Old December 31st, 2011, 04:11 PM   #1
zCasanova
zCasanova's Avatar
Motorcycle(s): '10 Ninja 250r
Replacing Turn Signal Bulbs
I'm having trouble finding replacements for a turn signal bulb that stopped lighting a few days ago.
I'm not looking for another amber bulb, but a clear one.
I've tried all of the auto stores in town, but none of their bulbs will fit due to the odd location of the tabs on the sides of the OEM bulbs.
Where the aftermarket's are directly across from each other, the ninja's are slightly offset from the center.
I read that it is possible to grind one of the tabs off, but I'm worried that the bulbs may vibrate out of its socket while riding.
I have found sites on the web where I can order new bulbs, but like I mentioned before, I'm looking for a clear bulb, not amber.
Any suggestions would be greatly appreciated.
zCasanova is offline   Reply With Quote
Old December 31st, 2011, 11:32 PM   #2
Welcome Devin,
After much trial and error, I finally found some that fit at autozone in their marker light section. I had to take the turn signal housing with me as a complete unit. The very helpful man behind the counter even opened packages to ensure proper fit and water tightness of the amber cap.
Best of luck, it wasn't easy for me either.
Old January 1st, 2012, 08:59 AM   #3
zCasanova
zCasanova's Avatar
Do you remember what the brand or bulb # was?
Old January 1st, 2012, 10:10 AM   #4
Lemme check, not sure if I still have the packaging.
Old January 1st, 2012, 01:06 PM   #5
zCasanova
zCasanova's Avatar
Bulb # would be on the bulb if you don't have the packaging.
Turn signal mounting plate replacing...HELP rph12 1986 - 2007 Ninja 250R Tech Talk 5 March 8th, 2012 09:48 PM
Honda Clear Alternative Turn Signal Lenses & Bulbs dubojr1 Motorcycle-related 2 December 8th, 2011 02:31 PM
Removing the turn signal bulbs rmacgillis 2008 - 2012 Ninja 250R Tech Talk 12 October 10th, 2011 08:35 AM
I need help replacing my turn signal on my ninjette! venmichaels 2008 - 2012 Ninja 250R Tech Talk 8 August 12th, 2011 10:46 PM
2008+ turn signal bulbs azimmer11 2008 - 2012 Ninja 250R Tech Talk 2 August 4th, 2011 07:28 PM
