Old February 4th, 2014, 05:14 PM   #1
Bob2010
Bob2010's Avatar
Any good proven stands?
Look at this on eBay:
Motorcycle Stand Front Triple Tree & Rear Spool Stands, Head Lift
http://bit.ly/17V6yTl
AND
Motorcycle Stands, Front and Rear Set, Front Forklift, Rear Spoollift Paddock
http://bit.ly/1jWzMbv
I have 2 bikes but need at least 1 rear and 1 front
I could buy blindly but figure I would ask what people have used and what works best.
For example this eBay ad asks for pin size ? What is that
2010 Red Ninja 250
2009 Black Ninja 250
Old February 4th, 2014, 05:47 PM   #2
bkh2
bkh2's Avatar
Motorcycle(s): 2006 GSXR 750; 1983 CB750SC
The front triple tree stand works better if you want to do work on the forks. As you can imagine, the other style depends on the forks to keep the front end up.
The pin size is normally required for the triple tree stand style. The pin goes inside the head tube, partly for alignment, and partly so the bike doesn't fall off the stand. Note that the front stand should typically only be used in conjunction with (and after) the rear stand has been set.
bkh2 is offline   Reply With Quote
Old February 4th, 2014, 06:54 PM   #3
Boosted139
Motorcycle(s): 2009 Ninja 250R SE, 2009 Triumph Daytona 675
Pitbull. Are they on the expensive side? Yes. Will they last longer than your motorcycling career? Yes. I own other name brand stands as well and the Pitbull are just nicer. They are easier to lift (the leverage required is next to nothing compared to my woodcraft) and they have withstood a lot more abuse and are in better shape than others.
Boosted139 is offline   Reply With Quote
Old February 4th, 2014, 07:10 PM   #4
^^^ yep
Pitbull
T-Rex
Even the cheap rear stand from Harbor Freight
Old February 4th, 2014, 07:24 PM   #5
Bob2010
Bob2010's Avatar
Ok thanks for the feedback. Soo I see now these work with "spools". Don't know how I over-looked that one. I guess when I decided to not go with frame sliders because the reviews were horrible (both install and After crashing ) I forgot about these.
I see Yoshimura and other brands $40 a set. Is that normal?
2010 Red Ninja 250
Old February 5th, 2014, 06:15 AM   #6
Yea, pretty normal. I have some cheap HF spools on my race bike. Not really all that pretty but look "ok" and they work very well.
Pro Tip* - If you get spools, work them in and out slowly until they are seated all the way. Paint in the threads can make this seemingly easy job a HUGE pain the arse.
Old February 5th, 2014, 07:50 AM   #7
DCMoney
DCMoney's Avatar
I've owned the cheaper stands and have gotten rid of all of them, all I own is putbull now.
Watch craigslist for used stands, that's were I've bought most of mine.
My wall of stands, plus two being used to hold up race bikes not shown.
MCRA.com
Old February 5th, 2014, 09:04 AM   #8
Aodrn
It's a long boring story
Aodrn's Avatar
Motorcycle(s): 2012 Ninja 250
I actually like my HF rear stand, but I cant find adaptors to use my spools. Maybe I am looking in the wrong places?
#41 MCRA
alex.s :crashing is a normal part of life... people are just in denial about that.
Aodrn is offline   Reply With Quote
Old February 5th, 2014, 09:09 AM   #9
What spools do you have?
Old February 5th, 2014, 09:11 AM   #10
Aodrn
Aodrn's Avatar
I dunno. I have a correct sized bolt going through some generic spools off a gsxr I think. Fairly small.
#41 MCRA
Old February 5th, 2014, 09:22 AM   #11
I guess I will need to see a pic. I haven't seen any adapters that might work with the HF stand.
Old February 5th, 2014, 09:47 AM   #12
Aodrn
Aodrn's Avatar
The HF stand came with paddles. I wanted to get spool hooks.
#41 MCRA
Old February 5th, 2014, 09:51 AM   #13
OH! You have the paddle stands. HF also makes a hook style stand as well. If you get some good coupons, you should be able to land one for about a $10 spot. I think that would be a better spend of $$ than finding adapters.
Old February 5th, 2014, 10:22 AM   #14
rasta
Your face
rasta's Avatar
+1 for Pitbull. Expensive, but you get what you pay for. I like the triple tree stand, I just never trusted the fork stand.
Old February 5th, 2014, 10:56 AM   #15
Aodrn
Aodrn's Avatar
I found this
http://www.harborfreight.com/low-pro...and-99701.html
If I can find a pit bull stand for cheap, I would go that direction. Chicks dig good gear right?
#41 MCRA
Old February 5th, 2014, 11:03 AM   #16
That's it Ryan. Find a 50% or 70% coupon and pick it up much cheaper.
For sure on pit bull, good luck finding them cheap .
Old February 5th, 2014, 11:22 AM   #17
Klondike1020
Intrepid Adventurer
Klondike1020's Avatar
MY stand is a Grieves I think? I got it for free. fit a r6. I bent it to fit my 250 and bent it back to fit my GSXR.... its all aluminum and works nice!
!TIRE machinE - sooo nice
you have a serious shop....
I was considering giving up my hand powered Harbor freight tire machine for one of those get ups
Do you get your use out of it?
I DIG the SWEET phone charging station ! that is the best shop mod yet lol
Old February 5th, 2014, 12:34 PM   #18
DCMoney
DCMoney's Avatar
Ha thanks!
I advertise tire changes on craigslist and was using a NoMar changer till I had enough money made from doing changes to purchase this machine, even in this cold weather I still do at least a tire change a week, some times 3 depends.
During riding season I was averaging 10 tires a week.
That's in my garage at home too.
Its a life saver! watch this if you really want to hate your manual machine...
MCRA.com
Old February 5th, 2014, 03:04 PM   #19
Klondike1020
Intrepid Adventurer
Ha thanks!
WHOA maybe I should buy the setup the guy offered me ?>
I didnt know you could do bike tires on this thing!!!!!
what !
I want it!
this is the one I was looking at?
DO these do the same ?>
http://www.northerntool.com/shop/too...FStgMgodIWUADQ
http://equiptool.com/i-5048905-range...-balancer.html
Old February 6th, 2014, 07:21 AM   #20
DCMoney
DCMoney's Avatar
what !
I want it!
PM sent to not derail even more...
Watch craigslist for pitbull stands, I've gotten 2 of there for 75 each.
MCRA.com
[motogp.com] - Zeelenberg: ‘Lorenzo has proven he is back’ Ninjette Newsbot Motorcycling News 0 June 4th, 2014 03:02 AM
Group buy on proven 415 chain/sprocket setup!!! Order Ninjettes At Speed 103 September 27th, 2011 06:33 PM
Went down pretty hard today! Handroids, crash proven jamesio !%@*#$%!)@#&!%@ I crashed! 72 September 25th, 2011 12:53 PM
[sportrider - latest stories] - FogShield Sport: An Anti-Fog Treatment With Proven Re Ninjette Newsbot Motorcycling News 0 February 10th, 2011 02:30 PM
[roadracingworld.com] - Sachsenring Has Not Proven To Be A Good Venue For Alice Ducat Ninjette Newsbot Motorcycling News 0 July 8th, 2008 09:55 AM
