April 1st, 2014, 09:33 PM | #1 |
Join Date: Oct 2013 Motorcycle(s): 2009 Kawasaki Ninja 250R Posts: 219
Sprocket Replacement?
When I was at my local shop today, one of the guys who works there took a look over of my bike and said it looks like my sprockets need replacing. And when replacing the sprockets, I need to replace the chain since the two go hand in hand.
Not sure if he is just looking to get some more work ($$$) out of me for my bike (I am going to be having new tires put on by them), or if he is correct. He was a really helpful guy giving me recommendations of tires, and showed me around the shop, so I doubt he is bsing me. He did say at the end that I could probably get another 2000-3000 miles out of it, but he wouldnt recommend it. Regardless, I still want to get a second opinion from you guys. Below is a picture of my rear sprocket. What do you think? |
April 1st, 2014, 09:34 PM | #2 |
It does look a little worn, but not terrible. How many miles on the chain / sprockets?
April 1st, 2014, 09:53 PM | #3 | |
at that point the bike had a bit over 8000 miles on it. assuming it is the original chain and sprocket that came when the bike was first bought. since purchasing the bike, i have probably put a couple hundred miles on the bike over the winter. (I am currently working on fixing the odometer) My best guess is that the bike has around 9000 miles on it and so does the chain/sprockets |
April 1st, 2014, 09:56 PM | #4 |
in regards to the chain, is appears to be in bad shape (lots of rust). when i bought the bike i cleaned the chain the best i could (practically removed all the rust, and then lubed it up like crazy). Over the past 3 months she has gotten really rusted again. Looks like im going to have to pull out that wire brush and polish her up a bit and reapply the lube.
the previous owner really did not maintain the bike very well. because of that i got it for a steal. |
April 4th, 2014, 06:53 AM | #5 |
anyone else have any input?
April 4th, 2014, 07:01 AM | #6 |
If your trying to maximize chain/sprocket life then yea... replace as a set so they wear together. Otherwise, replace individual parts needed. I personally wouldn't replace it just yet, it just looks like it needs cleaned up. A little wire wheel on a cordless drill should have that thing looking shiny new again in a few minutes.
April 4th, 2014, 07:06 AM | #7 |
dirty boy
MOTM - Apr '14
chains will rust, no way around it, keep up on maintenance of it and measure stretch to determine how beat up the chain is.
Your sprocket looks ok as long as you want to continue using your current chain, however if you are going to replace either or just do it all, front, rear and chain at once and be done with it. + this way you don't have to worry about a beat up sprocket messing up your new chain or other way around. If you are strapped for cash you would be ok for a bit yet, but if you have the money just replace everything and be happy and content knowing it is all good. edit: apparently I need to be a little quicker putting my thoughts into text, @csmith12 ninja'd me
April 4th, 2014, 07:17 AM | #8 |
Fast-Guy wannabe
MOTM - Jan '13
Nooooooo wire brush please. The stock chain and any chain worth putting on a street bike has O-rings between the plates to retain the original grease. If you wire brush the chain you will damage the O-rings and the grease will escape, then it'll be trash. Exterior rush won't really effect anything as long as you take care of the chain from now on. If your adamant about making it look pretty again then try a stiff scotch bright instead with a little lube. The scotch bright will leave granules of abrasive material all over the chain so pressurized can of degreaser with the spraying force of a can of brake clean but a chemical that's no so harsh with displace a lot of the crap left over without forcing grease out of the O-rings. Some "light" pressurized air to finish cleaning the chain then relube and your done.
April 4th, 2014, 07:25 AM | #9 |
Dang... I guess I wasn't clear enough, my bad. The OP stated a new chain was getting installed. Not really sure why anyone would use a wire brush on a chain, much less a new one. I was referring to the sprocket.
April 4th, 2014, 07:32 AM | #10 | |
thanks for the response. |
April 4th, 2014, 07:32 AM | #11 | |
dirty boy
MOTM - Apr '14
You did say "it looks like it just needs cleaned up", OP only posted a picture of sprocket
April 4th, 2014, 07:33 AM | #12 | |
April 4th, 2014, 07:35 AM | #13 | |
April 4th, 2014, 07:35 AM | #14 |
It's all good, rojo posted some good info. Sadly, I have watched my neighbor clean his chains (4wheelers) with a wire brush.
April 4th, 2014, 07:37 AM | #15 | |
Fast-Guy wannabe
MOTM - Jan '13
April 4th, 2014, 07:54 AM | #16 |
I see what you mean. I will be sure to do it lightly, and pay very close attention to make sure it does not get near the o-rings
April 5th, 2014, 12:44 PM | #17 |
dirty old man
Join Date: Nov 2008 Motorcycle(s): Blue '08 Ninja 250 Posts: A lot.
since we are on the subject of chains and sprockets, I am in the process of replacing both sprockets and the chain. Any body know what size the nut holds the sprocket on? I know it is metric, and larger than 19mm.
TIA nb
Death tugs at my ear and says, "Live, I am coming." -Oliver Wendell Holmes, Sr., poet, novelist, essayist, and physician (1809-1894) www.friendsofsanonofre.org |
April 5th, 2014, 01:35 PM | #18 |
Fast-Guy wannabe
MOTM - Jan '13
I just did this but I'm not 100% but my gut says 14mm wrench.
April 5th, 2014, 02:07 PM | #19 |
dirty old man
Oopps, forgot to add, front sprocket.
Thanks, Jason, now I know what to use on the rear. nb
April 5th, 2014, 03:44 PM | #20 |
Join Date: Aug 2013 Motorcycle(s): 2012 Ninja 250 Posts: 450
Front sprocket is a 27mm, i had to buy one to change mine.
Invest in a good chain beaker/riveter like the D.I.D. http://www.ebay.com/itm/DID-Chain-To...ab00b5&vxp=mtr I got the D.I.D chain and sprocket kit which is excellent IMO. http://www.amazon.com/D-I-D-DKK-013-.../dp/B00G9TJX6I Switched from chain oils to Maxima's chain Wax which is so much cleaner and keeps the chain looking like new. |
April 5th, 2014, 08:08 PM | #21 | |
dirty old man
Got a chain breaker a while back, this will be the first time that I get to use it. Not sure but I think that the only chain lube that I have used is the Maxima, that's good stuff. nb
April 5th, 2014, 10:04 PM | #22 |
There isn't enough room for a wrench, so i got the socket.
April 6th, 2014, 07:37 AM | #23 |
dirty old man
Thanks Skullz.
nb
Sprocket carrier bearing replacement | The_big_dill | 1986 - 2007 Ninja 250R Tech Talk | 6 | May 27th, 2014 10:08 AM |
JT Sprocket 42 tooth Rear Sprocket | lolibater | Motorcycle-related | 36 | February 25th, 2013 12:30 PM |
Chain/sprocket replacement question (I forgot) | headshrink | 2008 - 2012 Ninja 250R Tech Talk | 3 | September 19th, 2011 11:24 PM |
Chain/Sprocket replacement | 02ninjaeastbay | 1986 - 2007 Ninja 250R Tech Talk | 2 | June 12th, 2011 07:52 AM |
