May 28th, 2012, 07:38 PM | #1 |
Join Date: Apr 2012 Motorcycle(s): Ninja 250r Posts: 228
HELP ASAP please! - turn signal issues
hey everyone I just did some mods and am stuck. I put in the custom led integrated tail light and removed the back oem signals in the rear. I installed led flush mounts from tri, put in his relay and did the diode kit. The rear integrated signals do not work, the front ones flash slower than tris video. The left and right turn signals on the integrated DO NOT work, when I press either of the brakes then the right and left on the integrted work, but only holding the break. Please help!
I am trying to get this fixed asap so I can ride to class tomorrow, gonna be 91 degrees + I don't want to put all the stock back on. edit: rear integrated worked fine prior to flushmount install
www.SafetyPaws.org |
May 28th, 2012, 07:49 PM | #2 | |
Avid Kitteh Poster
Join Date: Sep 2011 Motorcycle(s): 2006 Yamaha TTR 50 SUCK IT Posts: A lot.
I powdercoat stuff Help me pay for my addiction I say funny stuff. http://twitter.com/JustinPWNSyou sometimes... I write like a 12 year old too, http://justinpwnsyou.wordpress.com/ |
May 28th, 2012, 09:17 PM | #3 |
ModMy250.com
Please double check your diode wiring.
http://www.ninjette.org/forums/showthread.php?t=79621 video: http://modmy250.com/diy.html The only time I see when people have problems is when they don't wire the diode correctly. You can also just plug in the oem front LED's and see if the integrated blinkers work. If they do, you possibly have a defective relay. I haven't sold a defective relay yet, but it's possible.
The www.ModMy250.com guy |
May 28th, 2012, 09:26 PM | #4 | |
before I plugged the flushmounts the integrated worked flawlessly. I was thinking it was the relay bc of the front led blinking slow and then flickered.
May 28th, 2012, 10:58 PM | #5 |
ModMy250.com
It should be obvious where they should re-plug into. The two connectors you work with are a 3 pin and a 9 pin. You can't plug one into the other, so I don't see the confusion. I'm not sure what "possible combinations" you might have tried. Have you tried plugging in the oem front blinkers to see if everything comes back to normal? Posting a video won't help if I don't know what your wiring looks like. Please plug in the oem front blinkers to confirm the relay is not the issue.
May 29th, 2012, 08:59 AM | #6 | |
alright, I unplugged both flush mounts and the integrated works as normal. I plugged in the oem stock and the taillight works again. the tail light and stock function as normal with the diode kit converted, what did I do wrong/then relay should be working correct?
May 29th, 2012, 11:01 AM | #7 |
ModMy250.com
Sounds like a faulty relay. I'll pack one up today and priority ship it tomorrow. Just to confirm, you grounded the black wire on the diode kit right?
May 29th, 2012, 11:17 AM | #8 |
yep i put it on the same 10mm screw bolt that you had in the picture.
May 29th, 2012, 12:22 PM | #9 |
DIY newbie
Join Date: Oct 2011 Motorcycle(s): 2010 Ninja 250r Posts: 17
Interest
I'm quite interested in how this turns out since I'm doing as much reading up before I start hooking up. I'm about to do the integrated taillight with the protons up front. Now, from what I've read, I should be good with a new relay, LF1-S-FLAT from superbrightleds, and the diode kit from Tri/www.ModMy250.com. So from what I gather, and hopefully:
Protons + Integrated Taillight + Diode Kit + Electric relay = Nice looking and fully functioning lights? Let's hope |
May 29th, 2012, 05:00 PM | #10 | |
my main complaint now is that i cant ride atm =***********( i could put on stock to ride but time limits that scenario. hand signals?
May 31st, 2012, 04:14 PM | #11 |
wouldnt let me delete this post, ill put my update here when i get the relay
edit: see below, still not functioning correctly!
www.SafetyPaws.org Last futzed with by SafetyPaws; June 1st, 2012 at 04:30 PM. |
May 31st, 2012, 05:26 PM | #12 |
DIY newbie
Yeah, I just got the incorrect relay in the mail. I just bought one from Tri, as I probably should have in the first place by the looks of it.
June 1st, 2012, 04:27 PM | #13 |
still broken
Alright so i got the new relay in and hooked it up. It still is not functioning correctly with the LED front signals. It works fine with OEM incandecents.
video here (mite take a few min after post for video to be processed by youtube) http://www.youtube.com/watch?v=_4aGt...ature=youtu.be on what it looks like. The LED signals are actually flickering but you cant tell in the video. i tried unpluggin the license plate light for the hell of it, nothing. I unplugged the brake light and when i would go right or left, either way both front LED's flashed. (well flickered). Any suggestions? =*( EDIT: is maybe the green taken out of the 9 pin supposed to go into the diode kit 3 pin? EDIt 2: I plugged in stock relay for the hell of it and the integrated tail light worked but the led flush mounts stayed lit, if that's any indication.. My ninjette is a 2012, has anything changed from previous models?
