Old June 30th, 2015, 06:27 AM   #1
fatspiderman
Motorcycle(s): 2011 250r
Tachometer on 2011 stopped working
Hey guys I have a 2011 Ninja 250r. I dropped it last weekend on it's left side when I stalled going about 2 mph practicing a tight figure 8 in the parking lot. Going too slow I guess.
It went down pretty slowly but enough to bend gear shift pedal and scratch up my fairings/mirror/turn signals. I was able to bend the pedal back and other than the cosmetic damage, seemed to run fine.
I went on a few more rides since then with no problems at all. Now today, after a 3 day rest, I take it out and the Tachometer works for 2 seconds before bottoming out and staying at 0 RPM.
I ignored it hoping it'd fix itself during my ride and there were a few times when the gauge jumped up but for the most part, it stayed dead and didn't move at all.
Mechanically, the bike seems sound though and everything else looks like it's working, both electrical and mechanical.
Any thoughts on what could be wrong? I've been researching but have not had much luck so far. I took it to the shop today but they said it'd be at least a week to even take a look so I just brought it back home.
fatspiderman is offline   Reply With Quote
Old June 30th, 2015, 06:34 AM   #2
CC Cowboy
CC Cowboy's Avatar
MOTM - Mar '13, Jun '14
I have found that a hammer fixes most problems.
This information can not be reliable for all repairs. Use hammer fix at your own peril.
Old June 30th, 2015, 06:54 AM   #3
fatspiderman
LOL well the needle was moving fine before. Plus it even jumped a tiny bit once or twice during the ride so I don't think it's stuck. I'm guessing the signal being sent was weak and slowly died....any suggestions on checking the wiring?
Old June 30th, 2015, 09:26 AM   #4
CC Cowboy
CC Cowboy's Avatar
Start at the tach and work backwards.
Old June 30th, 2015, 09:30 AM   #5
Lol... CC
Check your battery connections first. Loose wires can cause crazy tach issues. Pinched wires around the front sprocket cover also causes this issue.
Old June 30th, 2015, 10:56 AM   #6
Tachometer not working or going crazy 3290675 2008 - 2012 Ninja 250R Tech Talk 8 September 1st, 2014 09:11 PM
Tach stopped working? beta7 2008 - 2012 Ninja 250R Tech Talk 1 July 4th, 2013 09:31 AM
Blinkers just stopped working coluk33 1986 - 2007 Ninja 250R Tech Talk 8 May 6th, 2013 09:13 PM
tach stopped working -.- ajaygraci 2008 - 2012 Ninja 250R Tech Talk 23 March 31st, 2012 10:55 PM
Blinkers stopped working :( caps 2008 - 2012 Ninja 250R Tech Talk 13 October 15th, 2011 10:54 AM
