July 4th, 2009, 03:56 PM | #1 |
Guest
Posts: n/a
Can't believe this happened to me
nevermind
Last futzed with by hyo sang; July 4th, 2009 at 06:15 PM. |
July 4th, 2009, 04:03 PM | #2 |
Join Date: Jun 2009 Motorcycle(s): 2007 Suzuki GSX-R750 Posts: 378
sorry 2 hear that..hope your alright..
July 4th, 2009, 04:56 PM | #3 | |
Join Date: Apr 2009 Motorcycle(s): 2009 Ninja 250r Posts: 379
But I'm sorry to hear about the bike. It definitely sucks when it happens. Hope fixing goes quickly, almost any info you need is in the tech section. |
July 4th, 2009, 05:20 PM | #4 | |
MOTM - Mar '13, Jun '14
More embarassing then telling us on here that you screwed up, crashed your bike, scratched a car up, and hurt your knee and hip because you weren't paying attention?
If everything seems under control; you're just not going fast enough! Last futzed with by CC Cowboy; July 14th, 2009 at 11:12 AM. |
July 4th, 2009, 06:16 PM | #5 |
Guest
Posts: n/a
k i wasnt embaressed about posting that but **** off
July 4th, 2009, 06:26 PM | #6 |
Join Date: May 2009 Motorcycle(s): 2008 Kawasaki Ninja 250R, 2009 KTM 690 SMC, 2001 Suzuki GSX-R 750 (track bike) Posts: 172
July 4th, 2009, 07:48 PM | #7 |
Sorry to hear that.
July 4th, 2009, 11:42 PM | #8 |
Join Date: Feb 2009 Motorcycle(s): '91 Honda CBR600 F2 Posts: A lot.
Bro, it sounds to me like you need to chill out. We're sorry you crashed, but if you can't take some dry humor about it from the king of ninjette dry humor, you're not using the right mindset when posting this kind of thing. We're not here to make fun of you, or tell you you're a horrible rider, but we are here to help you learn from your mistakes, just like we learn from ours. Please don't start cussing people out just because they make a snide comment in the hopes that you'll take the time to think about how it happened and make an attempt to keep from duplicating your mistake. Thank you.
1991 Honda CBR600 F2, White/Gray, D&D slip-on exhaust, tail integrator, gel grips, Custom undertail. |
July 5th, 2009, 08:37 AM | #9 |
motorcycle rider
Join Date: Apr 2009 Motorcycle(s): '14 Yamaha V-Star 650 Custom (silver) Posts: A lot.
Ah, I gotta side with the OP. He's a newbie, and wants to share his negative experience. Sure he screwed up, but it might have been said a little nicer.
Oh well, now that he's been chased off the site I guess no one will have to read about his mistakes anymore.
'14 Yamaha V-Star 650 Custom (silver) |
July 5th, 2009, 09:31 AM | #10 |
Join Date: Oct 2008 Motorcycle(s): 08 250 R Posts: A lot.
Capt, I feel the same way.. Always better to try to get someone on track then to chase them away.
"Don't let adverse facts stand in the way of a good decision" Colin Powell |
July 5th, 2009, 10:01 AM | #11 |
sorry to hear about your bike - lets try to figure out what happened so the same thing doesn't happen again. Also, iof you need help getting your bike back in shape, let us know and we'll try to help.
You said you popped the clutch too fast - were you stopped at a hill, or what? I need a little more info.... When I had my incident, I was stopped on a very steep hil on a tar and gravel road. Teh tar was all that was left, and I had to turn across the gravel - compiled with a 2-day old bike that I was still learning and a very lean bike that was all kinds of twitchy and it was just a not nice situation. The best thing I did was shim the carbs to keep her from being too lean and haven't found myself in that situation since....
July 5th, 2009, 10:38 AM | #12 |
July 5th, 2009, 10:45 AM | #13 |
same end result, the shimming is more of a crude method and you can't fine-tune as well - if you don't have an after market exhaust on yet, you're probably fine with just shimming - Kelly didn't rejet his until after the area P, the desnorkel, and removing the airbox I believe...
July 5th, 2009, 10:51 AM | #14 |
I had the AP QC exhaust and a desnorkeled airbox with 3 shims under each needle and the bike ran great. It wasn't till I removed the airbox and went to a stand alone filter that I installed a jet kit.
