March 6th, 2011, 06:33 AM | #1 |
Join Date: Feb 2011 Motorcycle(s): '04 Aprilia RSV, '10 Bonneville, '10 Ninjette Posts: 359
Tail Tidy / Turn Signal ?'s
The 2010 I just picked up had a Tail Tidy installed already. I'm noticing a couple issues with it.
First, I don't seem to have any rear signals. There aren't any physical turn signals on the rear, but I figured it was an integrated signal / brake taillight. If I flip on my blinker, nothing seems to happen on the rear. Any idea if a Tail Tidy fender eliminator kit is setup that way? Also, when I use my blinkers, the stock front signals light up, but they don't blink. Just solid light until I turn them off. Was the original install done incorrectly perhaps? The bike came with a set of Proton flushmount fronts, but I don't want to tackle that install until the current issues are sorted out.
-Jeremy |
March 6th, 2011, 07:08 AM | #2 |
Here's a DIY that may help you with your problem.
http://www.ninjette.org/forums/showthread.php?t=44747 |
March 6th, 2011, 07:16 AM | #3 |
I was just looking through that thread. I seems that my problem is that there aren't any turn signals bolted to the back of my bike
-Jeremy |
March 6th, 2011, 07:44 AM | #4 |
Join Date: May 2009 Motorcycle(s): '09 Kawasaki N-250 + '09 Vulcan 900 Classic Lt Posts: A lot.
Looks like previous owner only did half the job and has left the rest up to you to figure out.
March 6th, 2011, 07:52 AM | #5 |
So it would seem. I think I've got the original fender and signals, but I love the clean look. Guess I'll look into a Bilelightz tail light
-Jeremy |
March 6th, 2011, 08:12 AM | #6 |
Check into PA safety inspection., I used to do them and what you're talking about would not pass inspection back then.
tail light/turn signal bulb size | ieathonda | 1986 - 2007 Ninja 250R Farkles | 20 | March 27th, 2015 06:48 AM |
turn signal tail light mod help plz | BukkShot | 1986 - 2007 Ninja 250R Tech Talk | 3 | March 18th, 2015 08:44 PM |
Looking for 09 oem rear turn signal and front turn signals and tail fairings | mbbernas | Items Wanted | 1 | September 11th, 2013 10:48 AM |
