Old March 17th, 2015, 01:46 AM   #1
Jason5885
Jason5885's Avatar
Motorcycle(s): 2010 Kawasaki Ninja 250r FI
Question Brake Lights don't work when braking
I noticed last night that my brake lights are on solid. When I operate the back brake or the front break the brake light is always on, even when back and front break aren't being operated the light is solid.
Any ideas?
Jason5885 is offline   Reply With Quote
Old March 17th, 2015, 05:16 AM   #2
HKr1
IC2(SW)
HKr1's Avatar
Check the switches...
Old March 17th, 2015, 05:58 AM   #3
^^^ yep, I would pay close attention to the rear switch.
Old March 17th, 2015, 06:47 AM   #4
Jason5885
Jason5885's Avatar
Where are these switches located exactly? Could one switch cause a problem with both brakes?
EDIT just checked my service manual. Will have a play about with the switches tonight.
Old March 17th, 2015, 07:00 AM   #5
In the above pic, the rear brake light switch is the wire above the rearset, just in front of the brake res. hose. When viewed from underneath, you will find a thin connecting rod that runs from the brake lever to the switch. Ensure that it is clean and moves freely. Then check that it operates with the foot lever. It works in opposite, meaning... when the foot lever is pushed down the pin will pull inward, making the electrical contacts for your brake light. Vice versa for when the lever is released, the pin will be pulled outward breaking the electrical connection.
The front is similar in how it works. It's a simple button, pull the hand lever to push the button. Again, ensure everything is clean and moves freely.
Old March 17th, 2015, 07:24 AM   #6
Jason5885
Jason5885's Avatar
This makes sense to me, thanks Chris, I'll have a look tonight and see if i can source the problem. I hope it's as simple as that.
Old March 17th, 2015, 07:52 AM   #7
Np Jason, another issue the thin connecting rod may be missing altogether.
Old March 17th, 2015, 10:54 AM   #8
Check the bulb before you go too deep into troubleshooting elsewhere. It's a dual-filament, so the brake element could be non-functional while the tail-light/running-light filament is working fine.
The fact that neither the front brake switch nor rear brake switch appear to be triggering the light points more to a bulb issue than a sensor issue.
Old March 17th, 2015, 02:25 PM   #9
Jason5885
Jason5885's Avatar
Ok so I've sourced the issue..
The small switch that your front brake lever is meant to cover when you aren't braking, and when you do break the level allows the switch to Pop out, is not being covered by the brake lever.
I'm using the ebay adjustable levers and the bit that covers this little button/switch is just short of covering it. i don't know why it's only just happened now? Can this little button be adjusted so the lever covers it properly ?
Old March 17th, 2015, 02:38 PM   #10
Post a pic, I aint quite following what your saying.
Old March 18th, 2015, 03:16 AM   #11
Jason5885
Jason5885's Avatar
I will when i'm home from work today.
But basically, when you arent pulling your brake lever and its in its stationary position, its covering a small button, and when that button is pressed in, the brake light is not in operation. As soon as you pull your brake lever, it moves away from the button , thus not pressing it anymore, which triggers the brake light to turn on.
My problem is, wether my lever is in operation or not, the button isn't being covered. Thus my light is permanently on.
Old March 18th, 2015, 03:40 AM   #12
Somchai
Freedom for Germany
Motorcycle(s): Ninja 250R-FI
Jason, didn't you say that your bike fell two times down on the right side, so could it be that the lever is bent?
Old March 18th, 2015, 07:22 AM   #13
Jason5885
Jason5885's Avatar
It was happening before it fell. The bar is replaced now too. I think theres a small allen screw on the button assembly, pehaps i can move the button closer to the lever.
Old March 18th, 2015, 10:00 AM   #14
There is no adjustment to move it closer that I know of. It sounds as if it is broken internally and you will need a new one.
Here is what I would do;
Pull and release the lever, hear a click? No click, switch is most likely broken internally. Replace switch.
Check the prongs on the back of the switch. Clean and plugged in properly? Retest, work? Problem solved.
Get a multimeter and touch the two prongs with the meter probes. If the switch is working, there should be continuity when the button is not pressed. With the button pressed in, there should be no continuity. If broken, replace the switch, otherwise replace the bulb.
Old March 22nd, 2015, 07:18 AM   #15
DmbShn41
Wannabe Reborn
DmbShn41's Avatar
OP, had similar issue with that exact switch. My rear brake switch would work, front brake switch didn't work, mechanically it worked, however when I removed it and put a meter to it, state didn't change. Believe that switch is a normally closed device. Partzilla, eBay, etc about $10.
Old March 22nd, 2015, 08:07 AM   #16
Whiskey
The front brake light switch is well known for being easy to break when you're switching out levers. the 'button' on the front can get snapped short.
first things first check the bulb.
Volo lights enhanced deceleration brake lights coachparm 2013 - 2017 Ninja 300 Farkles 3 February 11th, 2014 09:52 PM
Extra Brake Lights in pods = all other lights dimming CalvinAmI 1986 - 2007 Ninja 250R Tech Talk 23 October 16th, 2012 10:21 AM
Electric start problem, lights, blinkers, and indicator lights work. claymaker 1986 - 2007 Ninja 250R Tech Talk 8 July 10th, 2012 07:04 PM
Front Brake Light Don't Work ajcadoo 2008 - 2012 Ninja 250R Tech Talk 2 April 19th, 2012 09:58 PM
blinkers don't work Domagoj 2008 - 2012 Ninja 250R Tech Talk 11 January 8th, 2011 12:03 AM
