August 14th, 2013, 08:29 AM | #1 |
Join Date: Jan 2013 Motorcycle(s): 1987 Ninja 250 custom gold Posts: 218
Sprocket carrier bearing replacement
Hi all,
So i will be changing chain sprockets and bearings. I found out that the sprocket carrier has an exposed bearing, is that for a purpose or to reduce price? In any case, will it be possible to replace the sprocket carrier bearing with a sealed one, or will it cause me issues? |
August 14th, 2013, 11:08 AM | #2 |
Bump! Anyone know?
August 14th, 2013, 01:41 PM | #3 |
Join Date: Aug 2012 Motorcycle(s): Ninja 250 2001 Posts: A lot.
Not sure which part you're talking about for sure but if you mean the ball bearing closest to your front sprocket on the output shaft then yeah it's exposed. It's $15 new.....
I don't see anything wrong with a sealed bearing besides having some clearance issues. There is the same bearing on your input shaft fyi.
Mods: Offset clutch pressure plate |
August 14th, 2013, 05:00 PM | #4 |
Join Date: May 2013 Motorcycle(s): '92 GPX 250 (Gone and replaced with '08 V-Strom), 2005 Suzuki C50. Posts: 186
I think he is referring to the rear wheel sprocket carrier. I haven't checked, but I would have thought it would be a sealed unit.
August 14th, 2013, 10:32 PM | #5 |
August 15th, 2013, 03:48 PM | #6 | |
I might get the sealed ones and put them in there, if i do, i will get back to you guys. |
May 27th, 2014, 10:08 AM | #7 |
Are we talking about ball bearings? I don't recall the 1988-2012 sprocket carrier having ball bearings at all.
Sprocket Replacement? | kennetht | 2008 - 2012 Ninja 250R Tech Talk | 22 | April 6th, 2014 07:37 AM |
Help: Journal bearing replacement | cuong-nutz | 2008 - 2012 Ninja 250R Tech Talk | 2 | February 27th, 2014 09:39 PM |
FS: sprocket carrier bearings, extra seals 08+ | GlassAnkles | Motorcycle-related | 9 | June 24th, 2012 08:51 PM |
WTB: 08+ Sprocket Carrier and Cush Drive | SNAPPY | Items Wanted | 0 | April 4th, 2012 08:37 PM |
Chain/Sprocket replacement | 02ninjaeastbay | 1986 - 2007 Ninja 250R Tech Talk | 2 | June 12th, 2011 07:52 AM |
