Old August 21st, 2009, 10:14 PM   #1
Rafalski
Motorcycle(s): Ninja 250R 08
Installing pitbull rear spools
I got a pitbull stand and have the spools. How do i properly install them
Anyhelp is appreciated.
Rafalski is offline   Reply With Quote
Old August 21st, 2009, 10:25 PM   #2
coffeecandy
Motorcycle(s): 2002 Ninja 250
does it have a place for spools to be attached? if so just screw them in with some red loctite and tighten...
if not go to pitbulls website and their their spool attachments for non-spooled bikes. go to a shop and get them welded on and you are done.
Bay Area Event Coming Up:
June 2, 2012 Mike's Newb Group Ride
coffeecandy is offline   Reply With Quote
Old August 21st, 2009, 10:35 PM   #3
Rafalski
yeah they do. But whats the order it goes. i think its spool and washer?
Old August 22nd, 2009, 04:10 AM   #4
coffeecandy
i would think the washer goes in between the bolt and the spool. You really can't hurt the bike by having a washer between the bolt and spool and a washer between the spool and bike.
Old August 22nd, 2009, 04:19 AM   #5
Momaru
Momaru's Avatar
I found it worked better if I installed them like this for the left side:
bolt - spool - spacer/washer - bike
and vice versa for the right, so that the included spacers were between the spool and the bike. The lip they put on the spool was just a tidbit too small to make it over the swing arm. Also, I'd definitely do a test-fit before aplying the loc-tite, just to make sure you're happy with the fit, etc...Ask me how I know
Proud member of the Blue Army
Old August 22nd, 2009, 09:32 PM   #6
Rafalski
doesnt our bike come with spool spots. so should i do botl spool bike spacer on the end to hold it in place
http://www.totalmotorcycle.com/photo...Ninja250Ra.jpg
little black part there.
Old August 23rd, 2009, 02:00 PM   #7
Momaru
Momaru's Avatar
The spacer is to help it clear the lip between the end of the spool bung (threaded part on the bike) and the swingarm itself. If you just try screwing them in yourself I think you'll see what I mean. I wound up just test fitting with and without the spacer, going with the fit I liked. Just make sure you do the same for both sides. Here's a couple pics from my right side spool to show ya what it looks like without spacers. And yes, I know I need to wash the bike :-p
Last futzed with by Momaru; August 23rd, 2009 at 02:04 PM. Reason: dirty
Old August 26th, 2009, 02:30 PM   #8
im_a_ninja
im_a_ninja's Avatar
How did you order your stand and spools? Is there a certain size and you just ordered them by size? Or are they specific to the bike?
I found the stand at pitbull for $140 something....that's the standard/spool combo stand.
im_a_ninja is offline   Reply With Quote
Old August 26th, 2009, 02:36 PM   #9
rockNroll
rockNroll's Avatar
Motorcycle(s): black
That's one of the best stands you can get.. a good choice. Now you need 10mm spools. As far as fitment of the spools, here's a thread for ya... http://www.ninjette.org/forums/showthread.php?t=21722
Old August 26th, 2009, 03:37 PM   #10
Momaru
Momaru's Avatar
I also recommend stands by T-Rex. Got a set (front triple-tree and rear spool stands) for about $160 total.
http://www.t-rex-racing.com/
There's several threads around with opinions, etc for these and other, less expensive stands.
Old August 26th, 2009, 06:47 PM   #11
noche_caliente
noche_caliente's Avatar
Motorcycle(s): '08 250
Shannon, Oneida Suzuki has the best price I've found on the pit bull stands
Progrip tank pad, blue rim stripes, blue Pazzos, Roaring Toyz lowering kit, Puig DB in dark smoke, Cortech sport tail, super mini tank, and saddlebags, OES swingarm spools and Intuitive frame sliders
Old August 26th, 2009, 08:00 PM   #12
ScorpionNinja
ScorpionNinja's Avatar
Pit Bull Spooled Motorcycle Stand (i bought mine here)
http://stores.sportbiketrackgear.com/Detail.bok?no=81
Pit Bull Delrin Swingarm Spools (i bought mine here)
http://stores.sportbiketrackgear.com...ls%2FReceivers
As a local,Loyal customer (ive bought all my scorpion gear,etc from them so far) i got -10% off when i drove up to their store in my Car to pick mine up!
Spool ends are adjustable (youll use this stand for your ZX-6R lets say, next bike!) The 2 Bolts if i remember right are 19mm or 20mm :scratch:
SV Racing Parts, 10mm Swing Arm Sliders with Spools for Rear Stands SV Racing Parts Motorcycle-related 0 February 16th, 2015 11:44 PM
Rear Spools FvnnyL3tt3r1ng 1986 - 2007 Ninja 250R Tech Talk 1 September 11th, 2013 06:13 PM
Yoshimura Rear Spools 08+ Black, New GlassAnkles Motorcycle-related 5 March 7th, 2012 11:40 AM
rear spools ladyninja08 2008 - 2012 Ninja 250R Farkles 6 February 26th, 2012 08:45 PM
WTB: Pitbull Front Stand or Rear Spool Stand Mr_Pete Items Wanted 8 October 30th, 2009 02:02 AM