June 1st, 2012, 06:04 PM | #14 |
ModMy250.com
From the video, it looks like the wiring is correct. Try this: remove the diode kit and put the wires back to stock. Plug in the led signals and flip the turn signal. All four lights should blink at the same time like hazard lights. If they do, then the fault is in the diode kit. LMK how it turns out.
June 1st, 2012, 06:43 PM | #15 | |
on a side note it feels like the little metal piece (what's it called?) that holds the green wire that I had to pop out and in is going to break, if it breaks where can I get a replacement, like radio shack or somewhere? appreciate your help btw, luckily its been raining past few days.
June 1st, 2012, 06:47 PM | #16 |
ModMy250.com
The diode was probably bad to begin with. I'll ship a new one out tomorrow. Can you ship the old diode kit and one of the relays back to me?
June 1st, 2012, 06:53 PM | #17 |
yes I can, I've never shipped anything (just regular envelop mail), can I put them in one of the original boxes (relay box) and do a "return to sender" ? Or do I have to go to the post office and put em in new box?
June 1st, 2012, 06:53 PM | #18 |
ModMy250.com
Do me a favor and clean your grounding point with some sand paper. Then try the diode kit.
June 1st, 2012, 06:55 PM | #19 |
ModMy250.com
You can reuse the box but they will charge you to ship priority which is $5.50. You will need to go to the post office to ship it.
June 1st, 2012, 06:59 PM | #20 |
my grounding point was the same as in your video - the screw on the frame, where should I sand, the back of the screw or the part of the frame? Also would that damage that lil spot for rust or any thing?
June 1st, 2012, 07:45 PM | #21 | |
June 1st, 2012, 07:46 PM | #22 |
ModMy250.com
Sand the frame part. Some people have needed to do that to get the lights working correctly and had the same problems you did. Once you get the blinkers working right, you can go back and spray a little paint on the bolt and ring terminal (not where you sanded as that needs to be a clean ground point.)
June 1st, 2012, 07:46 PM | #23 |
ModMy250.com
Ok, thanks for trying . I'll ship it out tomorrow.
June 2nd, 2012, 10:45 AM | #24 |
tyvm
now if that don't work, what other problems can their be? Anything we can for see?
June 3rd, 2012, 12:20 AM | #25 |
ModMy250.com
If it doesn't work, I'd remove the rear integrated lights and see if the fronts blink right. Other than that, there's really not much else.
June 7th, 2012, 01:57 PM | #26 | |
Tri @ Modmy250.com (i got nerd chills [term used {i know i didn't coin it but think only one who uses and people are like wth is that} getting goosebumps for something silly in a game or computer / technology oriented area] when hooking everything up and it worked.) Just thought i would share that, 7 days working on it off and on waiting for parts, arg... Ninja nerd chills!
June 7th, 2012, 03:01 PM | #27 |
June 7th, 2012, 09:21 PM | #28 |
ModMy250.com
Cool . I'm glad it worked out. Please send back the defective parts when you can.
June 11th, 2012, 09:04 PM | #29 |
yar will do, sorry will try to get them to you in the enxt few days, finals week
June 20th, 2012, 07:00 PM | #30 |
Join Date: Jun 2012 Motorcycle(s): 08 R6, 08 250R Posts: 87
Just threw in my electronic relay from Tri today in 2 seconds and it worked like a charm to fix my non blinking problem. OEM front signals, and integrated LED tail.
YEAH BUDDY! |
June 25th, 2012, 04:17 PM | #31 | |
@CThunder-blue did you get the stuff back?
June 25th, 2012, 07:05 PM | #32 |
ModMy250.com
Not yet.
Looking for 09 oem rear turn signal and front turn signals and tail fairings | mbbernas | Items Wanted | 1 | September 11th, 2013 10:48 AM |
Front turn signal issues... | snowman7 | 1986 - 2007 Ninja 250R Tech Talk | 6 | June 30th, 2013 07:21 AM |
Turn Signal Issues | dsmisfits | 2008 - 2012 Ninja 250R Tech Talk | 9 | December 19th, 2012 09:16 PM |
2009 ninja turn signal issues | schultzy808 | 2008 - 2012 Ninja 250R Tech Talk | 3 | March 28th, 2012 08:06 PM |
Turn Signal Indicator Issues | menikmati | 2008 - 2012 Ninja 250R Tech Talk | 9 | December 12th, 2011 08:17 PM |
