Go Back   ninjette.org > General > !%@*#$%!)@#&!%@ I crashed!
Old January 3rd, 2014, 11:35 AM   #81
jefe305
Motorcycle(s): ninja 250
Originally Posted by EsrTek View Post
Could've been anything in road really that caused the loss of traction while braking...it may not even be how you braked. A combination of things is usually the cause.
If you didn't survey the scene at the time, going back may help shed some light.
True there was construction going on right up the road, could of been some debris where I fell. Also the scratches on my bike are kind of uneven almost as if it slid on some tiny rocks or something. I couldn't see the scene at the time but when I'm better I'll definitely go back and take a look. I would feel so much better knowing this accident wasn't entirely from rider error.
jefe305 is offline   Reply With Quote
Old January 3rd, 2014, 11:59 AM   #82
ally99
Ninja chick
ally99's Avatar
Motorcycle(s): '13 Ninja 300
MOTM - Dec '13, Feb '15
Hmmmm, I wouldn't say that is always true. "Too much" is relative to the amount of traction the tire has. In the case of low traction, "too much" is achievable by even the newest of riders.
I think it's a common mistake for noobs to panic in midcorner and hit the brake. Leaned over at high speed is a recipe for too much braking, in which case, could easily result in a crash.
Postwhores are COOL! ~Allyson
Old January 3rd, 2014, 12:02 PM   #83
ally99
Ninja chick
ally99's Avatar
Mitchell,
Definitely check out Keith Code's Twist of the Wrist. His first important rule (he calls the survival reactions) is to set your speed and no matter what, continue with a steady roll-on of the throttle throughout a corner. He advises to say it to yourself 1000 times and start practicing to develop the good habit. It's all about entry speed...set that right and there will never be a need for brakes. Braking in a corner does the opposite of what you want it to do anyway.
Old January 3rd, 2014, 02:13 PM   #84
jefe305
true, but I didn't crash because of that lol
Old January 3rd, 2014, 02:18 PM   #85
jefe305
Mitchell,
Yep, I actually do very well with corners maybe because I don't have a fear of leaning. My first time riding on public streets I went with some friends out to Red Rock Canyon 30 miles each way on 3 different highways plus plenty of riding around out there.
Old January 3rd, 2014, 03:30 PM   #86
She has been around long enough to know. I am pretty sure she was just responding to me anyway.
You crashed because you put yourself and the bike in the position to crash. Simply stated from your own posts, one or more of a few main factors where at play here;
Night....
Empty lane next to slow/stopped traffic (invites getting pulled out in front of)
Following to close?
Tried to accelerate past a car at a bad time?
Handful of front brake?
Locked rear brake?
Speed? (80-100ft is a loooonnnng way for a bike to slide)
The car came out of nowhere?
The car tried to merge in your lane as you were beside it?
Construction and possible debris on the pavement?
That is a lot of possible negatives happening at the same time. Possibly you were a bit complacent at the time?
While you may be able to handle the corners just fine, at the ripe old age of 21... learning to read, predict and react to traffic can be a bit more of a challenge. Sometimes patience is a virtue and cagers do some of the dumbest things.
Again, we wish you a speedy recovery to you and the very best of luck when you throw a leg over. It's a good sign your taking the time to reflect on what and why it happened.
Old January 3rd, 2014, 03:33 PM   #87
..............I brake hard to avoid hitting him locking up my brakes losing control and falling. I hit the ground on my left side and my bike continues to slide about 80 to 100 feet. I broke my left ankle in 3 places, sprained right wrist, and some mild road rash that went thru my gloves, pants, and leather jacket....................However what I don't get is when I hit the ground my head and shoulders never touched it, my left ankle took all the impact and I slid to a stop. If I grabbed to much front brake the bike would of swept under me and I should of hurt of arms and shoulders.
Yes, sorry, Mitchell; I confused your lesion with someone's else.
Please, disregard the previous lecture about the collar bone.
You are correct, in your case, it looks like the rear tire went into a skid, then the rear tried to catch up with the front swinging CCW and the left side of the bike trapped your left ankle against the road.
Your ankle probably got liberated before the bike slid those 80~100 feet and you rolled and slid on your own, damaging other body parts.
Regardless of the reason that initiate it, there are two types of low-side falls:
Due to front tire tucking (described in previous post): Note the pure lateral fall of the rider's body (hence the typical Clavicle damage:
And due to rear tire skid: Note the more mushy fall of the rider's body, with his but still connected to and following the seat that moves down and away from him, while his ankle becomes sandwiched by the bike and road:
A backpack tends to protect the upper back, shoulder and head in this type of fall.
Did you wear one that night?
