Old August 20th, 2013, 05:39 PM   #1
n4mwd
n4mwd's Avatar
New Video: How to remove the carbs on a pregen
I finally got around to removing the carbs today and decided to record a video on how its done. I wasn't able to find a video on youtube that actually showed the correct procedure, so I made this video.
My Ninja Blog
Old August 20th, 2013, 06:08 PM   #2
Originally Posted by n4mwd View Post
.......I wasn't able to find a video on youtube that actually showed the correct procedure, so I made this video.
Thanks, D !!!
Old August 20th, 2013, 06:10 PM   #3
FvnnyL3tt3r1ng
FvnnyL3tt3r1ng's Avatar
Motorcycle(s): Ninja 250 2001
I recognize that bike!
Mods: Offset clutch pressure plate
Old August 20th, 2013, 06:51 PM   #4
n4mwd
n4mwd's Avatar
Yep, that's my bike. Seems like it takes me forever to work on them any more. I'm always having to do other things.
Anyhow, I got some 30R9 fuel hose which is supposed to be E85 resistant. So it should work for regular gas (E10). I haven't had a chance to actually clean it yet though.
My Ninja Blog
Old August 20th, 2013, 08:50 PM   #5
Just a note, always disconnect the + terminal first and reconnect it last to avoid sparking. You did it the other way around. Other than that, the video looks good.
Did that actually take you 6 minutes?
Old August 21st, 2013, 04:48 AM   #6
n4mwd
n4mwd's Avatar
Actually, the video is correct. Disconnect the neg first. If you accidentally short the neg to the frame while you are removing it, then nothing happens. If you start with the pos and accidentally short that to the frame, then sparks will fly and any gasoline drips may ignite.
Then reconnect backwards - pos first.
But since most people will be using a screwdriver, its pretty hard to short that to the frame. Its more of a factor when people use socket or crescent wrenches that can swing over and bang into the tank.
Yep, it was more like 10 minutes.
My Ninja Blog
Old August 21st, 2013, 05:07 AM   #7
Well done video! Thanks for your time and effort put into this.
Old August 21st, 2013, 06:16 AM   #8
agentbad
agentbad's Avatar
So I have pods and have been meaning to try this since my carbs have a really slow leak. I am hoping I just need a new gaskets on both sides.
Old August 21st, 2013, 07:40 AM   #9
A slow leak indicates faulty float valves.
Old August 21st, 2013, 07:44 AM   #10
agentbad
agentbad's Avatar
Really because it seems to run just fine but after riding for a bit I can run my hand under the carbs and feel/smell the gas. Any who great video.
Old August 21st, 2013, 12:55 PM   #11
n4mwd
n4mwd's Avatar
A slow leak could also indicate your petcock isn't shutting the gas off. Its the easiest to check. Just pull the hose off when its switched to ON with the bike off and see if it still comes out.
My Ninja Blog
Old August 21st, 2013, 01:47 PM   #12
7oxSin
MSF Coach!
7oxSin's Avatar
Motorcycle(s): 2003 ninja 250
awesome vid, it sounds like you did the original voice acting for Micrsoft Sam.
Hey Unregistered wanna ride the dragon? Ninjette group ride! May 16th-20th
Join the Ride!!http://www.ninjette.org/forums/group.php?groupid=35
7oxSin is offline   Reply With Quote
Old August 21st, 2013, 04:30 PM   #13
n4mwd
n4mwd's Avatar
I used a different microphone this time. Sounds a bit softer than the old one.
My Ninja Blog
Old August 21st, 2013, 08:08 PM   #14
deeno415
deeno415's Avatar
Motorcycle(s): 2006 Kawasaki EX250(Bright Yellow)
Most motorcycle problems are caused by the nut that connects the handlebars to the saddle. Sorry, I don't speak Spanish... I'm Filipino!
deeno415 is offline   Reply With Quote
How to remove the carbs cuong-nutz 2008 - 2012 Ninja 250R Tech Talk 1 July 1st, 2014 07:10 PM
Another way to remove the carbs.... Soujyu 2008 - 2012 Ninja 250R Tech Talk 6 August 26th, 2013 12:36 PM
remove and reinstall carbs - stock airbox red 2008 - 2012 Ninja 250R Tech Talk 22 July 16th, 2013 07:09 PM
Easiest way to remove carbs? chadh92 1986 - 2007 Ninja 250R Tech Talk 22 April 9th, 2013 06:59 PM
Howto: Remove carbs in under 10 mins [Video!] TheDuck 2008 - 2012 Ninja 250R Tech Talk 39 January 11th, 2013 10:04 AM
