Old December 22nd, 2012, 08:03 PM   #2721
rojoracing53
Fast-Guy wannabe
rojoracing53's Avatar
MOTM - Jan '13
It's not finished appearance wise but it works and is safe to ride now I can go ride and find some food
R-6 wheel, Yamaha 310mm Rotor, and 2006 R-6 Radial mounted caliper.
Old December 22nd, 2012, 08:28 PM   #2722
lolibater
lolibater's Avatar
Motorcycle(s): 2005 ZX6R, 2011 Sprint GT
changed my first set of brakes. Scary how low they were.
"The enemy is fear. We think it is hate, but it is fear." - Gandhi
lolibater is offline   Reply With Quote
Old December 24th, 2012, 09:00 PM   #2723
NevadaWolf
Certified looney toon
NevadaWolf's Avatar
MOTM Jul '13, Jul '14
Got my new seat cowl in and tried an idea for darkening my ugly white gauge faces. I like the results!
<-- Linky
Old December 24th, 2012, 09:23 PM   #2724
Kstorm21
Kstorm21's Avatar
Motorcycle(s): 2009 Ninja 250R SE
It's hard to tell...what'd you do? I'm putting green LEDs in my dash. I had to order another one. For some reason I only ordered 2. You can see my picks a few post before this one.
Kstorm21 is offline   Reply With Quote
Old December 24th, 2012, 09:35 PM   #2725
NevadaWolf
NevadaWolf's Avatar
I overlaid a cut piece of black transparent plastic from a file folder onto the gauge itself, giving it a smoked look. From the tests in my garage, I can still see where the needle is pointing while under the garage lights and the backlight shows through nicely in the dark.
BTW I reassembled my fairing and looked in the area you show a gap. I don't have one there but it isn't perfectly flush either. There is a small ridge between the upper and lower fairings.
<-- Linky
Old December 24th, 2012, 09:55 PM   #2726
Kstorm21
Kstorm21's Avatar
Well, I couldn't fully take off the side fairings when I removed the front one. I have frame sliders on that use a ginormous hex screw that I don't have. When I get one I'll take it all off again and make sure to get it squared away properly. Oh, isn't there a special screw driver we're supposed to use? I can't remember what it's called. The large phillips head screw on the very bottom of the right fairing is about 2 seconds away from being striped. I need to get it off before I can't anymore.
Old December 24th, 2012, 10:09 PM   #2727
NevadaWolf
NevadaWolf's Avatar
The two Phillips head screws just use a standard #3 Phillips. Nothing special on those. (I know which one you are talking about as today I discovered I lost mine!).
<-- Linky
Old December 25th, 2012, 12:36 AM   #2728
Kstorm21
Kstorm21's Avatar
where are they? Do you know what kind of screw driver I need for it?
Old December 25th, 2012, 01:27 AM   #2729
rojoracing53
Fast-Guy wannabe
MOTM - Jan '13
swapped out the radial 19x20 brembo master cylinder for the OEM equipped brembo that come on the yamaha R-6 and R-1. I don't know what size piston is in the yamaha unit but it has to be smaller because I've gained back a bit of feel. still hoping to get my hands on a brembo 15RCS master to test out later.
Old December 25th, 2012, 01:39 AM   #2730
NevadaWolf
NevadaWolf's Avatar
I'll PM you so we don't derail this thread...
<-- Linky
Old December 25th, 2012, 09:54 AM   #2731
lolibater
lolibater's Avatar
I gave it a start to see how it would idle in the freezing cold and then gave it some sexy looks.
Put my new telescoping magnet thing in my tank bag.
Old December 25th, 2012, 04:29 PM   #2732
menikmati
crash 250, get supersport
Motorcycle(s): 2010 250R SE (Sold 6/9/14), 2009 ZX-6R (Sold 6/25/14), Subaru BRZ
Found that my clutch cable on my ZX6R was fraying, which explains why shifting felt different. Turns out that I can shift smoothly and do rev-match downshifts a lot better with a half-frayed cable, figures.
Installed a pair of Philips H7 X-treme Power headlight bulbs on the 250R, glad to have a functional high-beam flash now. Lubed the chain, needs a good cleaning before the next lube as I've been riding in the rain.
Last futzed with by menikmati; December 25th, 2012 at 05:37 PM.
menikmati is offline   Reply With Quote
Old December 25th, 2012, 07:13 PM   #2733
rc racer
rc racer's Avatar
Motorcycle(s): 2015 R3, 1969 CB160, 2002 TTR125, 2007 KX250F
Installed woodcraft rearsets yesterday. Plus took it for a spin around the apartment complex. Been sitting since the last track day.
rc racer is offline   Reply With Quote
Old December 25th, 2012, 08:50 PM   #2734
DreamN
Beer Me!
