Old December 29th, 2014, 04:45 PM   #81
chrly
chrly's Avatar
Motorcycle(s): 2013 Kawasaki EX300 , 1999 Kawasaki ZRX1200.
How would you rate those Teri ?
IBA # 59523
chrly is offline   Reply With Quote
Old December 29th, 2014, 04:52 PM   #82
NevadaWolf
Certified looney toon
NevadaWolf's Avatar
MOTM Jul '13, Jul '14
I'd give them an 8/10, very happy with some issues.
Aside from the brake modulator issue, the only other trouble I've had with them is in a heavy downpour. The rain ran down my arms and into the mitts, where my gloves just soaked up the pooled water
But I have used them in 20* temps and know that they keep that pocket of air "warm" compared to the wind chill from riding. Add in heated grips or something and it'd be perfect.
<-- Linky
Old December 29th, 2014, 11:56 PM   #83
NevadaWolf
NevadaWolf's Avatar
I have plexiglass and a mock up. How do I cut the plastic with no power tools?
<-- Linky
Old December 30th, 2014, 12:37 AM   #84
chrly
chrly's Avatar
I started by scribing a straight line with a utility knife and straight edge then snapping it. That got it close then I used a bench grinder to trim it . At that point I shaped it with the heatBe careful that stuff is sharp and every edge will cut. Ypu might want to wear heavy gardening gloves or similar.
IBA # 59523
Old December 30th, 2014, 06:37 AM   #85
LittleRedNinjette
Certified Troublemaker
LittleRedNinjette's Avatar
Raven's Rejuvenation
Old December 30th, 2014, 08:25 AM   #86
flitecontrol
Motorcycle(s): Rebel 250s, Ninja 250s VN750s (currently nine total)
You can also cut it with a fine bladed hand saw. A saw designed for cutting wood usually has large teeth that can rip pieces from the edge that's being cut. If you don't have a grinder, a file and sandpaper will smooth the edges.
Profanity is the weapon of the witless.
flitecontrol is offline   Reply With Quote
Old December 30th, 2014, 10:33 AM   #87
NevadaWolf
NevadaWolf's Avatar
Hurm, I tried scoring it to half way through the sheet but it still broke crooked.
Ah well, got more to fiddle with. May have to go get a hand saw to work with it. Thought my little dremel would work with the plastic cutting wheel but the disk keeps getting stuck.
<-- Linky
Old December 30th, 2014, 03:52 PM   #88
flitecontrol
You can use a hacksaw blade. If the hacksaw frame gets in the way, just use the blade only and wear a glove or wrap the end of the blade with duct tape. The Dremel cutting wheel is probably sticking because it tends to melt the plastic rather than cut it.
Old December 30th, 2014, 10:23 PM   #89
Ghostt
Ghostt's Avatar
Sounds like a good excuse to buy some tools to me, personally pick up a Dremil and have at it, just take you time cutting it don't push the tool, let it do all the work.
As I have one original winter wing in my possession to use as my template, I was going to start making these out of Lexan instead of Plexiglass, but unfortunately life gets in the way hopefully here in a few weeks I'll start cranking some out.
If anyone needs, I can post a detailed pic, so other might make their own, just let me know.
violente et ignorantia
ZX-2R BLOG
Old December 30th, 2014, 10:32 PM   #90
Ghostt
Ghostt's Avatar
Well.. I am definitely not a professional but I did manage to get a couple of pieces cut from a 12x12 inch piece of 1/8 clear plexiglass and by playing with a propane torch* , I now have wings....Ugly but I surprised at how effective they are ..No rain test yet but they can only help .
* I highly advise against heating in the oven as it has been three days and the kitchen still stinks and yeah..I DID sightly overcook..
A full DIY write up would be Nice.
ZX-2R BLOG
Old December 31st, 2014, 07:55 AM   #91
chrly
chrly's Avatar
My work techniques are embarrassingly crude...
IBA # 59523
Old December 31st, 2014, 10:08 AM   #92
Ghostt
Ghostt's Avatar
Don't be shy, look at the Wright brothers, and see where we at now, everything has to start somewhere.
ZX-2R BLOG
Old December 31st, 2014, 10:31 AM   #93
Ghostt
Ghostt's Avatar
Idea: I might instead of Lexan use aluminum, more durable, can be finished, painted, polished, whatever, and easier to work with assuming the gauge I pick, I'm thinking 1/8" or 3/16" or what I have in the shop just laying around.
