Old March 19th, 2014, 09:59 AM   #1
RedPepper64
Kawi Girl
RedPepper64's Avatar
Motorcycle(s): '10 Ninja 250R Green SE, '13 Ninja 636 Pearl White
Steering Damper Suggestions - 636
I'm not sure if this is the best spot for this post so it can be moved if needed.
Looking into getting a steering damper for the 636 and have heard a ton of different advice between my mechanically inclined friends and the local shops.
What are your favorites and recommended? Least favorites and recommended to avoid? And why of course. Other input also appreciated, trying to get her track ready for end of April.
Thanks!
Perspective: Everything looks better from the inside of a motorcycle helmet
RedPepper64 is offline   Reply With Quote
Old March 19th, 2014, 11:23 AM   #2
backinthesaddleagain
backinthesaddleagain's Avatar
Motorcycle(s): 2013 ZX6R 636
Don't get the OEM. Its expensive and underdamped. Get a true ohlins or other aftermarket one. I haven't brought my bike home yet so I have no idea yet if I will be wanting a damper. My CBR had the electronic Honda one and that worked great whenever the front got light. I hear the GPR is a good one and the price is much better. Check the ZX6R forum also, lots of friendly people there. I am GEB on there by the way.
Old March 19th, 2014, 11:29 AM   #3
I am partial to the barrel type vs. the bar type. It's less likely that this will be majorly damaged in the event of a down.
I am a fan of Scotts but there are others that are fine too.
Old March 19th, 2014, 11:31 AM   #4
Peanut_EOD
Peanut_EOD's Avatar
Motorcycle(s): Green 2013 ZX-6R
I've got the GPR on mine and it seems to work just fine. I've had the front tire come up a little many times powering out of a corner and have never had it get squirrely.
http://www.simplysurrealphotography....es/peanut2.png
Peanut_EOD is offline   Reply With Quote
Old March 19th, 2014, 12:11 PM   #5
Hey how was the fit?
Old March 19th, 2014, 12:29 PM   #6
Peanut_EOD
Peanut_EOD's Avatar
It fits great. It's a little weird getting the key in and out because of the angle. Make sure you get the one for the 2013-14 ZX-6R, previous models will not work they are different.
Old March 19th, 2014, 12:41 PM   #7
thanks just ordered GBRacing engine covers and sato frame sliders so probably look at dampers next, then fender eliminator. Funny thing is on my CBR the only thing I ever changed were tires.
Last futzed with by backinthesaddleagain; March 24th, 2014 at 09:20 AM.
Old March 19th, 2014, 12:45 PM   #8
Heard good things about the GPR's as well, never rode with one though.
Old March 19th, 2014, 01:10 PM   #9
Chris - if I read correctly on the scotts you have separate low and high speed damping so you can still maneuver easy at low speed and save a slapper at high speed is that correct? That's what I liked about the elec one on my Honda as it varied with speed ant throttle position.
Old March 19th, 2014, 03:23 PM   #10
Ducati999
Motorcycle(s): Ducati 999 2012 Ninja 250r Ducati748 Yellow finally running 2003 SV650 S (SOLD)
Going with a new stabilizer is best if you can afford the $cost$. My Ducati has a non adjustable unit and it works great but I want to get the Ohlins adjustable model (which is also rebuildable). Should you have to go the used route and are good at fabricating the mounts, I would suggest checking out the ZX10 dampers. I have seen their Ohlins damper for around $100 on E-bay. I am not sure of the model number but it looks just like the stock Ohlins dampers that come on Race/S model Ducatis.
Ducati999 is offline   Reply With Quote
Old March 19th, 2014, 05:06 PM   #11
Hey I think I've seen you on nesr forum.
Old March 19th, 2014, 07:16 PM   #12
Basically, yes sir.
Old March 24th, 2014, 05:56 AM   #13
Ducati999
Yes you have. I have the same screen name over there but I like this forum much better!
Old March 24th, 2014, 09:19 AM   #14
great group of people here for sure.
steering damper Frogger 2008 - 2012 Ninja 250R Tech Talk 6 September 8th, 2013 09:11 PM
Steering damper caliente103 2008 - 2012 Ninja 250R Farkles 10 April 4th, 2010 12:11 PM
