Ram Jet's Avatar
I've got to believe it's your carbs. My bike gets 1/2 choke and the choke is off after two minutes of running and it idles at 1000 R.P.M. The other day my temperature gauge read 67 degrees when I started the bike, exactly 60 seconds later it read 130 degrees. After my first start of the day I never have to choke it again. Things might be different if it was 40 degrees out.
My bike warms-up quickly because I have modified my cooling system.
Bill
Old August 21st, 2017, 06:48 AM   #7
Correct idle mixture and idle speed settings should give you a ride-able bike in just a couple of minutes from starting cold.
Old August 21st, 2017, 08:14 AM   #8
ducatiman
ducatiman's Avatar
possible valve clearance issue? tight can undeniably cause weird starting/running issues. Need to eliminate.
Tylor...current mileage and mileage at last known valve clearance check?
Custom Carb Service
Old August 21st, 2017, 10:03 AM   #9
Tylorwashere
Current mileage 18.5k, last check unknown
Old August 21st, 2017, 01:34 PM   #10
ducatiman
ducatiman's Avatar
3.5 turns should deliver adequate mixture, preventing super lean long warmup.
At 18k with no known valve check...would be advisable to do. These 250's are especially sensitive to tight valves....I'm sure others will agree and chime in here.
Custom Carb Service
Old August 21st, 2017, 01:52 PM   #11
Lazarus
Lazarus's Avatar
Motorcycle(s): 2008 Ninja 250
Waited till 10k miles to even check my valves (I know, shame on meeeee) every one of them was out of spec. The exhaust valves were way tight and the intake valves were on their way over to being too tight as well. Had some minor hard starting issues and stalling every so often. She just loved to mess with me, adjusted the valves and she is a very happy girl.
Lazarus is offline   Reply With Quote
Old August 22nd, 2017, 12:52 AM   #12
Tylorwashere
Sounds like I have a weekend project now
Old August 22nd, 2017, 10:05 AM   #13
A.J.
A.J.'s Avatar
Motorcycle(s): 2001 Kawasaki Ninja 250r(SOLD) 2006 Kawasaki Ninja 250r full Muzzy(my pride and joy)
I think it might be nothing. These bikes are cold blooded. If it takes 3-5min to warm up I wouldn't go dismantling the carbs. JMO
Then again after I warm my bike up once she's warm the rest of the day and no choke needed. So if you aren't able to do that then what these guys are saying is probably necessary.
"A car or truck will get you from point A to B. But a motorcycle, that is the point." -unknown
A.J. is offline   Reply With Quote
Old August 22nd, 2017, 10:26 AM   #14
ducatiman
ducatiman's Avatar
at 18K (with no known history of valve adjustment) I'd consider a check mandatory...then reevaluate results from that point.
Custom Carb Service
[kropotkin thinks...] - 2015 Aragon Moto3 Warm Up Result: Kent Takes Charge Ninjette Newsbot Motorcycling News 0 September 27th, 2015 01:40 AM
[kropotkin thinks...] - 2015 Jerez Moto3 Warm Up Result: Kent Takes Charge Ninjette Newsbot Motorcycling News 0 May 3rd, 2015 12:41 AM
Michael Gone Forever? CC Cowboy Off-Topic 10 January 27th, 2014 05:43 PM
Takes forever to start surlistyc 1986 - 2007 Ninja 250R Tech Talk 14 October 13th, 2012 05:32 PM
[kropotkin thinks...] - 2011 Misano MotoGP Warm Up Result: Stoner Takes Charge Ninjette Newsbot Motorcycling News 0 September 4th, 2011 01:50 AM