DreamN's Avatar
Motorcycle(s): '13 Ninja 300 Car(s): '09 Cube, '93 240SX (Coupe & 'Vert)
I filled her up and took her on our first canyon run. I live in the San Fernando Valley, so I decided to take it to a nearby canyon which I've driven many times and am quite comfortable on; Little Tujunga Canyon. About 18 miles of beautiful scenery and great turns. Such a great ride. Definitely still feel sketch with some of the turns, but I eventually found a good rhythm. Loved the fact of how empty it was.
DreamN is offline   Reply With Quote
Old December 26th, 2012, 06:51 PM   #2735
rojoracing53
Fast-Guy wannabe
MOTM - Jan '13
Have you ever been to AIP(All Industry Performance) it's a shop on Sherman way. Next time I stop by ill have to give that canyon a try.
Old December 26th, 2012, 06:58 PM   #2736
rojoracing53
Fast-Guy wannabe
MOTM - Jan '13
So I finally got the R-1 rotor I've been waiting for so I swapped the 310mm R-6 rotor for the 320mm R-1 rotor.
Old December 26th, 2012, 07:49 PM   #2737
lolibater
lolibater's Avatar
grande sized that rotor. NICEEEEEEEEEEEEEE.
Old December 26th, 2012, 08:00 PM   #2738
rojoracing53
Fast-Guy wannabe
MOTM - Jan '13
SUPER SIZE ME PLEASE
I laugh when I think this wheel and ginormous rotor are 1lb lighter then the stock ninjette
Old December 26th, 2012, 08:09 PM   #2739
lolibater
lolibater's Avatar
good ol ninjette
*pats gas tank*
Old December 26th, 2012, 08:20 PM   #2740
rojoracing53
Fast-Guy wannabe
MOTM - Jan '13
good ol ninjette
*pats gas tank*
Just remember that with all these mods to my brakes I'm just overpowering the my stock soft pogo stick front suspension even more. I so need to follow your example and add stiffer springs and emulators. Or like my old crew chief tells me "why don't you just go buy another R-6 and be done with it"
Old December 26th, 2012, 09:15 PM   #2741
lolibater
lolibater's Avatar
lol y u no R6?!
Yeah the .80 / 20wt / emulators are like night and day from stock. You even have the .6 or whatever, so you're closer. You won't regret it.
Old December 27th, 2012, 12:16 AM   #2742
DreamN
Beer Me!
DreamN's Avatar
New to the scene, so only shops/stores I know of are Cycle Gear and the few dealers in the Valley.
Definitely a fun little canyon. Once I get comfortable and upgrade the gear. I'll be taking a drive up to Lake Hughes Road. That's 30 miles of fun.
Old December 27th, 2012, 01:54 PM   #2743
Chicagobob
Chicagobob's Avatar
Motorcycle(s): '06 Ninja 250, 2018 Honda GL1800B
Moved the helmet lock, then took a 20-minute ride until it snowed
It was on the upper frame tube above the left exhaust bracket. Now it's just in front of the right rear turn signal. Only 26 degrees today, so a short ride.
Chicagobob is offline   Reply With Quote
Old December 27th, 2012, 01:59 PM   #2744
Nothing again.....
Old December 27th, 2012, 02:01 PM   #2745
rojoracing53
Fast-Guy wannabe
MOTM - Jan '13
When I was in SoCal for my last 50mile ultramarathon in April I got to ride that road out and back twice on the ninjette. I even got a chance to make a group of CBRs look like Newbs
Old December 27th, 2012, 02:05 PM   #2746
rojoracing53
Fast-Guy wannabe
MOTM - Jan '13
After getting slapped upside the head by a brilliant idea of how to lengthen my clutch cable the extra 3mm I was to short to get my CRG clutch lever and perch installed. I installed it while taking a lot of pics so keep an eye out for my DIY for lengthening a OEM clutch cable 5mm soon to come.
Old December 27th, 2012, 02:17 PM   #2747
What brake pads did you use? Did you bleed/replace the fluid as well?
I'm running Vesrah pads and DOT 5.1 and love the feel.
Old December 27th, 2012, 03:29 PM   #2748
lolibater
lolibater's Avatar
I didn't bleed/replace, as I did that during my SS lines upgrade. Here's what I went with:
Front: http://www.amazon.com/gp/product/B00...ls_o04_s00_i00
Back: http://www.amazon.com/gp/product/B00...ls_o05_s00_i01
Fluid is just run of the mill standard fluid; wtf that is.
Old December 30th, 2012, 05:00 PM   #2749
menikmati
Replaced the clutch cable on my ZX6R in about 20 minutes. Zip tied one end of the new cable to the old one and just pulled it through without having to remove the fairings. Went ahead and lubed the cable since it was accessible (probably overkill, but meh).
