Old September 28th, 2014, 07:02 AM   #81
Ducati999
Motorcycle(s): Ducati 999 2012 Ninja 250r Ducati748 Yellow finally running 2003 SV650 S (SOLD)
Wings of that small size will only give a marginal down force at high speed. The aerodynamics of the fairing dont get efficient till over 90 mph when the air flow (with rider crouched over tank) smooths out and will flow smoothly over the wings-- so cornering at high lean angle will not be effected. Running wide open in a straight line will give more down force to help keep the front down but when the rider sits up this will negate any effects the wings may cause. Also since the bike is leaned over in a turn and not going straight there will be a lot of turbulent airflow not smooth airflow over the wings so they will be much less efficient at lean. I believe Kawasaki did their home work (wind tunnel testing) and they are there to help keep the light weight high power bike on both wheels while accelerating hard in a straight line, no "active" control needed!
Ducati999 is offline   Reply With Quote
Old September 28th, 2014, 07:33 AM   #82
Originally Posted by Ducati999 View Post
The aerodynamics of the fairing don't get efficient till over 90 mph when the air flow (with rider crouched over tank) smooths out and will flow smoothly over the wings-- so cornering at high lean angle will not be effected.
Yes and no. Airflow doesn't magically just smooth out; where the fairing is 'efficient', as you call it, depends on the shape of the bike. The shape determines where turbulence begins over the body, and how turbulent the flow becomes. Theoretically, you could make a small turbulent layer form right at the trailing edge of the windscreen to force air to curl back down with the back of the rider and fill in the void left after the tail of the bike. This would increase skin drag, but it will be tiny in comparison to the reduction in form drag. I initially doubt the engineers would make this magic break even point at a speed as high as 90 mph, but maybe. It is a SS, that is meant to be lapping tracks at 90-110 avg speed, after all.
However, if those wings are on the front, they will almost always be encountering 'smooth' airflow that has not yet been disturbed by flow from other portions of fairing. This means they will always be working. But none of this has anything to do with lean angle because the bike leans about the lengthwise axis of the bike, the same axis that the flow travels along. The angle of attack never changes based on lean angle.
Lean angle has no effect on the smoothness of the incoming air. As long as the bike is traveling in the same direction is is pointing, not sliding sideways at some angle of attack, the aerodynamic properties of the vehicle will be the same. Think about it, the air is moving along the lengthwise axis of the bike, regardless of the lean angle or turning rate. The only thing that changes the angle of attack with the oncoming wind is if the bike is traveling into the wind, but pointing a different direction, aka, sliding. As long as the bike is traveling forwards, the wings will have an effect.
I think what you're missing is that while the bike does change direction while turning, unless it is sliding, it never changes direction relative to the ground below it and the air in front of it. Without cross wind, the nose of the bike will always feel wind coming directly at it with a zero angle of attack, regardless of lean angle or turn rate. The same can be said for the ground traveling past the wheels. Unless the wheel slides sideways, the ground will always travel the same direction relative to the wheel.
http://en.wikipedia.org/wiki/Angle_of_attack
http://en.wikipedia.org/wiki/Turbulence
Old September 28th, 2014, 08:14 AM   #83
Ducati999
I agree with what you said totally I just expressed it in extremely simple terms so everyone could understand. I was lazy and did not want to dig up the facts from my aero/hydro dynamics classes. Thanks for the details though i believe it will help people further understand what was being said.
Old September 28th, 2014, 09:26 AM   #84
Jono
Jono's Avatar
I'm sure Kawasaki will tell us exactly what they are trying to do with these wings on the 30th!
Like the Duc, I'm sure the side winglets have more to do with cooling the engine than changing the downforce.
Old September 28th, 2014, 10:55 AM   #85
^^^ I would bet that we get marketing mumbo jumbo instead of a technical explaination, but hey.
Old September 28th, 2014, 12:53 PM   #86
Jono
Jono's Avatar
Well of course. They have to dumb it down for all the squids who want this crazy fast bike with wings.
Old September 28th, 2014, 05:49 PM   #87
Aggrotech
Aggrotech's Avatar
Motorcycle(s): 12' Ninja 250
Think ill buy it, paint it the Redbull colors, get sponsored by them and get paid by just riding around.
win/win
Aggrotech is offline   Reply With Quote
Old September 29th, 2014, 09:48 AM   #88
From reddit today; this is supposed to be a front shot.
Old September 29th, 2014, 09:50 AM   #89
Sirref
Private Joker
Sirref's Avatar
MOTM - Mar '14
they put the wrong logo on the front, they clearly meant for it to be a decepticon logo
Old September 29th, 2014, 10:03 AM   #90
garth285
KAWASAKI GURU
garth285's Avatar
Alex, where on reddit did ya find that?
Old September 29th, 2014, 10:16 AM   #91
Jono
Jono's Avatar
Badass! Photo looks legit!
Old September 29th, 2014, 12:11 PM   #92
Aggrotech
Aggrotech's Avatar
wouldnt even be street legal since theres no lights, right?
Old September 29th, 2014, 12:11 PM   #93
xorbe
xorbe's Avatar
So it's gonna be a track only machine. ^^^ What he said.
http://www.reddit.com/r/motorcycles/...h2_front_shot/
Old September 29th, 2014, 12:13 PM   #94
garth285
KAWASAKI GURU
garth285's Avatar
That picture could be of the "race" version if they are doing that
Old September 29th, 2014, 12:54 PM   #95
subxero
dirty boy
subxero's Avatar
MOTM - Apr '14
leaked photo, it was only a matter of time before the bikes caught up to the cars
Old September 29th, 2014, 03:07 PM   #96
Jono
Jono's Avatar
But why have mirror wings if it's not for the street? Mmmmmm
Old September 29th, 2014, 03:42 PM   #97
subxero
dirty boy
subxero's Avatar
MOTM - Apr '14
Old September 29th, 2014, 03:49 PM   #98
xorbe
xorbe's Avatar
Hopefully tomorrow the Ninja H2 details are out, also the Honda HR-V details.
