Go Back   ninjette.org > General > Off-Topic
Old June 17th, 2013, 03:02 PM   #1
az3200
az3200's Avatar
Motorcycle(s): 2002 Ninja 250
Help Restoring Windows 7
Hey all, my computer crashed :/ I'm having a lot of trouble trying to reinstal windows, either from the recovery partition on the HDD, and from the recovery disk. It's a 2 year old acer laptop. Once I get to the Acer recovery managment tool when the computer starts up (it never actually starts up, just gets to this screen and nothing ever happens) This is the screen it freezes at:
This happens whether i try doing it from the recovery parition, or the recovery cd
What happened: Was using it the other day, and when I was finished I put it to sleep mode. When I went back to use it, it started up and said "loading windows" Except it said this for about 10 minutes. I held the power button down to shut it off, and on start up it said it wanted to perform a check of the C: drive.. so I checked that option. When it was supposedly checking the HDD for errors, it wasn't doing anything.. so after 20 minutes I shut it off again and this time tried to start windows without running the check. It displayed the "loading windows" screen for about 30 minutes. I tried going back an forth between the two options with no luck to load the desktop. I finally decided it was time to reinstall the operating system anyway because the computer was bogged down with junk..and now I'm stuck at this point.
Please help!
az3200 is offline   Reply With Quote
Old June 17th, 2013, 04:21 PM   #2
Aurodox
Motorcycle(s): -
Your best bet would probably be to just straight up reinstall windows 7 by formatting your C:\ drive and starting new. There are tutorials on the internet. The only downside to this would be the fact that you'd lose all your documents, pictures, etc....Hopefully you kept those on an external or something. If you really want to fix your computer but don't want to lose your files, there are companies that specialize in this type of thing. Sadly, that's where my tech knowledge stops.
Aurodox is offline   Reply With Quote
Old June 17th, 2013, 04:22 PM   #3
CynicalC
CynicalC's Avatar
Motorcycle(s): '96 EX250
Sounds like a botched windows update. Does it start in safe mode? You should be able to recover from there.
Ç¥ñ頻| ßÿ Ñâ7µ®é. Äñt¡~§º¢Ïä| ßý Çhøî©è.
Old June 17th, 2013, 04:24 PM   #4
CynicalC
CynicalC's Avatar
Old June 17th, 2013, 04:27 PM   #5
Aurodox
Motorcycle(s): -
Originally Posted by CynicalC View Post
Hahahaha no! Everyone knows GS does nothing but take your money. I was talking about a data recovery company, since reformatting would probably be his best bet. It'd be my first move anyways....
Old June 17th, 2013, 08:19 PM   #6
az3200
az3200's Avatar
Thanks guys.. No way of getting into safe mode, but I think I've found the problem: bad Hdd
Found an old Linux disk that I decided to try (Ubuntu 9.1) that loaded! Only thing is, it's telling me I have many bad sectors on the Hdd. Anyway to fix that or is it just time to replace the Hdd?
Oh, and if anyone knows anything about Ubuntu, how in the **** do you get online with it? Tried googling it on my phone but to me it's all a foreign language...
Old June 17th, 2013, 08:49 PM   #7
Aurodox
Motorcycle(s): -
Ubuntu, you probably just need to install your ethernet driver with the ubuntu version of the driver. Find out which ethernet driver came with the computer.
As for your HDD, I'm not too sure how to fix bad sectors (don't even know what that means honestly), but they are pretty cheap these days. If this is a desktop, I'd recommend a WD blue. I've my blue for 5 years and its still going strong!
Old June 18th, 2013, 06:26 AM   #8
az3200
az3200's Avatar
But...how do I install the driver if I can't get on the Internet? I watched something on YouTube from my phone, but the drivers weren't there on the Ubuntu desktop. This is my first time ever trying Ubuntu. There is a computer repair shop right down the street from me. Gonna ride the ninjette there today and see if they can help.
Thanks so much!!
Old June 18th, 2013, 06:42 AM   #9
You don't really fix bad sectors. When running a surface scan tool, the sectors are just marked bad/unusable and that space is lost. Some bad sectors are normal, a lot of bad sectors is a sign to buy a new HDD.
Got a mem stick? You made this post so that means you have access to the webs. Download the driver to mem stick, mount in ubuntu, install, WIN!
Old June 18th, 2013, 11:43 AM   #10
az3200
az3200's Avatar
hey guys...posting this FROM MY LAPTOP!!! I went to the computer repair shop and the tech turned me on to this OS called "Puppy Linux" I went to the library, downloaded it, and I'm running the OS off the disk...and connected to the internet )))
thanks for the help!
[American Motorcyclist Association] - Interview: Restoring the 2015 Hall of Fame raff Ninjette Newsbot Motorcycling News 0 January 22nd, 2015 01:50 PM
Restoring the colors (Sun damaged) NaMeTaKeN33 1986 - 2007 Ninja 250R Farkles 6 August 1st, 2013 08:14 PM
Windows 8 Boom King Off-Topic 8 November 8th, 2012 09:15 PM
[crash.net - MotoGP] - Crutchlow eyes progress after ‘restoring confidence' Ninjette Newsbot Motorcycling News 0 September 14th, 2011 02:10 AM
[webbikeworld.com] - Restoring Motorcycle Transmisisons by Roy Bacon Book Review Ninjette Newsbot Motorcycling News 0 October 21st, 2008 01:39 PM
