April 27th, 2019, 07:00 PM | #1 |
Join Date: Apr 2019 Motorcycle(s): 1993 katana 600 (sold) 1999 gsxr750 srad (sold) 1991 zx10 (blown)2016 grom 125 (sold) 2006 ninja 250r (current Posts: 35
2006 ninja 250 wont rev!?
hey guys. so i recently picked up a 2006 ninja 250r. i just cleaned the carbs, and threw new plugs in it and it wont rev. when i spray start fluid into the air box, it will rev as i spray, but with out starter fluid it will only idle. if i try to rev without starter fluid it just bogs out. i blew compressed air through the jets, and through where the jets screw in. also blew it through every hole i could see. ( i only pulled the float bowls off ) what part of the carbs would be causing this thing to completely die when i give it any throttle? i didnt pull the diaphragm covers off, could there be a ripped diaphragm? dont want to pull the carbs back off until someone can give me a ballpark as to whats not letting it rev without starter fluid. thanks for the help in advance guys.
April 27th, 2019, 07:14 PM | #2 |
First thing...verify the petcock is actually delivering adequate fuel to the float bowls
April 27th, 2019, 08:24 PM | #3 | |
While writing the above, I ran downstairs, loosed the drain screw on the bottom of the carbs, and I have little to no gas in the right side carb bike is on the center stand so its level at all times. Didn’t check the left, as I left my extensions at work and don’t want to pull the carbs. back off tonight. I then used fresh fuel line to go straight from good flowing petcock, right into carbs. Still no fuel in right side carb. I assume very little or none as well in the left side carb. Just didn’t check due to not being able to acess it tonight. Although it ran and spiked to 4k fully choked and then quickly died. Got it to do that twice. What do you think? Is the pet cock not flowing fuel once the bike starts cranking? It doesn’t flow in the on position when bike is off and I believe that’s how it’s supposed to be. But I set it to the prime setting on the petcock (don’t worry I was catching the gas from the little vacuum hole on the bottom with a container) but still had the same result of no gas in the carb Edit: id like to add that i did blow compressed air through the fuel lines that go into the carb while connected to the carb, and air did come from around the float valves. |
April 28th, 2019, 06:58 AM | #4 |
Join Date: Feb 2018 Motorcycle(s): Harley Fatboy, Honda CX500, Harley XL1200C Sportster, 305 Honda Dream, Ninja 250 Posts: 174
You probably have a float issue.
When I buy a new to me bike that has been sitting I only check for spark. I never try to get it running. The first thing that needs to be done is to order a carb rebuild kit from ducatiman. Then proceed to dissemble the entire carb, soak in an ultrasonic bath with 25% simple green, then wire floss every jet, passage way and hole. Followed by spray carb cleaner and compressed air. Adjust the float level to spec and reassemble. The nice thing about the 250 ninja is you do not have to dissemble the carbs from each other most of the time. You still have dirty carbs and unverified float levels. |
April 28th, 2019, 07:13 AM | #5 | |
How long was this 13 year old bike sitting dormant?
April 28th, 2019, 02:56 PM | #6 |
It sat for 2 years outside. Okay so here’s the update. When I try to blow through the fuel line going into the carb, I can’t blow through it. But when I force 120 psi of air in it it’ll have some come out, but when trying by mouth, it will not let me blow any air into the carbs. The petcock pisses gas from the vacuum hole in the on and reserve/prime position. I ordered a petcock that supposedly works with the bike just for the he’ll of it due to it being 7$. But that wouldn’t cause my issue here would it? Because I literally can’t even blow through the brand new fuel line while it’s attached to the carbs. So there’s no way fuel can get in them either since my breath can’t. I also tried blowing while cranking bike, same result.
April 28th, 2019, 03:23 PM | #7 | |
1. Inline filter inside fuel-line has been reversed and crushed-in on itself, or it's completely filled up with crud and not passing fuel. 2. and/or .... fuel-distribution line between carbs clogged and not delivering petrol to float-bowls. 3. and/or float-valves stuck due to dried petrol varnish acting as glue. 4. petcock's diaphragm ripped and not opening petcock's fuel-line. 5. new petcock (when it arrives) will not fit because it's too short, selection-handle will hit bottom of tank, and tilt petcock to prevent seal with tank. I suggest removing carbs and sending them to ducatiman for full-refurb job. This way, you only have to remove carbs once. Rather than doing one trick once. Then having carbs still be problematic and having to yank them yet again, and trying slightly deeper clean. Only to find it didn't work and yanking them yet again for more desperate attempt at "cleaning" to have it not work... etc. Last futzed with by DannoXYZ; April 30th, 2019 at 10:04 AM. |
May 2nd, 2019, 03:53 PM | #8 | |
Floats were stuck. Ordered a kit from ducatiman and rebuilt them. Bike runs now, rides, and revs. But I have like surges of power. So from idle to 10 grand, it accelerates decently hard but not as much as it’s supposed to. Once I hit 10k, it explodes with power and actually lifted the front wheel on the first - second shift. Why am I not getting full power until after 10k? |
May 2nd, 2019, 07:12 PM | #9 | |
May 4th, 2019, 10:15 AM | #10 |
Well I discovered I forgot to put the air filter in. So I put it in, and went for a ride, bike ran much better.. I figured I’d go down to pepboys and spend 10$ on a vin check so I can go register this thing. About 25 minutes down the highway, I lost power. All power, and then the bike died. I’m currently waiting for my progressive road side assistance, (thank god I got insurance literally yesterday) and so far I’ve tested for spark, I do have strong spark, and my 7$ fuel petcock off eBay has failed. Gas flows out in the on position with the bike not running. I suspect this to be my issue, but will investigate further once I’m home. Any ideas? Bike just started to lose power little by little and then died (acting as if it’s running out of gas) I was cruising around 80mph. Also, What’s a cheap strong petcock I can buy that won’t fail in 17 miles? New one from Kawasaki is like 100$. Not interested in paying that at all. Lol
May 5th, 2019, 01:32 PM | #11 |
Bummer.
There isn't a good aftermarket replacement petcock out there that I've seen. Most are manual (not vacuum) and not long enough to be able to turn them on and off. There are rebuild kits, but some are as pricey as a complete new petcock. |
May 5th, 2019, 03:12 PM | #12 |
So BOTH your original and new petcock flow fuel in ON position? Should only flow when there's vacuum in vacuum line. Something's wrong with both of them.
I believe this is rebuild-kit for pre-gens:https://www.ebay.com/itm/323531028088 |
January 1st, 2023, 11:54 AM | #13 |
I didn't know that about the aftermarket petcocks.
2007 Ninja 250 dies and wont start when warm | Hewes | 1986 - 2007 Ninja 250R Tech Talk | 12 | September 19th, 2018 11:31 PM |
My 250 Wont go more than 55 mph...!!!! | Knobs28 | 2008 - 2012 Ninja 250R Tech Talk | 14 | May 19th, 2016 06:20 PM |
2010 ninja 250 wont stay on! | daveduno | 2008 - 2012 Ninja 250R Tech Talk | 10 | May 27th, 2014 07:55 PM |
2007 Ninja 250 wont start...any suggestions? | tkessler | 1986 - 2007 Ninja 250R Tech Talk | 11 | February 26th, 2014 10:36 AM |
Ninja 250r Wont Rev or run without choke | esde | 1986 - 2007 Ninja 250R Tech Talk | 21 | November 9th, 2009 02:32 PM |
