Old July 3rd, 2015, 11:50 AM   #1
fatspiderman
Motorcycle(s): 2011 250r
Stock exhaust. Shifting time questions.
Hey guys,
I recently bought my first 250r last year. The previous owner put on a HMF exhaust slipon on it and I've only been riding with it on. It sounds nice but my neighbors have decided enough is enough so I need to put my stock one back on.
The issue is that my tachometer recently stopped working. It's not a big deal since I can shift by sound now but I'm sort of screwed when I put my stock back on.
Any tips on what I should do? Are there any speedometer guidelines I can try to follow?
fatspiderman is offline   Reply With Quote
Old July 3rd, 2015, 12:00 PM   #2
Hi Dan, the sounds of the rrrrrr's will not change that much by putting on the stock can. You should be able to continue to shift by feel after a ride or two. Just remember, when in doubt, upshift lol.
A 250 can nearly be shifted on the 10's on the speedo for a lazy sound respectful ride but trust your gut and all should be well.
Old July 3rd, 2015, 12:11 PM   #3
Originally Posted by fatspiderman View Post
...........I need to put my stock one back on.
The issue is that my tachometer recently stopped working..........
........I'm sort of screwed when I put my stock back on.
............Are there any speedometer guidelines I can try to follow?
Could you explain how are those four things related?
Old July 3rd, 2015, 12:20 PM   #4
Brother Michigan
Motorcycle(s): 2013 Ninja 300
Lots of bikes don't even come with tachs, so you should be fine just shifting when you feel like it. Bumping into the rev limiter won't hurt anything and I can't imagine anyone actually rides 250s around at low enough RPMs to lug the engine unless they're just totally not paying attention.
Old July 3rd, 2015, 12:36 PM   #5
InvisiBill
InvisiBill's Avatar
I generally say to fix the root problem rather than adjusting bandaids.
The tach signal is a black wire forking off between the igniter and coil. The gauge itself is powered by the brown wire and uses the black/yellow common ground wire.
Depending on exactly what's wrong with it, it might not be too hard to fix the tach and make this all irrelevant. Even if you don't specifically need it to shift, I still think it's very handy to know your RPMs.
Old July 3rd, 2015, 01:50 PM   #6
fatspiderman
I agree with you. I've got all the fairings off right now trying to figure out if it's a wiring issue or not. I mean, everything else works fine, even the light behind the tach. I even checked to see if the needle was stuck or anything but no go. Any ideas?
Old July 3rd, 2015, 01:52 PM   #7
Had your front sprocket cover off recently? If so, check to ensure the wires are not pinched.
Old July 3rd, 2015, 01:57 PM   #8
fatspiderman
I followed the service manual instructions.
16-57 disconnect BK lead. reinstall Bk screw. Turn engine on and connect the bk lead to screw to see if the pointer flicks.
It did not and recommends replacing the tach unit. But I don't see how this rules out that a wire is pinched somewhere down the line.
Actually, I don't see how this test does anything really. I'm sure I'm missing something here though....
Old July 3rd, 2015, 02:08 PM   #9
cadd
cadd cadd cadd
cadd's Avatar
Motorcycle(s): 300
MOTM - May '15
Is your neighbor also your wife or mother? if not, why do you have to obey?
Riding it like I financed it.
Old July 3rd, 2015, 04:52 PM   #10
fatspiderman
LOL no but I do like to go full throttle and have noticed it's excessively loud even with my helmet. I mean I set off car alarms if I'm amy where near 12k.
Old July 3rd, 2015, 10:43 PM   #11
cadd
cadd cadd cadd
cadd's Avatar
Motorcycle(s): 300
MOTM - May '15
I mean, if you like the aftermarket exhaust and want to keep that...I think you should keep it! Just keep the revs below 4k when riding in the neighborhood. That's what I do! At 6:45am when I leave the house, I duck walk the bike from the garage to the sidewalk, off the curb and onto the street. I make sure I'm fully geared up and ready to roll before I start her up. Once I start her up, I immediately (within 2 seconds) leave and make sure I'm not going more than 3k RPM at any point until I leave the neighborhood.
This way the bike gets warmed up while at really low rpms and I don't piss anyone off
Old July 3rd, 2015, 11:31 PM   #12
Ghostt
Ghostt's Avatar
I agree with @cadd you can be neighborly, and keep your aftermarket exhaust, if you so wish.
But you need to fix that tachometer issue for sure as @InvisiBill has pointed out.
violente et ignorantia
ZX-2R BLOG
what am i missing, 95 250R exhaust header bolt up questions (stock) macantley 1986 - 2007 Ninja 250R Tech Talk 13 May 19th, 2014 01:08 AM
stock exhaust questions gantt 2008 - 2012 Ninja 250R Tech Talk 10 August 26th, 2013 12:02 PM
Shifting Questions from a Nub. ranma3030 Riding Skills 13 April 9th, 2012 08:25 PM
Shifting Questions Pudge Ate Me 2008 - 2012 Ninja 250R Tech Talk 15 April 4th, 2012 04:51 AM
WTB: Stock rear links and stock exhaust for 2008 bluninja08 Items Wanted 1 July 14th, 2011 10:21 AM
