December 19th, 2013, 03:20 PM | #1 | |
Your face
Join Date: Jul 2013 Motorcycle(s): 2014 Honda CBR650f Posts: A lot.
What would you trackstars add?
I'm very interested in hitting the track next season, so I've been doing some research on causes for common crashes at the track. Here's an article I found that mentions some. Pretty obvious list. Anything you experienced trackers want to add?
"even a proper fitting helmet can 'get loose'" -csmith |
December 19th, 2013, 03:47 PM | #2 |
MOTM - Mar '13, Jun '14
I only know of one thing that makes riders crash, not enough experience. Don't focus on why you, or anyone else, will crash (negative focus). Focus on learning how to ride the track (positive focus).
I do know, for a fact, the more you go the better you get.
December 19th, 2013, 03:53 PM | #3 |
Jigglin' your Jiglets
MOTM - Apr '13
Don't try to go fast, that's how you crash.
December 19th, 2013, 03:57 PM | #4 |
Took me 6 days to get to A-group pace at T-hill. Took me 7 days til first track crash. Everything listed in your first post seems reasonable, as does CC's blanket advice.
Nobody gets signed to a GP contract based on kicking butt their first few trackdays. All you're there for is to have fun and improve your skills, at a speed (both velocity and learning-wise) that isn't possible on the street. Gradual = good. Safe = you get to come back the next week.
December 19th, 2013, 04:19 PM | #5 | |
December 19th, 2013, 04:28 PM | #6 |
Motorcycle Hypermiler
Join Date: Jan 2012 Motorcycle(s): 1999 & 2005 Kawasaki Ninja 250R's Posts: A lot.
I would add to avoid the dreaded rear brake lock-up and to make sure the tires are warmed up before cornering hard.
235 MPG Hypermotorcycling to a better tomorrow |
December 19th, 2013, 05:10 PM | #8 |
Ninja chick
Join Date: Jun 2009 Motorcycle(s): '13 Ninja 300 Posts: A lot.
MOTM - Dec '13, Feb '15
Hmm, hitting gator rumbles at full-lean is a no-no. Stand her up first.
Look where you want to go, as far ahead as possible, but I did learn at Little Tally there's a such thing as looking TOO far in and missing a turn-in point (which is how I ended up outside on the rumble).
Sometimes it's the journey that teaches you a lot about your destination. ~Drake Check out my Appalachian Trail journal, 2015! Postwhores are COOL! ~Allyson |
December 19th, 2013, 05:22 PM | #9 |
Another good reason, simply stated as "cart before the horse". How many times have you heard the following; "You don't need to get off the seat until hard parts are dragging". I will be honest, while that is technically true, why risk it? At least get a "clue" of the skills before you need them and NOT after they are the reason you crashed.
Link to original page on Vimeo. At the very end you can see a line in the tarmac from dragging a rearset as it lifted a wheel. He also hung on to a fault, the bike drug him right back into the race line. Not good at all. Bonus: Why did the following rider run off?
December 19th, 2013, 05:28 PM | #10 |
Your face
He/she was watching the guy crash?
December 19th, 2013, 05:38 PM | #11 |
December 19th, 2013, 06:21 PM | #12 |
Your face
That sounds like a tough reflex to resist. Human nature to want to look at someone/thing crash
December 19th, 2013, 06:25 PM | #13 |
Ninja chick
Gotta fight it. I'll never forget coming around Barber's most technical turn (corner 5), and a rider crashed and his bike kept going in unpredictable circular spiral patterns all over the track in front of me. Somehow I didn't target fixate and altered my line no problem. It was definitely a confidence builder because I often wondered the same thing...would I be able to overcome that immediately strong desire to look?
Edit: I also got lucky by choosing the right side of the track. It was hard to tell which direction the bike was going to go next. I had never seen anything like it!
December 19th, 2013, 06:29 PM | #14 |
Join Date: Oct 2012 Motorcycle(s): 64 Triumph, 86 Fazer, 08 R6, 11 Ex250 Posts: 39
I would add poor body position to the list. Poor BP will exaggerate all the other mentioned.
