Old September 18th, 2013, 11:55 AM   #1
sunspots
sunspots's Avatar
Motorcycle(s): 08 Plasma Blue 250
Missing bolt / Someone tried to steal my bike?
Ok, so I'm 100% certain this wasn't like this before, but sometime between last night and today, I noticed that this bolt was missing near the choke.
Does anyone know what size bolt that is and where I would be able to get a new one. Also would I be able to continue riding the bike safely without replacing that bolt?
sunspots is offline   Reply With Quote
Old September 18th, 2013, 11:58 AM   #2
Ride on brah! Your missing the little black plug. In fact, there is nothing in that hole from the factory. It's reserved for an accessory, mirror, gps clamp and so on.
Old September 18th, 2013, 11:58 AM   #3
ps, your bar is bent.
Old September 18th, 2013, 12:00 PM   #4
sunspots
sunspots's Avatar
Awesome.
I guess that was a bit paranoiac of me to immediately think that some bastard tried to steal it lol.
Old September 18th, 2013, 12:05 PM   #5
Take a deep breath.
Old September 18th, 2013, 12:05 PM   #6
You got 'em.
Old September 18th, 2013, 12:08 PM   #7
sunspots
sunspots's Avatar
That sounds....horrible...
What can I do to fix this..
Old September 18th, 2013, 12:12 PM   #8
It's not bent that much, nothing major. But if you wanna fix it; Remove it, put it in a vice and bend it back straight. Getting the bar ends (weights) off will be the hardest part. Roll it on something flat and try to get it to roll as smoothly as possible. Should be a fun Sat. afternoon project.
Old September 19th, 2013, 05:36 AM   #9
Kokosun
Are you sure about that?
Name: That's "Sir" to you!
Motorcycle(s): Ninja 250R-F16, Versys KLE650 CAF
Hmm! Does anybody know anything about that little hole? What's the diameter? Is it screw-threaded? Does anybody use it ... if so, what for?
Kokosun is offline   Reply With Quote
Old September 19th, 2013, 06:08 AM   #10
I don't think it's threaded from kawi. Since you plug is missing, do you see any threads in there? Maybe a previous owner tapped it. If it's not already tapped, then you have some options. Check out what this guy did.
http://forums.ninja250.org/viewtopic...ight=gps+mount
Old September 19th, 2013, 06:09 AM   #11
GHill762
GHill762's Avatar
Motorcycle(s): ZX-3R (ok, ex300)
it's threaded (or should be). just like stated above, it's an accessory hole. it will take mirrors (most non-sportbikes have mirrors mounted on the bars) and accessory mounts.
GHill762 is offline   Reply With Quote
Old September 19th, 2013, 06:16 AM   #12
Kokosun
Seems like a really good idea. I hadn't heard of this before.
Old September 19th, 2013, 06:24 AM   #13
mickheaven
mickheaven's Avatar
Motorcycle(s): 2009 Ninja 250
It should definitely be threaded. I put a mirror from my dads bike in there to test it the other day.
mickheaven is offline   Reply With Quote
Two Brothers Slip on missing bolt cadd 2008 - 2012 Ninja 250R Tech Talk 1 May 11th, 2014 04:51 AM
Missing essential bolt! Need help! Floki 2008 - 2012 Ninja 250R Tech Talk 4 October 6th, 2013 03:08 PM
Center Stem Bolt MISSING! BRad704 2008 - 2012 Ninja 250R Tech Talk 6 August 12th, 2013 08:55 AM
fairing bolt missing kittyslasher 2008 - 2012 Ninja 250R Tech Talk 3 July 30th, 2013 04:44 PM
Help with missing bolt dk58 2008 - 2012 Ninja 250R Tech Talk 22 May 11th, 2011 07:07 PM