Old January 3rd, 2014, 03:35 PM   #88
lol, Remember this day, Hernan got some links mixed up from his massive collection.
Old January 3rd, 2014, 03:41 PM   #89
n4mwd
n4mwd's Avatar
Originally Posted by Motofool View Post
The frontal support of the bike is violently swept from under you and the combined weight of the bike and rider slams the ground also violently.
Your shoulder receives a strong g force upon impact, which translates into a high compressive stress that shatters the collar bone, which is acting as a column between your shoulder and the rest of your upper body.
"The most common type of (Clavicle) fractures occur when a person falls horizontally on the shoulder."
http://en.wikipedia.org/wiki/Clavicl...nism_of_injury
Which is also a good argument for wearing a jacket with CE armor. Its not perfect, but it definitely helps.
If the front locks, which is rare on clean, dry pavement, you can recover just by letting go. But only if you let go before you lose control. Which can happen pretty fast given that the gyroscopic effects of the front wheel are what is holding the bike up.
Locked wheel rules: Front - let go immediately, Rear - ride it to a stop.
Knock on wood, I have never locked my fronts but have locked the rears a few times when I was a newbie. I've had numerous panic stops where I was to heavy on the front, but when then go wrong, they usually result in a stoppie - which is not good either because the rear brakes are no longer helping you stop - but better than a lockup. Very upsetting when you aren't expecting it.
My Ninja Blog
Old January 3rd, 2014, 05:10 PM   #90
Yes, sorry, I got confused with Deejay's accident the day before Christmas
Originally Posted by ranma3030 View Post
So it happened again. The day before Xmas eve I went down for my second time............
Soft tissue damage in my left hip. (Really hurts to move my leg) and fractured my collarbone in a few places......
Old January 3rd, 2014, 08:23 PM   #91
jefe305
No problem, man his sounds bad too. And right before the holidays I know how that feels sucks big time.
Old January 3rd, 2014, 08:33 PM   #92
jefe305
Yeah the second one looks exactly like what happened to me. When I practiced quick stops in a parking lot I couldn't get the rear brake to lock up. Maybe I just wasn't pushing hard enough. And yes, I had a backpack on but just an old cheap Jans Sport one from high school.
Old January 3rd, 2014, 10:08 PM   #93
SNAPPY
SNAPPY's Avatar
Motorcycle(s): '06 CBR1KRR(Track) '06CBR1KRR(Street) '05 CRF70 '08 EX250(Race) '08 CBR1KRR(Race)
If you want to quit riding then quit riding. Most people don't comprehend the level of risk involved in riding a motorcycle. If you are not willing to take that risk you should quit.
That being said, I don't think you really want to quit. I think you are scared. A healthy level of fear is good though. It'll keep you aware and alive. My suggestion would be to take it to the track. I have been riding for 8 years now. I started on the street like 99.9% of riders do. Eventually I started riding the occasional track day that evolved into more track time than street time. I developed my skills and began racing. Now I rarely ride street. Honestly, it scares me. Gravel, oil, pot holes, guard rails, curbs, OTHER DRIVERS, etc. Too many variables to be in control. The track is a VERY controlled environment and is WAY safer than the street. I suggest you get your bike back, get yourself healed up and go do a track day. I bet you'll love it.
SNAPPY is offline   Reply With Quote
Old January 6th, 2014, 06:19 PM   #94
JohnnyBravo
Certifiable nontundrum
JohnnyBravo's Avatar
MOTM - Sep '13, Sep '16
Crack cocaine... That is all
Old January 31st, 2014, 05:01 PM   #95
jefe305
Sure there have been injuries, and even some deaths in motorcycling, but none of them really that serious
Update: Doing well, seeing the doc next week which will make 6 weeks since surgery and hopefully I'll be able to start weight bearing again.
here's some pics
Right after the crash In the ER
A week later right before surgery
X ray after surgery
2 weeks after surgery
and here we are now 5 weeks post op
Old January 31st, 2014, 07:58 PM   #96
ally99
Ninja chick
ally99's Avatar
I bet that hurts even worse than it looks. Heal up!
Old February 1st, 2014, 09:13 PM   #97
jefe305
The first week was bad then when the swelling went down enough for me to have surgery. The first 5 days post op were brutal, round the clock heavy pain killers that were making me even sicker. After those 5 days I was able to stop all pain killers and I was basically pain free.
Old February 1st, 2014, 09:22 PM   #98
dcj13
Participant
dcj13's Avatar
Motorcycle(s): '94 K75 std
Heal quickly!