ZX-2R BLOG
Old December 31st, 2014, 02:55 PM   #94
chrly
chrly's Avatar
Dont forget mirrors.. My wings cover half of each mirror but I can still see thru the plexiglas enough for it not to be a problem , .
I started with a 12 x 12 inch piece of 1/8 inch plexiglas . I cut it diagonally into two pieces. The main side measurements for mine were 10 1/2inches and 12 inches, with the bend at 8 inches and 8 1/2 on the longside . If you want to make those cuts, let them run long, you can then trim the top and outside to your preference. Hope this makes since..
Place the piece flat on a smooth surface and let the "bend" overhang the edge. Then use a heat gun or propane torch and keepit moving constantly until overhanging piece simply falls. It helps to run a few passes on the underside also but main concern is to keep the heat supply moving steadily..
I have tried to be as accurate as possible with the measurements but kinda hard as bends are rounded...After you do one tho the second is easy...
This would be the left side with your mirror mount holes at "A" .I did not mark them as it is easy to do by removing mirror and holding wing in place while you mark the holes.. I made the holes by heating a Phillips screwdriver, laying the piece on a board flat and and then melting thru the mark .. Safer than drilling..
********PLEASE BE AWARE THAT EDGES ARE SHARP AND HEAT SOURCES CAN CAUSE FIRES!!~***********
IBA # 59523
Old December 31st, 2014, 08:29 PM   #95
flitecontrol
Question for clarification. Did you begin with a 10 1/2" square piece and cut it diagonally, or are the dimensions shown on the drawing incorrect, or did you trim a few inches off the pieces once you cut them so the dimension shown are correct?
Old December 31st, 2014, 08:58 PM   #96
chrly
chrly's Avatar
I started with a 12 x 12 and after bending, I trimmed it down.
IBA # 59523
Old January 2nd, 2015, 11:15 PM   #97
NevadaWolf
NevadaWolf's Avatar
I'm not calling this a finished product, more "proof of concept", but hey, I have wings!
<-- Linky
Old January 3rd, 2015, 06:47 AM   #98
Ghostt
Ghostt's Avatar
Woah!!!!! Now that is a set of wings!!!, looking good.
ZX-2R BLOG
Old January 3rd, 2015, 07:13 AM   #99
N-m
Captain 2 Sexy
N-m's Avatar
Motorcycle(s): Kwaka EX250
Score the material on both sides, as deep as possible. I have wondered if a brake using a straight edge as a guide would yield better results?
N-m is offline   Reply With Quote
Old January 3rd, 2015, 09:30 AM   #100
NevadaWolf
NevadaWolf's Avatar
I did with a boxcutter and it still failed. Got my hands on a proper scorer (?) and snapped quickly and easily. Right tool for the job!
<-- Linky
Old January 3rd, 2015, 04:30 PM   #101
N-m
Captain 2 Sexy
N-m's Avatar
Please post link to that tool.
Old January 3rd, 2015, 04:36 PM   #102
Ghostt
Ghostt's Avatar
Here you go
ZX-2R BLOG
Old January 3rd, 2015, 04:46 PM   #103
NevadaWolf
NevadaWolf's Avatar
Not this but like this. Looks like an xacto knofe with a hook.
http://www.amazon.com/gp/aw/d/B000BZ...=AC_SX200_QL40
<-- Linky
Old January 3rd, 2015, 05:48 PM   #104
N-m
Captain 2 Sexy
N-m's Avatar
I have used those and had same results. Sometimes great, sometimes not.
Old January 3rd, 2015, 08:59 PM   #105
NevadaWolf
NevadaWolf's Avatar
First 200 mile review - they work.
Held up under speed, including 75 MPH on I-80, including the wake behind semis and RVs. Slight vibration causing a bit of rubbing on the upper fairing so I'll probably add in a bit of foam to protect the fairing.
Blocked the wind so while my hands did get cold (it was around 27* tonight), my fingers weren't biting cold like my toes ended up getting. I believe these, combined with the handlebar mitts, should make my hands happy on cold nights.
@Old Guy on a '08 mentioned lower fairing wings, so going to play with my left over pieces to see if I can create a wind pocket for my feet.
<-- Linky
Old January 3rd, 2015, 09:05 PM   #106
Ghostt
Ghostt's Avatar
If I may personally suggest, and recommend heated grips, once you've tried them, you'll never ride without them again.