AMA, WERA, SOAR #412 Spiegler Vortex Pilot Chicken Hawk Racing Yoshimura |
December 19th, 2013, 07:59 PM | #15 | |
Same reason for virtually all of my get-offs over the past 15 years. Fortunately there haven't been that many, but all but one were caused by losing the rear under power. That one at Thunderhill was at a place on the track that is quite interesting (T9), with a blind corner over a rise, with strong acceleration necessary right past the corner to get decent drive into T10. I was spinning the rear up there pretty consistently when the bike unweights over that rise. I was slightly off-line to avoid a slower rider, but with the same lean angle and throttle; I lost the rear faster than I could catch it and ended up sliding down the entire hill on my butt. News flash #1 - it's great fun to leave darkies on corner exit, and it's surprisingly easy to do even on a 600 at speed, let alone a liter bike. News flash #2 - if you find yourself doing that repeatedly, it's not a sign of bike control; rather it's more likely a sign of impatient throttle control. It's interesting, because I'm always more concerned about the front than the rear, with the belief that if I can get the front to stick, the rear will have more than enough, and it's easier to catch anyway. But when it comes to my get-offs (including the one rojo was present for), it's always been more throttle than advised for the current conditions/ bike attitude.
December 19th, 2013, 07:59 PM | #16 | |
Keep up the good fight, I just got a lot of practice at it.
December 19th, 2013, 09:05 PM | #17 | |
former ninja 250'er
Join Date: Jan 2013 Motorcycle(s): Aprilia 1000R, CRF450, CBR600RR tracktoy, Ninja 250 -- GONE!!!!! Posts: 153
listen, as a novice rider 1/2 of the OP's list doesnt even apply - you're simply not pushing the bike anywhere near hard enough to approach the limit of adhesion between the track and tire especially on a little bike like a 250. i would venture a guess that 90% of all novice crashes occur because of a combination of miscalculation of approach speed to a turn (ie, braking too late or not hard enough) and not having the confidence to follow through the turn. the result is either standing the bike up and running off track, or checking up and tucking the front end. my best advice, dont focus on how LATE you can brake, but instead (this is from the Parker or Code book, i forget) focus on slowing down to the speed that you feel is correct for the corner, even if it means braking a bit early and not as hard. true speed will come from what you can carry through the turns; getting all hot and bothered about optimized braking is just unnecessary stress at this level of riding and really doesnt impact your lap time as much as you'd think. |
4 out of 4 members found this post helpful. |
December 19th, 2013, 09:09 PM | #18 |
@iZapp - How you guys doing? Well I hope?
December 19th, 2013, 10:57 PM | #19 | |
Your face
Trail braking is definitely not something I was even considering at this point
December 20th, 2013, 10:22 AM | #20 | |
December 20th, 2013, 10:30 AM | #21 |
that could be applied to quite a variety of circumstances. on and off the track.
December 20th, 2013, 11:24 AM | #23 | |
There are plenty of really fast guys that don't use it. Kevin Schwantz has said that he never did. With hot tires and hard braking from the front there isn't much, if any, braking available from the rear. Not using it simplifies your life as a new track rider. As far as trying to go fast and "attack", even Kenny Roberts said he could only mentally hold a full-on race pace for 3 or 4 laps. If you listen to Marc or Lorenzo they will only "attack" at certain times when the timing is right. Without many exceptions (other than Marquez), smooth (like Lorenzo), is usually the fastest. |
December 20th, 2013, 12:07 PM | #24 |
Your face
December 20th, 2013, 04:30 PM | #25 | |
former ninja 250'er
December 20th, 2013, 04:37 PM | #26 |
Ninja chick
Don't use it on the track. Even though I love it on the street, I never touch it at the track.
December 20th, 2013, 05:11 PM | #28 |
Ninja chick
Me too! Lol!
But do you really? I thought you never used the rear.
December 20th, 2013, 05:13 PM | #29 | |
Hope ya'll have a merry xmas too and tell Zach I said hi.
December 20th, 2013, 05:44 PM | #30 |
i've been trying to use it more, but when push comes to shove, it has no room in my skill book. when i'm not pushing though i like to use the rear a little bit while i'm slowing down and shifting cause it helps eliminate some of the chain jerk i get when i do the weird half clutch upshift i always do
December 20th, 2013, 08:09 PM | #31 |
Ninja chick
I agree. I've started using it more over the past year most of the time when I'm stopping on the street b/c it smooths out my stops a bit, but I never use it when I'm hard braking.
add pic | james250ninja | Help | 1 | August 22nd, 2014 08:21 PM |
adobe add | fishdip | Forum Information | 8 | July 27th, 2013 02:36 PM |
Add me to the list! | RaceBikeRentals | General Motorcycling Discussion | 16 | March 23rd, 2010 03:25 PM |
Add Sticky | Snake | Forum Information | 2 | February 21st, 2010 01:37 PM |
[faster and faster] - Aero 3S add bling to the Campagna T-Rex, OptaMotive to add batt | Ninjette Newsbot | Motorcycling News | 0 | April 27th, 2009 10:30 PM |
