Old February 21st, 2016, 06:28 PM   #1
sabre al
Motorcycle(s): (1) 84 honda sabre v4 700 (2) 2010 ninjette
valve adjustment
hi folks sabre-al here. just thinking as a machinist, why not lap the required amount from each valve shim instead of buying more. two parallels and some valve grinding compound should not take long to remove .005 - .007" from your existing shims as needed. chime in with your thoughts.
sabre al is offline   Reply With Quote
Old February 21st, 2016, 06:32 PM   #2
Welcome Albert!
Someone will chime in soon.
Old February 21st, 2016, 06:38 PM   #3
RacinNinja
Vintage Screwball
RacinNinja's Avatar
MOTM - Mar '16
The only downside is that if you take too much, you're gonna need a shim anyway.
The upside is that if you're very careful, this can be done and you can save 10 bucks in shims.
IMO, doing this is not worth the 10 bucks in shims I can get from the local shop.
Goin' fast on slow bikes!
Old February 21st, 2016, 06:46 PM   #4
sabre al
valve adjustment
yes, if shims can be obtained for just ten bucks or so, it wouldnt be worth fooling with.
Old February 21st, 2016, 06:54 PM   #5
sabre al
valve adjustment
wouldnt it be nice if the valve shims were the same hardness as the valves and seats so they would wear approximately the same, increasing adjustment intervals.
Old February 21st, 2016, 06:55 PM   #6
RacinNinja
Vintage Screwball
RacinNinja's Avatar
MOTM - Mar '16
If you have a local repair shop, they will most likely have them for a couple bucks each.
Don't order an entire 80 dollar shim kit. The shop I have local, last time I went, just exchanged the three shims I needed for the ones I had at no cost.
Old February 21st, 2016, 07:48 PM   #7
Abu_Mishary
The Asian Caucasian
Abu_Mishary's Avatar
Name: Abu Mishary Mohd Fairus
Motorcycle(s): Kawasaki Ninja 250 SE 2015 (sold); Honda ADV160 (current)
MOTM - Jan '17
My "shims-ing" will only be done by the mechanic.
I just sit and watch.
Welcome Albert!
Losing someone is not painful. They are a part of us all this while and will always be with us. But missing them is.
Abu_Mishary is offline   Reply With Quote
Old February 23rd, 2016, 05:18 PM   #8
snot
sammich maker
snot's Avatar
MOTM - Apr '15
Welcome.
Old February 24th, 2016, 09:28 AM   #9
cbinker
Track Clown
cbinker's Avatar
MOTM - Sep '15
welcome.
TEAM ALFALFA
www.apexassassins.com
Old February 25th, 2016, 10:25 AM   #10
Bigballsofpaint
A lot of people and places say the shims are case hardened, so removing material will remove the outer most and hardest portion, resulting in excessive wear later on.
But I did what you said, I have a surface grinder at my job and brought each shim in and took off the required amount (.002-.003 in most cases). No issues with my or my friends bike as of yet.
I have purchased the shim kit for the future only because I wanted to be able to do the valve job without having to wait a day or so to bring parts to work and grind them.
Current - 2015 30th Anniversary Ninja 636 ABS - 1969 Honda 305 Scrambler
Previously - 2011 Ninja 1000, 2008 Ducati 848, 2011 Ninja 250 SE
Old February 25th, 2016, 10:42 AM   #11
dcj13
Participant
dcj13's Avatar
Motorcycle(s): '94 K75 std
Welcome, Albert! Lots of interesting reading, sage advice, and entertaining people on this forum.
The shims don't wear at all. It's the valve/seat interface that slowly wears away due to the hot temperatures and thousands of opening/closing cycles every minute.
During operation, the shims don't even make contact with the camshaft lobes (or rocker mechanisms, depending on engine configuration): there's a oil film between the two metal surfaces.
Old March 1st, 2016, 06:03 AM   #12
Snake
Snake's Avatar
Hello and welcome!
Old March 1st, 2016, 07:05 AM   #13
sabre al
valve adjustment
i would think case hardening would penetrate deeper than a couple thousandths, making that a non issue , if you remove half off each side.you know ,grind and or lap .002" off each side to remove .004" total would reduce the possibility of breaking through the hardened surface.
