Old June 20th, 2015, 12:25 PM   #1
LNasty
Daily Jap rider
LNasty's Avatar
Clickitty click click clickitty click click
So just got my battery tested and it is good and fully charged like my charger said, But I am getting a single click then nothing when I try to start bike. It doesn't do the numerous clicks like when the battery is dead. What could this be? bad starter motor? dirty posts ( on the battery, not the on ninjette ya sicko's)? Corroded terminals?
"Most motorcycle problems are caused by the nut that connects the handlebars to the saddle." - author unknown
Old June 20th, 2015, 01:05 PM   #2
Flying
Motorcycle(s): 2010 Ninja 250
nevermind misread
You will have to check the connection from battery to starter solenoid. It's hard to say anything about the condition of the starter motor.
Inspection for corroded terminals, loose connections, bad grounds are a good start.
Old June 20th, 2015, 01:09 PM   #3
Use a screwdriver to jump the starter solenoid. They click sometimes.
Old June 20th, 2015, 01:51 PM   #4
LNasty
Daily Jap rider
LNasty's Avatar
I will try this, where is the solenoid located on the new gen 250?
Old June 20th, 2015, 02:51 PM   #5
Ghostt
Ghostt's Avatar
https://www.ninjette.org/forums/showthread.php?t=61661
violente et ignorantia
ZX-2R BLOG
Old June 20th, 2015, 03:46 PM   #6
subxero
dirty boy
subxero's Avatar
MOTM - Apr '14
if your battery is completely shot sometimes you will only get one click if any click at all.
How do your headlights and dash react when trying to start?
Old June 20th, 2015, 04:47 PM   #7
Linkin
Down Under
Linkin's Avatar
Motorcycle(s): Kawasaki ZXR250C Ninja
Same thing happened to me. It was the starter motor. Try loosening and tightening the connection to the starter motor.
Try clutch starting then bumping the starter just to rotate it a bit.
Linkin is offline   Reply With Quote
Old June 20th, 2015, 05:14 PM   #8
The single click may come from any of the three relays which solenoids are powered when you press the start button.
Some contacts in those relays are not touching each other, not sending power to the starter motor.
Follow this schematic for troubleshooting:
http://faq.ninja250.org/images/0/07/..._Schematic.pdf
Old June 20th, 2015, 08:38 PM   #9
iamjacob
iamjacob's Avatar
Motorcycle(s): 2011 250R SE
My dad had and old chevy that did the same thing. He hit it (the starter, not the truck) with a big arse crescent wrench and then it was good to go.
Probably not useful information but it's what I had.
Last futzed with by iamjacob; June 20th, 2015 at 08:39 PM. Reason: edification
iamjacob is offline   Reply With Quote
Old June 20th, 2015, 09:13 PM   #10
LNasty
Daily Jap rider
LNasty's Avatar
I took battery to a different AutoZone since first one seemed a little unsure if what she was doing. The second opinion said battery was showing 12v but only 45% charged. So i am leaving on charger overnight even though light shows green. Will try it again tomorrow as well as bridging the starter. If no worky then i will take battery back to AutoZone and have them put it on their slow charger.
Old June 20th, 2015, 09:16 PM   #11
LNasty
Daily Jap rider
LNasty's Avatar
Everything goes out but then seems to come back on. Headlights don't have a chance to chance to come on
Old June 20th, 2015, 09:27 PM   #12
/begin yoda voice
A new battery I see in your future. Yes... Fail under load it seems.
Old June 21st, 2015, 12:01 AM   #13
LNasty
Daily Jap rider
LNasty's Avatar
/begin yoda voice
Yeah probably for sure now since i just accidentally dropped the god damn thing on the ground. Looks like there might be small cracks. I'm getting a damn lithium, screw the acid batteries, nothing but trouble and tired of having to hook up to charger every few days. Ballistic here I come
Last futzed with by LNasty; June 21st, 2015 at 12:02 AM. Reason: to angry to type correctly
Old June 21st, 2015, 12:10 AM   #14
Ghostt
Ghostt's Avatar
Sealed gel battery here, no issues since I switched over a year ago.
ZX-2R BLOG
Old June 21st, 2015, 12:42 PM   #15
LNasty
Daily Jap rider
LNasty's Avatar
IT'S ALIVE!! its allllliiiiiivvvve!
Was on charger for second full night and just hooked it up. Started up perfectly, however i asm still going to get a new battery. Since i depend on this bike to commute to work i can't be worthing about the battery every week. Even with the quick disconnect it had been a pain in the arse. A least this gives me a few days to do a little more research on batteries.
Old June 21st, 2015, 07:58 PM   #16
DmbShn41
Wannabe Reborn
DmbShn41's Avatar
May be worth checking into the charging system on bike. Just to make sure you don't cook a new battery.
http://faq.ninja250.org/wiki/How_doe...system_work%3F
Let us know what you find.
Old June 21st, 2015, 08:10 PM   #17
LNasty
Daily Jap rider
LNasty's Avatar
Definitely will. I do have some auxiliary led lights hooked up so that could be putting a little extra load on it, plus i have accidentally drained it two or three times by leaving key in and on or not turning off leds. You add all that in to a battery that is 3 years old and its prob time for a new one. Will be checking into all this.
Old June 21st, 2015, 08:57 PM   #18
........... A least this gives me a few days to do a little more research on batteries.
http://www.batterystuff.com/batterie...ex250-ninja-r/
Old June 21st, 2015, 09:04 PM   #19
Ghostt
Ghostt's Avatar
Here's the exact one I have, I also have the kind but bigger on my EX50/
http://m.ebay.com/itm/GEL-GTX7A-BS-U...-/360783842056
ZX-2R BLOG
Kawi Click or something else? johncrist1988 1986 - 2007 Ninja 250R Tech Talk 44 June 17th, 2015 01:23 PM
First gear click Bentley813 2013 - 2017 Ninja 300 Tech Talk 24 July 2nd, 2013 06:27 AM
[motorcyclistonline] - Adjusting Motorcycle Suspension | Click, Click | Street Savvy Ninjette Newsbot Motorcycling News 0 July 10th, 2012 10:20 PM
one click, no start coondog 1986 - 2007 Ninja 250R Tech Talk 12 September 12th, 2011 04:43 PM
Weird Click JBar215 1986 - 2007 Ninja 250R Tech Talk 13 June 7th, 2010 12:17 PM
