Old November 7th, 2012, 10:05 AM   #1
Ravenger
Motorcycle(s): Ninja 300
First Oil Change
So when do you guys do it? The Dealer as well as the manual says 1000km/600miles but I know a lot of people change both the oil as well as the oil filter out sooner. Do you guys recommend this? Is it really necessary and if so when?
Ravenger is offline   Reply With Quote
Old November 7th, 2012, 10:07 AM   #2
Samer
Samer's Avatar
Motorcycle(s): 09 Ninja 250R SE
600 mile service is more than an oil change... Check the FAQ
Samer is offline   Reply With Quote
Old November 7th, 2012, 10:14 AM   #3
Ravenger
I am very aware of what the 600mile service includes. My question is not whether the oil and oil filter is the only things to be changed in the first service. My question is should the oil filter and oil be changed before the 600 mile service as well.
Old November 7th, 2012, 10:22 AM   #4
Jiggles
Jigglin' your Jiglets
Jiggles's Avatar
MOTM - Apr '13
No
AFM #676
Supersports are for n00bs
Old November 7th, 2012, 10:23 AM   #5
Your gunna get varying answers to your question. I would answer your question as such; it depends on how you break it in, how conservative you are, how mechanically inclined you are and how well do you maintain your bike.
I changed mine for the first time @ 600 miles w/ an average type of break in. Didn't see much in the oil. Did it again @ 1000 after riding it pretty hard. Found more in the oil than the first change.
Your experience me be different.
Old November 7th, 2012, 10:56 AM   #6
Ravenger
Thats pretty much my thoughts on the topic, glad you guys confirmed it cause thats what I did with my 250 but not like I had it very long. Anyway planning the same with my 300, thanks
Old November 7th, 2012, 11:11 AM   #7
HKr1
IC2(SW)
HKr1's Avatar
Some people change oil out allot in the first 600 miles. I always did the 600 - 1000 then every 2000 on my bikes....
Until, the 250r. Kawi put some sort of bad oil in ours, gummy crap. Had to change it out at 200 miles, there was no way in hell you would have made 600.
Old November 7th, 2012, 07:47 PM   #8
Samer
Samer's Avatar
OK. I was just making sure as it wasn't clear to me from your post.
The people that write the manual know what they are talking about for the most part, so you generally will not go wrong following it
Just enjoy it and don't worry too much before 600 miles.
Is it normal for oil to increase a bit in the crankcase after an oil change? cadd 2008 - 2012 Ninja 250R Tech Talk 10 May 15th, 2014 08:38 PM
Synthetic oil at 300 mile oil change? anacron 2013 - 2017 Ninja 300 Tech Talk 14 July 29th, 2013 04:58 PM
Oil drain plug gasket for oil change. tsdexter 2008 - 2012 Ninja 250R Tech Talk 8 July 10th, 2012 01:00 PM
Oil Change Honko 2008 - 2012 Ninja 250R Tech Talk 10 July 17th, 2011 08:58 AM
change oil filter, without draining oil? peter330 2008 - 2012 Ninja 250R Tech Talk 5 May 30th, 2010 01:08 PM
