Old September 8th, 2016, 11:49 AM   #1
steezertotter
Motorcycle(s): 2004 EX250-F
Question Engine seemed seized
I'm working on a 2004 250 and when I went to start it this morning, as I hit the starter motor there was a loud clunk and it wouldn't turn. It sounded like it was getting a half rotation then hitting some resistance and stopping. I tried it in neutral, first gear, clutch in, clutch out. Nothing. I got on the bike and took it off the center stand and it started right up. I checked the oil it's got plenty and it was changed last week. An clue what could have caused this?
Thanks
steezertotter is offline   Reply With Quote
Old September 8th, 2016, 12:31 PM   #2
Thanks
Not following - does it start up fine off the stand?
Old September 8th, 2016, 12:38 PM   #3
RacinNinja
Vintage Screwball
RacinNinja's Avatar
MOTM - Mar '16
I don't suppose you've pulled the seat and checked the battery? If it's an aftermarket or taller than stock, sitting on the seat may have pressed on a terminal, fixing a crappy connection?
Otherwise, there is nothing else I can think of involving a centerstand and a no-start scenario.
Goin' fast on slow bikes!
Old September 8th, 2016, 01:07 PM   #4
steezertotter
It starts off the center stand.
I could hear the motor pushing even when it was not moving but I'll check for an electrical issue.
The problem now seems like it resolved it self because it will start now I'm any position but I'm waiting to see if it's recurring
Old September 8th, 2016, 01:39 PM   #5
I would suspect battery more than anything else. Sounds like you have a cell shorting out. On the stand the acid is at a level, off the stand it's at another level.
Old September 8th, 2016, 01:46 PM   #6
You hope it recurs, because otherwise it's lulling you into a false sense of security until your next really long ride when you're 200 miles from home at the bottom of a hill, and it's about to start raining.
Old September 8th, 2016, 02:58 PM   #7
JohnnyBravo
Certifiable nontundrum
JohnnyBravo's Avatar
MOTM - Sep '13, Sep '16
It's best to figure out the problem and fix it tbh
Old September 8th, 2016, 05:10 PM   #8
.........An clue what could have caused this?
Thanks
Hopefully, it is not the reason in your case, but check this thread out:
http://www.ninjette.org/forums/showt...starter+clutch
Old September 8th, 2016, 11:27 PM   #9
Ghostt
Ghostt's Avatar
It could be hydrolocked.
Thus happens when the carburetor float valve sticks, and/or petcock malfunction, this allows fuel to fill the cylinder.
Remove the spark plugs and crank the engine, if it is hydrolocked, fuel will shoot out the spark plug hole.
To fix this verify the petcock is operating properly, and check the float needle valves for wear, if in doubt replace, and adjustment of the floats,
If no inline fuel filter is present, install one.
violente et ignorantia
ZX-2R BLOG
Old September 9th, 2016, 08:10 AM   #10
I was thinking possible hydrolock as well, or maybe a battery that is on the edge.
Has the oil level risen at any time?
I would get a volt meter and check the battery voltage. You should get 12.7V (100% charged) before cranking. Also test it when you hit the button - you should still be in the 10V range. If it drops off more than that the battery is bad.
Also check all of the connections if the battery checks out fine.
[visordown.com] - Helmets that increase chance of death seized Ninjette Newsbot Motorcycling News 0 May 20th, 2014 02:10 AM
Engine Seized Ish 1986 - 2007 Ninja 250R Tech Talk 59 January 16th, 2014 07:34 PM
[visordown.com] - Sean Emmetts phone and laptop seized Ninjette Newsbot Motorcycling News 0 January 7th, 2014 09:50 AM
Seized engine Hawaiininja 1986 - 2007 Ninja 250R Tech Talk 28 December 7th, 2012 05:57 PM
[topix.net] - This supermodel seized a million hearts Ninjette Newsbot Motorcycling News 0 May 11th, 2010 09:10 AM