Old September 29th, 2014, 04:10 PM   #99
i see no mirrors.
Old September 29th, 2014, 04:26 PM   #100
snot
sammich maker
snot's Avatar
MOTM - Apr '15
Is it the 30th in japan now? Who do we need to kick out of bed to unveiled this wonderful machine?
Old September 29th, 2014, 04:42 PM   #101
Jono
Jono's Avatar
i see no mirrors.
I stand corrected. I was looking on my phone earlier and I thought the wings by the windscreen double as mirrors. Now that I am on the computer I can clearly see that's not the case.
This is going to be one expensive track toy!
Old September 29th, 2014, 05:46 PM   #102
Brother Michigan
Motorcycle(s): 2013 Ninja 300
Hnnnngggggg...
http://lanesplitter.jalopnik.com/the...ane-1640558028
DISCLAIMER: I generally have no idea what I'm talking about.
Old September 29th, 2014, 06:02 PM   #103
Jono
Jono's Avatar
Wicked!
Old September 29th, 2014, 06:06 PM   #104
Jono
Jono's Avatar
Old September 29th, 2014, 06:33 PM   #105
Jono
Jono's Avatar
Many more photos here: http://www.ninjah2.net/threads/ninja...f-intermot.46/
And rumor is 300HP!
Old September 29th, 2014, 06:46 PM   #106
Its badass. But it's uglier than a buttcrack Afro...
Old September 29th, 2014, 06:55 PM   #107
Jono
Jono's Avatar
Looks better than a pregen.
Old September 29th, 2014, 06:58 PM   #108
Touché sir. *backs out of the room slowly*
Old September 29th, 2014, 07:00 PM   #109
Aufitt
The A Team
Aufitt's Avatar
Motorcycle(s): Z50, CB125, RZ500, MC22, R3.
So a 17 year old with every garish anodized turd from the Bikers catalogue on his Ninja 300 designed his dream bike.
Aufitt is offline   Reply With Quote
Old September 29th, 2014, 07:06 PM   #110
Sirref
Private Joker
Sirref's Avatar
MOTM - Mar '14
I'd rock this bike but you can really tell who their target audience with the styling is :/
the hp4 looks better to me and I'm not the biggest fan of the asymmetrical look
Old September 29th, 2014, 07:07 PM   #111
kdogg2077
kdogg2077's Avatar
Motorcycle(s): 2015 Yamaha FZ07, Ninja 250r 2012 Limited Edition (Sold)
I didnt know Michael Bay designed bikes in his spare time. I swear Shredder rode this in the new turtles "movie".
"Take it easy driving. The life you might save might be mine."
kdogg2077 is offline   Reply With Quote
Old September 29th, 2014, 07:50 PM   #112
xorbe
xorbe's Avatar
US$25K? Less? More?
Old September 29th, 2014, 08:04 PM   #113
Brother Michigan
Much more, at least for the H2-R.
Old September 29th, 2014, 08:14 PM   #114
Jono
Jono's Avatar
I'm gonna guess that the street legal H2 won't have a carbon fiber front fairing. Who knows. Maybe there won't even be a street legal version.
Old September 29th, 2014, 08:32 PM   #115
I am trying to figure out why all the wings and getup at the top and no lower?!?!?!?
Old September 29th, 2014, 09:04 PM   #116
Sirref
Private Joker
Sirref's Avatar
MOTM - Mar '14
looks like 2.5 sets, one up top that could double as mirrors on a road version one in the middle that could double as turn signals and about mid way down, why would they put one low when it could impact ground clearance?
Old September 29th, 2014, 11:08 PM   #117
KawiKid860
KawiKid860's Avatar
Errrrmm... Wings actually produce quite a bit of drag. The trade off for downforce...
You're absolutely correct, but don't cars have superior downforce to bikes too...? So wouldn't more downforce still translate to better aerodynamics, provided downforce was the goal not top speed?
Either way, I read these wings were there to break up stagnant air and provide better cooling to the engine/supercharger.
Old September 29th, 2014, 11:25 PM   #118
first of all, the cross section of a bike is about 1/5th of a car. the drag on a car is much higher regardless of a more aerodynamic shape.
secondly, ... "break up stagnant air and provide better cooling"? ...... care to elaborate on those thoughts?
Old September 29th, 2014, 11:28 PM   #119
i'm not gonna lie though.
that is one ****ing ugly bike. like holy **** they beat that thing with the ugly stick until it had no face left.
the 90s called and want their styling back
Old September 29th, 2014, 11:38 PM   #120
KawiKid860
KawiKid860's Avatar
Not my thoughts, read it somewhere else so
[visordown.com] - Kawasaki’s supercharged four-cylinder engine Ninjette Newsbot Motorcycling News 0 November 20th, 2013 12:30 PM
[visordown.com] - Victory anniversary bike launch this month Ninjette Newsbot Motorcycling News 0 January 8th, 2013 11:00 AM
[topix.net] - TVS Motor to launch '125cc' Phoenix this month Ninjette Newsbot Motorcycling News 0 September 12th, 2012 02:50 PM
[visordown.com] - Supercharged 90bhp 100kg Cagiva Mito Ninjette Newsbot Motorcycling News 0 June 18th, 2009 01:20 PM
[visordown.com] - Classic supercharged Vincent sells for £200,000 Ninjette Newsbot Motorcycling News 0 October 20th, 2008 07:10 AM