ZX-2R BLOG
Old January 3rd, 2015, 09:18 PM   #107
NevadaWolf
NevadaWolf's Avatar
Perhaps, but any spare power my bike has is already earmarked for another upgrade
http://ledrider.com/shop/?model_numb...anufacturer=18
<-- Linky
Old January 3rd, 2015, 09:27 PM   #108
Ghostt
Ghostt's Avatar
They don't use that much power that the bike can't spare under 50w maximum draw. I run them on mine with absolutely no negative effects.
http://oxford-products.com/us/produc...ted-Grips.html
ZX-2R BLOG
Old January 3rd, 2015, 11:48 PM   #109
NevadaWolf
NevadaWolf's Avatar
My heated jacket takes up everything the bike has left over at the moment. Nothing left unless I improve the system.
<-- Linky
Old January 4th, 2015, 06:56 AM   #110
Ghostt
Ghostt's Avatar
Have you converted all lighting the CREE LEDs, and LEDs bulbs, including the headlight to either a CREE LED or HID? And upgraded to a MOSFET R/R ? As these are the only things you can do to gain more wattage back?
As far as that LED Rider stuff, save your money, get your buIbs from eBay, and the headlight go to DDMTUNING.COM for the HID, or LED bulb, or just order them all from them.
ZX-2R BLOG
Old January 4th, 2015, 11:28 AM   #111
NevadaWolf
NevadaWolf's Avatar
Nope, just getting this.
http://www.electrosport.com/street-b...nja-87-07.html
<-- Linky
Old January 4th, 2015, 12:00 PM   #112
flitecontrol
I recommend Tim Parrott's stator rebuild service. Send him an old stator and he will rebuild it to better than OEM specs for a fraction of what a new one costs, and better quality than electrosport. He uses top quality materials and it shows. The stators he rebuilt for the VN750 outperform the OEM Kawasaki stators.
Old January 19th, 2015, 04:54 AM   #113
N-m
Captain 2 Sexy
N-m's Avatar
Can you post about this or link us to a post?
Old January 19th, 2015, 04:56 AM   #114
N-m
Captain 2 Sexy
N-m's Avatar
I have my windscreen mounted with a heavy rubber gasket and a Chicago style nut made for the gaskets. These work great. I wonder if a similar set up would help.
Old January 19th, 2015, 08:17 AM   #115
flitecontrol
Glad to. http://www.tpe-usa.com/
Old January 26th, 2015, 11:45 AM   #116
NevadaWolf
NevadaWolf's Avatar
Well sadly, though I thought it would happen, when I laid my bike down to have someone help teach me to pick it back up - the wings broke.
I love the idea and concept, my execution of the design however needed a lot of work.
<-- Linky
Old February 6th, 2016, 08:04 AM   #117
Kestrel
Kestrel's Avatar
Motorcycle(s): DR350, Ninja 250
Bit of a thread bump, but it's cold! Purchased some winter gloves as a cold weather alternative to my Helimots, but the bulk is a little too much for me... So, I'd like to fabricate some winter wings for my '02 250.
Cutting and scoring isn't difficult, but what did all of you guys use to cut the holes in the plexiglass/lexan? I know cutting that stuff can be tricky, and that seems to be a pretty sizable hole, too.
Also... If anyone has a spare set lying around for the older bikes, let me know and perhaps I can pick it up from you instead.
Kestrel is offline   Reply With Quote
Old February 6th, 2016, 08:08 AM   #118
Ghostt
Ghostt's Avatar
I have the template if your interested, I used a new drill bit, and didn't force it, just let it do all the work.
Also lexan is better than plexiglass.
ZX-2R BLOG
Old February 6th, 2016, 08:22 AM   #119
Kestrel
Kestrel's Avatar
Template would be great. What size bit? Does this require a press, or could it feasibly be done with a hand drill?
Old February 6th, 2016, 11:07 AM   #120
Ghostt
Ghostt's Avatar
Took some detailed pictures, the grid paper is 1cm scaled, I posted the pictures here:
https://picasaweb.google.com/1006527...CO-4lsGr2MevBA
If you need anything else please let me know.
In case the link doesn't work, here's the pictures
ZX-2R BLOG
[motorcyclistonline] - A Man of Wings & Wheels Ninjette Newsbot Motorcycling News 0 May 2nd, 2014 07:30 PM
[motorcyclemonster] - San Marcos, CA - Wings, Wheels amp; Warriors Ride Jun 28, 2014 Ninjette Newsbot Motorcycling News 0 April 29th, 2014 01:10 PM
[topix.net] - Annual Wings & Wheels Festival will honour war veterans Ninjette Newsbot Motorcycling News 0 May 28th, 2010 04:00 PM
