Go Back   ninjette.org > 2013 - 2017 Ninja 300 > 2013 - 2017 Ninja 300 General Discussion
Old November 13th, 2014, 03:09 PM   #241
i wonder if you could simply put a ball bearing in the top so its air tight, but then a plug over that with a hole in it so that a vacuum or backpressure could push/pull the ball bearing up and down, but it would stay sealed and the ball couldn't escape completely because of the plug
Old November 13th, 2014, 04:08 PM   #242
tfkrocks
tfkrocks's Avatar
MOTM - Jan '18, Sep '13
Looks like a solid plug to me
My Ninja 300
Old November 13th, 2014, 05:14 PM   #243
tfkrocks
tfkrocks's Avatar
An appropriate sized screw would work as a plug too. Maybe get another tube clamp to make extra sure the plug is secure.
My Ninja 300
Old November 18th, 2014, 09:52 AM   #244
JohnnyBravo
Certifiable nontundrum
JohnnyBravo's Avatar
MOTM - Sep '13, Sep '16
Training Freddy Kruger really offends common kids senses
Old November 18th, 2014, 09:53 AM   #245
JohnnyBravo
I win
0 out of 1 members found this post helpful.
Old November 18th, 2014, 10:15 PM   #246
JohnnyBravo
I sure do wish it were that easy indeed, but life being what it is, an you nutty as a durn fruitcake I ain't doubting anything
Old January 2nd, 2015, 12:14 PM   #247
tfkrocks
tfkrocks's Avatar
Alright, did lots of stuff recently.
ZX-6R headlights! Still no high beams for me because I'm bad at dealing with electrical issues and I probably need to aim it a little better but it works.
Fairing stay was tweaked from crash. Finally got a brand new one so I won't have to struggle with putting the fairings on anymore and so the front end actually looks straight lol. Also discovered that one of the metal loops on the tweaked fairing stay had actually rusted off over time. Oops. (I bought the fairing stay from https://www.facebook.com/pages/Motor...8870?ref=br_tf and it was really cheap even after including the international shipping. Ordering isn't the easiest thing since you have to email the guy with part numbers but damn it was cheap.)
Old one on top, new one on bottom. Wait, something's missing...
Oh there it is.
PDM60 for my accessories. Yay for much safer wiring. The ability to program it is cool. Also finally threw in the battery tender lead since I cleaned up my battery bolt space with the PDM60.
R6 throttle tube. Definitely a noticeable difference.
My Ninja 300
Old January 2nd, 2015, 12:34 PM   #248
Progress!
Old January 3rd, 2015, 07:01 AM   #249
JohnnyBravo
Looks a lil too good, now I want some!
Old January 3rd, 2015, 07:05 AM   #250
garth285
KAWASAKI GURU
garth285's Avatar
Looking great!
If you need any electrical help let me (us) know!
Old January 3rd, 2015, 08:42 AM   #251
JohnnyBravo
Originally Posted by garth285 View Post
Looking great!
Make all the headlights work at the same time low/high beam and do a thread
Old January 3rd, 2015, 08:57 AM   #252
tfkrocks
tfkrocks's Avatar
That would be doing a bi xenon retrofit
My Ninja 300
Old January 3rd, 2015, 09:12 AM   #253
garth285
KAWASAKI GURU
garth285's Avatar
That would actually be very easy. People have been doing that for a while on all sorts of bikes. Your really just running a jumper wire from one bulb to the other. As long as both bulbs are dual filament it Will work. The only one other thing is some headlights are built to project the light higher on one side than the other.
If I had a ninja 300 to use I'd be glad to do a write up with pics but I don't know anyone with one.
Old January 3rd, 2015, 10:35 AM   #254
tfkrocks
tfkrocks's Avatar
Yep the reflectors are different on each side. And as I mentioned, there's no change in aim when you change low/high like that. The lights will still be pointed in the same direction. Not necessarily helpful.
My Ninja 300
Old January 3rd, 2015, 10:36 AM   #255
garth285
KAWASAKI GURU
garth285's Avatar
Ahhh I missed that, sorry.
Yeah most bikes are like that, the Gen 1 ZX-10rs were like that but I still wired mine and a buddys to have dual lights on.
Old January 3rd, 2015, 10:41 AM   #256
tfkrocks
tfkrocks's Avatar
Well technically I mentioned it in another thread but @JohnnyBravo has a tendency to carry on conversations in multiple threads
My Ninja 300
Old January 3rd, 2015, 12:25 PM   #257
wow those headlights look really good
Old January 3rd, 2015, 08:02 PM   #258
JohnnyBravo
Guess ill be getin some bisexual headlights
Old January 3rd, 2015, 08:06 PM   #259
tfkrocks
tfkrocks's Avatar
They need love too
My Ninja 300
Old January 4th, 2015, 03:08 PM   #260
snot
sammich maker
snot's Avatar
MOTM - Apr '15
I love the 636 lights. I always have a feeler out for them.
Old January 9th, 2015, 11:27 AM   #261
Bubba
Motorcycle(s): 300
Originally Posted by tfkrocks View Post
I call it the "Too cheap/broke to buy new fairings so using whatever cheap used fairings I could find" paint scheme
Regardless, it looks better than monochrome. I would paint the fairing upper green, the tail white, and seat piece green, get one unbroken line of white on the bottom half of the bike.
