April 26th, 2010, 01:00 PM | #1 |
Join Date: May 2009 Motorcycle(s): 2009 Kawasaki Ninja 650RTE & 2009 Kawasaki Ninja 250R (SOLD) Posts: A lot.
Heated Handlebar Grips!!!
Will these work on our bikes w/o mods to the bikes electrical system?
http://www.twistedthrottle.com/trade...view/4613/704/ Us in Michigan could use these! It wires to the battery, but would the 250 have enuff Power to use these while riding and with your Headlights -Also Highbeams on-? If you have HID headlights (35w) would it be enuff power saved Vs the stock headlights, to install this w/o having to totally mod the bikes electronics? |
April 26th, 2010, 02:30 PM | #2 |
Join Date: Jul 2009 Motorcycle(s): 2009 Kawasaki Ninja 250R Posts: 410
Just an aside, I rode a BMW with heated grips on a cold day this past weekend and they now haunt my dreams. What an exquisite pleasure they are! I was wearing summer gloves and my hands were toasty!
April 26th, 2010, 02:41 PM | #3 |
Join Date: Nov 2009 Motorcycle(s): '06 250 Ninja Posts: 6
Next to the 15 tooth countershaft sprocket, headed grips are the nicest feature I added to my bike. I ride with Lee Parks gloves year round and have yet to feel cold on my 30 minute commute, no matter what the weather. Best $35 I ever spent. The drain from the heaters is a non issue unless you like to sit for hours in the garage with the engine not running and the grip heaters turned on. Be sure to wire the grips to a switched power source or you will forget and run the battery down by leaving them on. I installed the Symtec heaters so I could run the grip of my choice. I'm assuming the grips under discussion draw aprox the same wattage. I use my heaters all the time on cool mornings and just after the sun goes down even in the summer.
April 26th, 2010, 03:22 PM | #4 | |
http://www.ninjette.org/forums/showthread.php?t=31087 |
April 27th, 2010, 04:10 PM | #5 |
Cool thanks Sam!
If you didnt read the link i had in OP, the heated grips are 48 watts. Last Oct. when i went to the BMW event, i was able to Demo ride a GS650, and boy oh boy did i dig the factory stock Heated grips on that! They cooked my hands towards the end of the demo ride. I had to turn em down to low setting! Sweet then I will be getting some heated grips for my bike later this year, afew weeks b4 the cold Michigan weather starts setting in! Next thing ill have to add, is a 12V Cig lighter, to plug in my Cell phone to charge up in case my phone dies while on a trip, or if i can save up to get a GPS unit! |
DIY - Hot Grips Heated Grips Install | NathanF | 2008 - 2012 Ninja 250R Farkles | 26 | January 23rd, 2014 03:37 PM |
Anyone using heated grips? | caineroad | General Motorcycling Discussion | 5 | September 24th, 2013 06:05 AM |
tried these heated grips? | smackenz | 2008 - 2012 Ninja 250R Farkles | 7 | October 17th, 2012 03:11 PM |
heated grips | bhalv | 1986 - 2007 Ninja 250R Farkles | 10 | January 17th, 2011 09:39 PM |
Heated Grips | sudadoda | 2008 - 2012 Ninja 250R Farkles | 7 | May 4th, 2010 07:15 AM |