Old March 1st, 2016, 08:31 AM   #14
kxpower?
kxpower?'s Avatar
Motorcycle(s): Ugly 89 frankenstien special ex250, and the "Zooks" : 1982 GS450 and 1979 GS1000
I don't know a whole lot about the hardening process, but here's how I have seen it done for the 29.5 mm shims both my Suzuki's use. The shims are stamped at the factory with the thickness, which, if that side is installed down that side is basically stationary other than spinning in the bucket. Which is a lot of movement but not nearly the action the top side is getting from the cam.
When you grind a shim (my brother did a few with a mill a while back) just grind the side where the thickness was marked, so you don't have the wrong thickness. Then install that ground side down. That way if it's lost any hardening from the grinding, it will be on the side that doesn't get beaten on thousands of times a minute.
Oh, and I don't know if it's an issue for the Kawi's, but I remember receiving an adamant warning to make sure the shims are NEVER exposed to magnetism. Apparently a magnetized shim could stick to the cam and lift out of the bucket in a perfect storm and wreak a lot of havoc in your motor. Fishing those suckers out of the head I could see the temptation to grab it with a magnetic screwdriver. I used these huge 6-inch long tweezers and they worked without a whole lot of cursing.
Oh god the bikes are multiplying!!!
kxpower? is offline   Reply With Quote
Old March 1st, 2016, 08:32 AM   #15
kxpower?
kxpower?'s Avatar
And PS: Welcome to the forum!!
Old March 1st, 2016, 08:40 AM   #16
RacinNinja
Vintage Screwball
RacinNinja's Avatar
MOTM - Mar '16
This doesn't really apply to Ninja's and most (!) motorcycles as they are shim-under-bucket (yes, I know a few are shim over bucket). IE, the bucket is what makes contact with the cam, and the shim is a tiny little thing riding on top of the valve stem.
Old March 1st, 2016, 08:44 AM   #17
kxpower?
kxpower?'s Avatar
Oh, whoops lol the only direct-actuate valve covers I've ever had off were the Suzukis
I assumed that was the norm for shim setups.
So anyways ignore all I've said here lol.
Old March 1st, 2016, 09:40 AM   #18
RacinNinja
Vintage Screwball
RacinNinja's Avatar
MOTM - Mar '16
Well, it's still good info in regards to engines. Just not most motorcycles. It was a "thing" in the 80's and early 90's, then everything went shim under. Yamaha used them on the 1100 Maxim and a few other bikes too.
A lot of Japanese car and truck engines used them. I don't buy in to the magnetism thing unless you really juiced them with a rare earth magnet or something. A small magnet on the end of a wand won't do any harm.
Old March 23rd, 2016, 10:30 PM   #19
xorbe
xorbe's Avatar
I've seen shim grinding videos on YT done somewhere in Asia.
Old June 13th, 2016, 09:37 PM   #20
Tim Fox
Tim Fox's Avatar
Motorcycle(s): 2014 Ninja 300 SE
Do not think I will worry about valve shims or 600 mile maintenance. I have road raced and thrashed bikes for years and checked clearances and have found very minimal clearance issues. I do all maintenance myself but I have a lot of experience. If you have little or no experience with motorcycle maintenance I would highly recommend having an experienced mechanic service your bike. Maintenance issues can cause serious safety concerns.
Tim Fox is offline   Reply With Quote
Old June 14th, 2016, 05:31 AM   #21
VaFish
VaFish's Avatar
MOTM - Jan '16
Just speaking as a non-machinist.
I wouldn't go through the trouble of lapping the shims because I don't have the equipment to do so. For the small price of the shims it isn't worth the hassle.
And Welcome to the Ninjettes.
Old July 2nd, 2016, 11:30 AM   #22
Valves aren't needed to be checked on the 300 until the 7500 mile service IIRC. This is different than the pre-gen bikes. The 600 mile maintenance isn't much, and one can certainly perform it themselves if they choose; but that doesn't mean the items in it are good to ignore completely.
Valve adjustment help jgcable 1986 - 2007 Ninja 250R Tech Talk 5 July 22nd, 2014 09:25 PM
Valve adjustment ninjaryda 1986 - 2007 Ninja 250R Tech Talk 6 April 6th, 2013 06:02 PM
Valve Adjustment-Really Tight adjustment screw? mikesova 1986 - 2007 Ninja 250R Tech Talk 5 May 2nd, 2010 04:57 AM
anyone want to help with a valve adjustment? diablo250 Group Rides and Local Events 2 March 28th, 2010 02:00 AM
Valve adjustment Apex 1986 - 2007 Ninja 250R Tech Talk 7 September 1st, 2009 05:53 PM