Bubba is offline   Reply With Quote
Old January 9th, 2015, 06:18 PM   #262
tfkrocks
tfkrocks's Avatar
Nah that's the oem pearl white paint and it would be too hard to do that myself. And one of those tail pieces used to be oem pearl white until I painted it green hahaha. I'll probably eventually get all of it green again. Maybe throw in some blue accents.
My Ninja 300
Old July 6th, 2016, 06:55 PM   #263
tfkrocks
tfkrocks's Avatar
Finally put some preload adjusters on. Now you can see how faded my other anodized parts are lol.
My Ninja 300
Old August 4th, 2016, 11:53 PM   #264
tfkrocks
tfkrocks's Avatar
Recently picked up an old Ninja 250 Fox shock. It's currently at a suspension shop for service but it will be on my bike very soon!
My Ninja 300
Old August 5th, 2016, 12:11 AM   #265
JohnnyBravo
I heard fox makes good shocks, but they sponsored the guy I heard that from so
I love preload adjusters
Old August 5th, 2016, 12:14 AM   #266
tfkrocks
tfkrocks's Avatar
It's hell of a lot cheaper than an ohlins! I've never touched suspension at all and just wanted to try something different. No desire to spend a fortune on it.
The preload adjusters definitely look much nicer than the bare fork caps. They've probably started fading already though cuz they spent 2 weeks baking in the hot Sacramento sun right after I installed them
My Ninja 300
Old August 5th, 2016, 12:19 AM   #267
JohnnyBravo
Part prices can get a bit crazy! I wanted to get a shock, never did; or I guess haven't yet?
Then they may all match bout everything weathers when out in the weather, embrace the suck
Old August 23rd, 2016, 09:41 PM   #268
tfkrocks
tfkrocks's Avatar
Fox shock installed! Dropped the OEM shock on my pinky while removing it and that hurt like hell. Haven't ridden on it yet cuz it took me so long to finish working. Getting the undertail on and off is such a pain in the ass, not helped by the amount of the stuff i have wired on the bike lol. I'll see how it feels in the morning.
My Ninja 300
Old August 25th, 2016, 02:58 AM   #269
JohnnyBravo
Looks good...
Old August 25th, 2016, 03:09 AM   #270
tfkrocks
tfkrocks's Avatar
I took a better picture in sunlight. The person who does suspension set up at the shop I went to wasn't there so I'll have to do it another time. Doesn't feel bad as it is now though. I just put it at Fox's recommended starting point.
My Ninja 300
Old August 25th, 2016, 11:38 AM   #271
JohnnyBravo
So much want for suspension sparklie bits
Old August 26th, 2016, 03:48 PM   #272
algs26
Motorcycle(s): ex300, gave up looking for a 250
Is the 300 better handling than the FZ now?
algs26 is offline   Reply With Quote
Old August 26th, 2016, 04:27 PM   #273
tfkrocks
tfkrocks's Avatar
It was already better handling than the FZ. I probably didn't NEED any suspension upgrades on the 300 but I like to keep tinkering I really need to do something about the FZ's suspension because it is not confidence inspiring at all.
My Ninja 300
Old August 26th, 2016, 04:30 PM   #274
JohnnyBravo
I need to start tinkering again
Old August 26th, 2016, 04:32 PM   #275
tfkrocks
tfkrocks's Avatar
Started bixenon retrofit. So far I've already spent way too many hours cursing while opening the headlight unit, had a screwdriver slip and cut my face making it bleed, and completely destroyed an important part from inside the headlight unit that can't be bought by itself. Project on hold until I can find a way to 3D print that part...
Thank goodness I didn't sell off the stock headlights yet.
My Ninja 300
Old August 26th, 2016, 04:34 PM   #276
JohnnyBravo
Yikes.. PPE; sheesh
Old August 26th, 2016, 04:35 PM   #277
tfkrocks
tfkrocks's Avatar
Yikes.. PPE; sheesh
At least it missed my eye! Got me right under.
My Ninja 300
Old August 26th, 2016, 04:37 PM   #278
JohnnyBravo
That sounds worse than I thought... Glad you missed your eye indeed
That's why I like to get as much stuff plug an play as possible, but at least I know who to send my lights too for fixing
Old August 26th, 2016, 04:39 PM   #279
JohnnyBravo
That looks like something superglue or epoxy would fix perfectly
Old August 26th, 2016, 04:44 PM   #280
tfkrocks
tfkrocks's Avatar
eh. it needs to be snug though. was apparently a bit too snug when i was putting it on, hence the cracking. i could try epoxy but i'd need to find the other half first. no idea where it when cuz it split violently lol.
My Ninja 300
2005 rebuild help thread Ninjetteshubby 1986 - 2007 Ninja 250R Tech Talk 7 December 16th, 2014 07:14 AM
1990 Ninja 600R Rebuild thread theJester517 General Motorcycling Discussion 8 March 31st, 2014 07:14 PM
Ninja 300 vs. CBR500R - the inevitable comparison thread adouglas 2013 - 2017 Ninja 300 General Discussion 180 October 8th, 2013 01:53 AM
Official 2013 Ninja 300 (and 250) Thread 2009zx6rider 2013 - 2017 Ninja 300 General Discussion 1795 January 2nd, 2013 01:07 AM
