May 10th, 2012, 09:20 AM | #1 |
Leaking Carb- Out of ideas....
Hey guys, looking for some help here.
I have a 2001 Ninja, has 135 miles on it. Obviously it has been sitting for sometime. The bike seems to run fine except the carbs leak fuel when it is running. I have cleaned the carbs thoroughly, purchased new needle valves, tried a different carb from another ninja, purchased a new pet cock, checked fuel for debris....all with no luck. What am i missing? Any ideas would be appreciated. |
May 10th, 2012, 09:23 AM | #2 |
Welcome Drew, where around the carbs is it leaking from? Fuel line, bowls somewhere else?
May 10th, 2012, 09:27 AM | #3 |
Thanks!
Sorry, leaking (a lot) from the overflow hose. |
May 10th, 2012, 09:35 AM | #4 |
The system for each carb is a simple valve operated by a float.
If the float freely floats, the neoprene in the valve is soft and the seat of the valve is not damaged, it must work and maintain the specified fuel level withing the bowl with the petcock open and with the engine off (and vacuum applied to the petcock) and with the engine working (vibrations).
May 10th, 2012, 09:40 AM | #5 |
Check the floats and float needles.
May 10th, 2012, 11:36 AM | #6 |
Ok well I've done all of that. Guess Ill keep trying.
May 10th, 2012, 12:01 PM | #7 |
More history please. Did this just happen all of a sudden? Has the bike just came out of storage?
May 10th, 2012, 04:12 PM | #8 |
Check if one of the floats leaks and sinks.
A way to verify that is to submerge it in hot water and check for any air bubble popping out.
FS: Motion Pro Syncpro Carb Tuner (Carb Sync) $60 Shipped | menikmati | Motorcycle-related | 4 | April 8th, 2020 12:39 AM |
2005 carb leaking | Firebrick | 1986 - 2007 Ninja 250R Tech Talk | 13 | April 23rd, 2015 03:51 PM |
Carb to Intake rubber boot clap leaking | joecool | 2008 - 2012 Ninja 250R Tech Talk | 1 | August 24th, 2014 08:17 AM |
Valve adjustment, carb clean, carb sync? | amad1972 | 1986 - 2007 Ninja 250R Tech Talk | 2 | July 29th, 2014 09:42 PM |
Really Weird carb Issue need more trouble shooting ideas | Virustech | 1986 - 2007 Ninja 250R Tech Talk | 11 | September 24th, 2012 06:35 PM |
