Old September 28th, 2016, 04:02 PM   #1
chibit89
Motorcycle(s): 250r
4k Idle after carb cleaning
Hi,
Problem: 4k Idle after a clean start up. Rode around the block. No sign of it going down or up.
Notes:
- Before carb clean, needed choke to start up, rough idle, would die below 2k.
- cleaned carbs, installed 2 shims per needle
- installed everything back, all hoses back in place
- starts easily now, but now jumps up to 4k and stays there.
- took out shims, problem still there.
- carb sync adjuster is all the way up. (we thought more air = rpm down?)
- idle screw is NOT touching
- choke NOT on
- throttle cable shows slack, did the turn handle bars trick, the cable isn't super tight.
Could be: (as per other threads)
- vacuum leak
- leak through boots (i did have a hella hard time getting carbs in and out)
- valve adjustment
- tight throttle cable, but it shows slack and the turn right/left trick didn't raise RPM
Solution:
- needed to tighten carb sync adjuster, then reset air mixture screws to about ~2 turns, its not perfect but it lowered the revs to now ~2k
Thoughts? Bike is for sale after I get it fixed... sigh. Thank you for this forum for helping me through this
Last futzed with by chibit89; September 29th, 2016 at 09:51 AM.
chibit89 is offline   Reply With Quote
Old September 28th, 2016, 04:11 PM   #2
I'm confused... what butterfly valve is all the way open?
Old September 28th, 2016, 04:13 PM   #3
chibit89
Motorcycle(s): 250r
apologies, the "- carb sync adjuster is all the way up. " meaning not screwed at all. Logic is it needs more air for rpms to dip?
Old September 28th, 2016, 04:18 PM   #4
Often, high idles are caused by too much air (from a leak somewhere), not too little air.
Old September 28th, 2016, 04:31 PM   #5
It could be as simple as the idle was turned up due to carb condition. Have you tried simply turning the idle speed down?
Old September 28th, 2016, 04:36 PM   #6
I think that's what he meant by "- idle screw is NOT touching".
Old September 28th, 2016, 06:34 PM   #7
chibit89
Motorcycle(s): 250r
correct. idle is turned all the way down.
I'll try spraying starter fluid around boots, look for el leako.
Old September 29th, 2016, 09:38 AM   #8
bruce71198
bruce71198's Avatar
Cables misadjusted? I've seen parts of the throttle lever/linkage hang up on the screw clamp.
Old September 29th, 2016, 09:52 AM   #9
chibit89
Motorcycle(s): 250r
hey all,
i'm not 100% sure if it's running right but it starts and will idle at 2k. i'm happy for now, i will sync it (dont want to push my luck) but thanks all for the help.
Old October 1st, 2016, 12:08 PM   #10
Ryan_005
Ryan_005's Avatar
When I took apart my bike there was 1 single tube comming from the gas tank to the carb, some type of air bleed or something and the bike wouldnt run good. Check to make sure all your hoses are connected to the right places.
"The most important thing is to have a good relationship with the bike... you have to understand what she wants. " ~Valentino Rossi
Understand, Unregistered ?
Ryan_005 is offline   Reply With Quote
Old October 1st, 2016, 12:17 PM   #11
RacinNinja
Vintage Screwball
RacinNinja's Avatar
MOTM - Mar '16
Originally Posted by chibit89 View Post
hey all,
The carb sync adjust isn't what you think it is. That is the idle speed adjuster.
The carb sync adjuster is a small screw located between the carbs and has a spring on it.
Don't mix the two up.
Goin' fast on slow bikes!
Old October 8th, 2016, 08:49 AM   #12
chibit89
Motorcycle(s): 250r
I didn't. I meant what I typed.
During the sync, we adjusted the "carb sync adjuster" even more and now i'm balanced.
carb removal/cleaning yenome 2008 - 2012 Ninja 250R Tech Talk 6 April 27th, 2016 09:44 PM
High Idle at 4500rpm after cleaning carbs NinjaBob 1986 - 2007 Ninja 250R Tech Talk 5 June 14th, 2013 09:38 PM
First Carb Cleaning Achilles 2008 - 2012 Ninja 250R Tech Talk 33 February 1st, 2013 11:48 PM
Carb Cleaning?? jboyd12 General Motorcycling Discussion 11 March 3rd, 2012 10:05 AM
08 dies on idle now, is the carb cleaning covered in warranty? novak2k9 2008 - 2012 Ninja 250R Tech Talk 7 September 6th, 2009 08:33 PM
