Old April 18th, 2013, 02:44 PM   #1
fishdip
fishdip's Avatar
Motorcycle(s): 250/300
Crank but no start
02/250
So I decided to do the valves/clean the carbs and sync them since I had them off. All went well tell it was time to start it. It will crank over but I can not get it to start. Yes I put gas back in the tank as I pulled it off and clean it out I can also see the fuel flowing in to the carbs out of the inline fuel filter.
The battery has a good charge and the bike was running before I started this work last night.
Any ideas you got I am willing to try it thanks in advance.
Old April 18th, 2013, 02:52 PM   #2
Joshorilla
Bass Master General
Joshorilla's Avatar
Synced carbs and valves ey, do it again, but this time properly.
Old April 18th, 2013, 03:01 PM   #3
fishdip
fishdip's Avatar
What do you mean I followed the shop manual to the T?
Old April 18th, 2013, 03:27 PM   #4
Lychee
sail away
Lychee's Avatar
Would start if you did. Spark, fuel, compression. Check for all. How did you sync without a running engine?
Old April 18th, 2013, 04:15 PM   #5
fishdip
fishdip's Avatar
In the book it tells you to do a visual sync with them off.
Old April 18th, 2013, 04:50 PM   #6
Lychee
sail away
Lychee's Avatar
Well, if you have ruled out spark and fuel, then the only thing left is compression. The valve adjustment directly affects this. Perhaps you should do as Joshorilla suggests and have at it again. Check that you are using the proper size feeler gauges. When you finish with the adjustment and get the engine going again, you should sync the carbs using a vacuum meter of some sort. This is to account for any imperfections between the intake valve clearances. There are many different ways to do this, the simplest is with a long tube with liquid in it.
http://faq.ninja250.org/wiki/How_do_..._the_valves%3F
http://faq.ninja250.org/wiki/How_do_...carburetors%3F
Old April 18th, 2013, 05:10 PM   #7
Asspire
Fix It Till Ya Break It
Asspire's Avatar
Motorcycle(s): 08 250RRrrrr
did you plug in the ignition coils (and correctly)?
I may know of some who had the same problem once.....
Old April 18th, 2013, 06:42 PM   #8
fishdip
fishdip's Avatar
Thanks for the reply guys I got it to run after reading how much it takes to get a carb engine to start I went and got a new battery and it fired on the first push of the button. I think the battery had a gone bad as I had it on a trickle charge all night last night. I plan to fine tune the sync now that its running. I all ready made one with the bottle and stopper off that page.
Old April 19th, 2013, 09:07 AM   #9
Lychee
sail away
Lychee's Avatar
Old April 20th, 2013, 07:58 PM   #10
Poogamer69
Ninja bot
Motorcycle(s): Ninja 300
So it was just the battery and nothing to do with any of these:
Tell you what for a site that advertises as being "The friendliest Kawasaki Ninja 250R site", you guys are very arrogant and sarcastic.
Poogamer69 is offline   Reply With Quote
Old April 20th, 2013, 10:20 PM   #11
Lychee
sail away
Lychee's Avatar
I'm sorry that you feel like that. However our suggestions were sound advice based on the information provided to us. A valve adjustment done incorrectly could lead to a non starting engine. The fix would be to take it back apart, redo the adjustment and put it back together. Also, the OP ruled out the battery in the original post. We on the internet have to assume his ruling to be correct. Love your screen name by the way. Welcome to the site!
Old April 20th, 2013, 11:03 PM   #12
It's a troll account. Ignore him.
Old April 20th, 2013, 11:14 PM   #13
fishdip
fishdip's Avatar
Yep just the battery I did not even think it been the battery at first since I had it on the charger all night and did not look at it when I had taken it off.
Old April 22nd, 2013, 07:31 PM   #14
Poogamer69
Ninja bot
No not a troll account at all. I will just ignore you. I quite often come and have a look but I feel no need to post unless I think I can add some value. Thanks for the info that I have taken away with me from the site to date anyway.
Old April 22nd, 2013, 07:45 PM   #15
Oh really?
I think your a bit new here.........
^^So this added value??
Great first post.
Old April 22nd, 2013, 09:02 PM   #16
Poogamer69
Ninja bot
Yep. Funny that you only chimed in on this one to say I was just a troll account, ignore him. Way to boost the post count. Just because I have only 1 or 2 posts, dont mean **** it just means I can get what I need from the site without the need to post anything. If I decide to post about the arrogant tone of some of the responses, I am more than free to do so. Just as people are more than free to post arrogant responses.
Who cares what my first post was anyway? Do you troll much?
Again, thanks for the info that is already here and what I have taken away with me from reading.
Old April 22nd, 2013, 09:16 PM   #17
Old May 29th, 2015, 02:09 AM   #18
jkaiser209
Motorcycle(s): 07 Kawasaki Ninja 250 R
my ninjas cranking over but no start and has no spark in the spark plugs in both of t
I have an 07 Kawasaki Ninja 250r and I got it from a friend and it doesn't start he said the ignition box Was bad so I went and bought a new one I put it on try to start it no action So I check the spark plugs to see if any spark So should I just checked the coils and see if its that as gas too and good battery
jkaiser209 is offline   Reply With Quote
Old May 29th, 2015, 08:00 AM   #19
Welcome Jacob! Hope you get your bike sorted soon.
No Crank Gavin_Coffey 1986 - 2007 Ninja 250R Tech Talk 5 March 16th, 2015 01:57 PM
99' ninja wont crank cream 1986 - 2007 Ninja 250R Tech Talk 16 March 13th, 2015 05:07 PM
Another bike will crank but won't start thread... remix919 2008 - 2012 Ninja 250R Tech Talk 10 May 12th, 2014 01:05 PM
bike won't crank!! LoneRonin 2008 - 2012 Ninja 250R Tech Talk 14 September 5th, 2011 04:19 PM
WTB Crank set porschepatrick912 Items Wanted 1 January 20th, 2010 03:32 PM
