Old August 9th, 2014, 11:09 AM   #1
garman
Motorcycle(s): 06 Ninja 250
6000 RPM Idle Dies with Throttle
When starting the bike with the Choke open it revs up to 6000rpm and stays there, it will rev normally until its warm and then when I rev it the RPMS will go down with each twist of the throttle until it finally dies. With the choke closed it will idle normally. What should I be looking at, I have ran seafoam through it and reseated the carb to engine and airbox. I have also tried adjusting the idle speed screw to no avail. 2006 250
garman is offline   Reply With Quote
Old August 9th, 2014, 11:37 AM   #2
Sounds like a clogged idle jet, status of cleaning the carbs?
Old August 9th, 2014, 11:40 AM   #3
garman
Going to tear into it tonight, going to try whatever else I can before that.
Old August 9th, 2014, 01:29 PM   #4
garman
Drained and added new gas (for the second time) this time Gas without ethanol, sea foam, and a couple sprays of carb cleaner. It came back to life
Throttle Response Dies Around 7-10k rpm + a few noob questions Ninja Star 2008 - 2012 Ninja 250R Tech Talk 11 June 27th, 2013 10:50 AM
Sluggish rev, erratic idle, dies with throttle Fappy 2008 - 2012 Ninja 250R Tech Talk 12 October 8th, 2012 06:20 AM
Strange Noise at ~6000 RPM forevertwowheels 2008 - 2012 Ninja 250R Tech Talk 20 August 20th, 2012 06:15 AM
Idle jumps to 9000 rpm on choke then wont stay idle after off Shawn250 2008 - 2012 Ninja 250R Tech Talk 1 June 19th, 2012 06:45 AM
Engine Vibration at 6000 RPM Samer 2008 - 2012 Ninja 250R Tech Talk 11 November 10th, 2009 01:15 PM