Noche's correct that shimming is a crude version of rejetting, but costs pennies and will give you about 75% of the improvements you get by installing a jet kit. |
July 5th, 2009, 11:00 AM | #15 |
Join Date: Jun 2009 Motorcycle(s): Ninja 250 x2, Ninja 650R Posts: 165
Shimming the needles isn't crude if you are adjusting between the next jet size. It actually lets you fine tune the A/F ratio (up to 4 shims).
Now, if you're just tossing shims on the needles w/o knowing your A/F ratio... |
July 5th, 2009, 11:15 AM | #16 |
July 5th, 2009, 12:51 PM | #17 |
I don't see where anyone was trying to chase him off. If he's going to take sarcasm that way, what are we supposed to do? Forbid Oscar from ever posting again?
July 5th, 2009, 03:15 PM | #18 |
Just seems there is a time and place for everything. Nobody said anything about forbiding anything and or anyone. don't make this bigger than it is.
this isn't your deal. Just the guy seemed bummed and he didn't need kicking when he was down. Don't make me mad.... you wouldn't like me when I'm mad...
July 5th, 2009, 03:19 PM | #19 | |
I just dropped my clutch yesterday. Hand was getting tired. *&it happens.
July 6th, 2009, 12:17 AM | #20 | |
July 6th, 2009, 12:25 AM | #21 |
you ain't seen nuthin till you rejet the bike. when you do so, remove the snorkel at the same time. use the jetting database to figure out where to start with your baseline jetting. be willing to put a lot of time fine tuning your jetting.
backfiring can be cured by removing the Kleen system. take a look in this thread for more info on all these subjects... http://www.ninjette.org/forums/showthread.php?t=5586 |
July 6th, 2009, 12:26 AM | #22 |
Join Date: Nov 2008 Motorcycle(s): '09 Ninja 250R Posts: 518
To stop backfiring, try removing the Kleen Air System
http://www.ninjette.org/forums/showthread.php?t=9948 EDIT: Kelly beat me to it. Slow poster here... |
July 6th, 2009, 12:49 AM | #23 |
thankz
July 6th, 2009, 12:53 AM | #24 |
You will notice a difference and more torquey response right off the throttle!
I have a little pop still once in a great while. Is there anything that might be harmful about removing this. It is only an emission requirement , Right?? I think Kkim is really a Bot
July 6th, 2009, 01:06 AM | #25 |
yep, an emission thing and if you've switched out to a full aftermarket system you got rid of the 2 cats that the stock system has in the header pipe and muffler.
try it, if it doesn't work for you for some reason, it's easily reversible. |
July 6th, 2009, 01:14 AM | #26 |
Ok next time I have it apart I will check it out. I only have the slip on . I had some jetting and shimming done but it was by a really good tuner. People ask about my bike at the dealer and they say yep Joe did it!!
I know how to do it but,,, I don't mess with the carbs I have fumbly finger and might as well tear the diaphrams right off the bat. He also bored the slides and trimmed the springs. The emissions tubing looks easy enough to do and reverse if necessary I can handle that. I have done everything else cept the carbs. thanks,
July 6th, 2009, 01:37 AM | #27 |
Plugging the kleen air system and pulling the snorkel seem easy enough...Its the rejetting thatz gonna be a pain in the ass, becuz I dont know how 2 do it, and I dont trust myself enough to attempt 2 do it..Finding a good, reliable, honest mechanic 2 do it, and do it right, is gonna be hard 2...
July 6th, 2009, 08:35 AM | #28 |
Giggity Giggity
Join Date: Feb 2009 Motorcycle(s): 08 ninja 250R aka Hiryu Posts: 481
lol major thread jack
Facebook DY Fender chop, Danmoto CB slip-on w/baffle, Airbox removed, Kleen-air removed, shimmed needles, Mikuni #117.5 Main jets, K&N RU-1822 air filter pods |
July 6th, 2009, 11:06 AM | #29 |
It happened. | roc0487 | General Motorcycling Discussion | 23 | July 13th, 2014 02:17 PM |
whatever happened to jiggles...? | gitoy | General Motorcycling Discussion | 9 | March 24th, 2014 10:01 AM |
Well...it happened...and I can't believe it happened.. | sunspots | !%@*#$%!)@#&!%@ I crashed! | 27 | July 17th, 2013 06:49 PM |
What just happened? | oreX | !%@*#$%!)@#&!%@ I crashed! | 26 | February 3rd, 2012 07:52 AM |
I'm not sure how it happened... | noche_caliente | Off-Topic | 14 | June 10th, 2009 09:24 PM |