Old February 2nd, 2014, 06:19 AM   #99
n4mwd
n4mwd's Avatar
Regarding pain killers, I have been preaching that for years. Especially when it comes to narcotic pain killers. There are powerful non-narcotic NSAIDs out there that are considerably stronger than dilaudid, hydrocodone, etc, and don't have the negative side effects. And have zero potential for addiction. And many also reduce inflammation and swelling at the same time. But because of habit, doctors still give accident victims the narcotic stuff.
I don't know what you got, but in any case, its really good that you were able to stop the pain killers because people that don't end up in a nasty downward spiral. And sadly it happens a lot.
My Ninja Blog
Old February 2nd, 2014, 08:43 AM   #100
allanoue
allanoue's Avatar
MOTM - Sep '14
Demerol rocks
Old February 2nd, 2014, 09:22 AM   #101
n4mwd
n4mwd's Avatar
Demerol rocks
My Ninja Blog
Old February 2nd, 2014, 09:35 AM   #102
dcj13
Participant
dcj13's Avatar
Originally Posted by n4mwd View Post
...There are powerful non-narcotic NSAIDs out there that are considerably stronger...and don't have the negative side effects...
Dennis hit it on the head. Do we even need the narcotic stuff anymore?
Old February 2nd, 2014, 09:51 AM   #103
n4mwd
n4mwd's Avatar
NSAIDs tend to work better on constant pain and not that well on intermittent pain. So the narcotics still work better for intermittent pain. But for something like an injury, the NSAIDs work great.
I knew a lady that was dying of cancer and she was in a lot of pain. They were giving her morphine and dilaudid which had virtually no effect on her pain because the cancer was really bad. When they gave her Toradol (an NSAID) her pain vanished for about 4 hours each dose. That is just one of many examples of where high power NSAIDs rock.
My Ninja Blog
Old February 2nd, 2014, 11:14 PM   #104
jefe305
Yea I'm into natural holistic remedies. They prescribed me hydrocodone, and I knew I had to get off it as soon as possible. Doctors are nothing but drug dealers in white coats they rather prescribe something and get you on your way rather than try to treat the underlying problem. Then those meds cause side effects and they prescribe something else for that it's a vicious cycle. In my case that wasn't my problem, but I've seen it happen to too many people.
Old February 2nd, 2014, 11:22 PM   #105
jefe305
I'm going have to look into that. My mom suffers from severe fibromyalgia and takes a lot of narcotic pain killers. Which really doesn't help at all, and has caused a lot of bad side effects.
When I was in the ER right after the accident they gave me morphine intravenously and it didn't do a damn thing. They said it should feel like you're floating away, meanwhile it had no effect on me. My mom is the same way even before she started taking narcotics for pain and built up a tolerance she always had a very high tolerance. Certain drugs just don't work on some people
Old February 3rd, 2014, 06:50 AM   #106
n4mwd
n4mwd's Avatar
If your mother is in constant pain, then a toradol may help, however, NSAIDs are not miracle drugs and they also have side effects. So chronic use can lead to liver problems and gastric bleeding. But the nice thing about toradol is that it drastically reduces inflammation of an injury and that's how it kills the pain - by getting rid of the source. In your mother's case, I don't know that much about fibromyalgia, but it probably wouldn't hurt to talk to the doctor. There may be other NSAIDs other than toradol that might work better for her that she can take on a regular basis. Toradol cannot be taken continuously.
Opioid pain meds can cause a phantom pain syndrome when they wear off. So if you had continued to take the hydrocodone on a regular basis, you could still feel pain in your ankle long after it healed. At that point, you'd be a junkie if you continued to take the hydrocodone to relieve the phantom pain.
Its not uncommon for people to get injured and be in relatively little pain, but then hours later be in agony. This is due to inflammation building up. Toradol (don't confuse with Tramadol which is no stronger than an Alieve) will reduce the inflammation so that you need less toradol and not more over time. Opioid narcotic pain killers don't do squat for inflammation.
In your case, if you have recurring pain, I suggest starting with advil, alieve, or regular aspirin. If its not enough, then talk to the doctor about some toradol.
My Ninja Blog
Old February 3rd, 2014, 01:37 PM   #107
jefe305
I was talking to my mom about the NSAIDs turns out she already tried various kinds and none of them helped enough. She is seeing a new doctor now that is not too fond of taking narcotics long term, and wants to get her off of them. Not too much is known about fibromyalgia at the moment. There's no cure, just ways to manage the pain and symptoms. As for me I've been basically pain free, and since I'm young (only 21) I'm not expecting to have any further problems with this injury.
Old February 5th, 2014, 03:24 PM   #108
Klondike1020
Intrepid Adventurer
Klondike1020's Avatar
Major bummer. I hope your recovery is going allright.