Checked the tire pressures on the 250R, something that I admit to not doing enough.
Old December 30th, 2012, 05:27 PM   #2750
Dozer
Dozer's Avatar
Motorcycle(s): 2010 EX250, 2012 ZX-6R
broke a bolt...
saw uniform corrosion on the exhaust can cover so i wanted to clean it, i think the bolts had loctite on them
broke one bolt off and the stem's still in the exhaust can...
maybe an excuse to get an aftermarket exhaust?
---> or just a screw extraction kit.
Dozer is offline   Reply With Quote
Old December 30th, 2012, 06:13 PM   #2751
Kstorm21
Kstorm21's Avatar
My danmoto was only $123(ish) shipped...great sound too!
Old December 31st, 2012, 10:10 AM   #2752
Joshorilla
Bass Master General
Joshorilla's Avatar
I reconditioned the leather on my jacket, gloves and boots, gave them all a good wash, scrub and brush with boot polish.
Washed the inner lining to my helmet and gave the visors a good clean.
Look after your gear and it'll look after you.
Old December 31st, 2012, 10:17 AM   #2753
I serviced my unitrak link and my swingarm
Old December 31st, 2012, 08:42 PM   #2754
rojoracing53
Fast-Guy wannabe
MOTM - Jan '13
I swapped out the original 195 stat that came with my thermo-bob for another 195stat bill sent me for testing. Removed my caliper bracket so it could trim it down to its final shape, and hide away my Koso speedo sensor. Then washed and polished the crap out of it for tomorrow's ride
Old January 2nd, 2013, 01:27 AM   #2755
g_salazar26
A girl named Roxy...
g_salazar26's Avatar
Motorcycle(s): Red 2012 Ninja 250R SE
Cold/Rainy ATX here... haven't been on in 2 weeks..... feel my life ending!
But I've added a Two Bro's exhaust, K&N, some T-Rex frame sliders in the past month. Got some new integrated turn signal mirrors, hopefully get them on tomorrow
g_salazar26 is offline   Reply With Quote
Old January 3rd, 2013, 10:26 AM   #2756
Joshorilla
Bass Master General
Joshorilla's Avatar
Didn't really think this warranted it's own thread, but I have been busy repairing the fenders, tacked the plastic in place with a hot screw driver, glued / filled with epoxy and for the deeper scratches I used Isopon P38 filler "like bondo" then sander with 60, 80, 120, 240 I believe.
The filler looks deeper than it is, the blind rub test shows no bumps, i'll prime it tomorrow or Saturday to show it in it's true colours, problem is I only get ten minutes usable light after finishing work so I don't get much time other than weekends for repairs.
It costs about £220 = $357 or £440 = $ 714 for the two after shipping for a new side fender here and their is no second hand market where I live, so it's a lot cheaper for me!
Old January 3rd, 2013, 11:17 AM   #2757
lolibater
lolibater's Avatar
fixed the fuel map and tested idle fluctuation
Old January 3rd, 2013, 11:40 AM   #2758
Sirref
Private Joker
Sirref's Avatar
MOTM - Mar '14
went out for a ride
~28-32 degrees out
spent 15-20 minutes in a parking lot working on my countersteering and braking
then the rest of it on a nice little 12 mile loop of the only back roads that i know how to get to without a highway near my home
came back an icecube and now i think i may have caught a cold
worth it though, needs to be spring already
Old January 3rd, 2013, 12:18 PM   #2759
Joshorilla
Bass Master General
Joshorilla's Avatar
Gave it a quick spray of an old can of primer to see how well it had fixed up and I am very pleased!
Take a look at my first picture attached a few posts up for comparison.
Old January 3rd, 2013, 02:41 PM   #2760
Old Guy on a '08
Chris
Old Guy on a '08's Avatar
Motorcycle(s): BLACK!!! '08 250R
Looking good!!! Let's see a lot of pics when your done!
Some roads are too good to waste on four wheels!
Riding in a car is like watching a movie...
Riding on a motorcycle is like being in one....
Old Guy on a '08 is offline   Reply With Quote
Discovered something scary about my Ninjette today... kjohng General Motorcycling Discussion 28 October 15th, 2021 01:40 PM
Sold the 2006 Ninjette today :( Renner General Motorcycling Discussion 31 October 16th, 2014 11:46 PM
Today I Gave My Ninjette Wings! BlueHairSar Pictures 5 June 20th, 2013 07:38 AM
my bro went down today on his ninjette richierich781 !%@*#$%!)@#&!%@ I crashed! 46 January 18th, 2013 11:59 AM
Ninjette. org hacked today CC Cowboy Off-Topic 9 April 3rd, 2011 08:55 AM