Old February 5th, 2014, 03:26 PM   #109
Klondike1020
Intrepid Adventurer
Not too much is known about fibromyalgia at the moment. There's no cure, just ways to manage the pain and symptoms. .
I read online that they are trying medicinal Marianna to treat the symptoms, that and extreme health diets like the paleolithic diet are supposed ot help in some cases.
Old February 8th, 2014, 04:10 PM   #110
jefe305
Since they occur almost daily here, I got used to hearing about all the fatalities but this one really got to me today. http://www.fox5vegas.com/story/24670...torcycle-crash
Rider was the same age as me and it happened in an area that I know well. Can't even imagine what his last few moments must of been like.
Old February 8th, 2014, 04:33 PM   #111
allanoue
allanoue's Avatar
MOTM - Sep '14
Why did he run off the road? What killed him, internal injures, head trauma, or did he burn to death? How is that ankle doing?
Old February 8th, 2014, 04:35 PM   #112
n4mwd
n4mwd's Avatar
I read the article.
2014 Kawasaki sport motorcycle failed to maintain his lane while traveling eastbound on Oakey Boulevard approaching Martin Luther King Boulevard. The Kawasaki ran off the right side of the roadway onto the south sidewalk and continued eastbound crashing into the base of a street light pole.
When stuff like that happens, its usually a combination of two things - rider inexperience and an idiot cager changed lanes into him and drove away. It happens a lot, but the ones I have seen the most are when the cager pushes a biker (who is in the leftmost lane) into oncoming traffic on the other side. That's when it gets really nasty. In this guy's case, it looks like he was in the right lane and someone pushed him over on to the sidewalk.
When riding, you need to make a special effort to make sure you don't end up in anybody's blind spot.
Another thing to remember is that in many cases, there is enough room for both you and the cager in the same lane (lane splitting) - so there is no reason to panic when they do that. Just hit the brakes and get out of the idiot cager's way.
Its also a good argument to always run video. If that kid had video, at least his family could sue the cager for wrongful death.
My Ninja Blog
Old February 8th, 2014, 08:43 PM   #113
SNAPPY
SNAPPY's Avatar
or..................Take it to the track.
Old March 5th, 2014, 07:35 PM   #114
jefe305
Started up my my bike today for the first time since my crash which was about 2 1/2 months ago, can't believe it's been that long already. It started right up not even a dead battery amazing these bikes are indestructible. Going check it out better this weekend and if everything checks out going for a short ride.
Old March 6th, 2014, 05:13 AM   #115
Old March 6th, 2014, 06:28 AM   #116
jefe305
Can't believe I even thought about giving up motorcycling. What was I thinking, no way, no how, never.
We crash, we almost die, we break bones, and as soon as we are physically able to we get back on the bike hop on the highway and do 100 MPH. haha (straight open desert roads)
If you wake up and drive the same car to the same job day after day after day everyday and that's it then I got news for you you're already dead.
I am free to live in the now because I have decided not to be enslaved to the future.
Everyday we gradually distance ourselves from experiencing a full and free life and we don’t even know it.
Old March 8th, 2014, 08:27 PM   #117
Yakaru
The Violet Vixen
Yakaru's Avatar
MOTM - Jun '16
*hugs from one Vegas rider to another*
Sorry I missed the majority of this thread due to my absence.
Glad you're getting back on your feet and two wheels. Make sure you get everything checked over on the bike (any nasty frame damage, alignment slip, or wheel out of round could give you a bad day), but from the nature of the accident it should be in good shape.
Old March 9th, 2014, 09:32 AM   #118
greenaero
Motorcycle Hypermiler
greenaero's Avatar
Motorcycle(s): 1999 & 2005 Kawasaki Ninja 250R's
Great to hear you back to riding!!!
235 MPG Hypermotorcycling to a better tomorrow
greenaero is offline   Reply With Quote
[crash.net - MotoGP] - Dovizioso beats Pedrosa to end Honda career on a high Ninjette Newsbot Motorcycling News 0 November 6th, 2011 01:10 PM
[crash.net - MotoGP] - Akiyoshi 'happy', Ito reaches end of two-wheeled career Ninjette Newsbot Motorcycling News 0 October 3rd, 2011 04:10 AM
[crash.net - MotoGP] - HAVE YOUR SAY: Should Rossi end career in Superbikes? Ninjette Newsbot Motorcycling News 0 March 11th, 2011 02:30 AM
highway riding, top end giving out? dungY General Motorcycling Discussion 12 July 26th, 2010 10:04 PM
[superbikeplanet.com] - Yamaha Courting Rossi For "End of Career" Contract Ninjette Newsbot Motorcycling News 0 December 21st, 2009 03:40 PM
