June 21st, 2013, 02:00 PM | #1 |
Join Date: May 2013 Motorcycle(s): 2005 Ninja 250 Posts: 35
Mid-throttle vibration?!
Bike is a stock 2005 250r with 1400 miles. I'm the second owner, never dropped.
Bike has a vibration / rattle when at mid to mid-high throttle. Only when riding, never when in neutral. I can't tell from where exactly, but sounds more forward of the bike than rear. Any known areas or things that might need checked? All fairings are secure and properly tightened, sounds almost like its from the gas tank but I can't find any cause. Thanks! |
June 21st, 2013, 02:06 PM | #2 |
sail away
Join Date: Jul 2012 Motorcycle(s): gixxer (sold), ninjette (upgrade!) Posts: 964
Check if all motor mount bolts are tight?
Unregistered found this post helpful. Track Day Preparation Checklist 1. Financial 2. Mental 3. Physical 4. Gear / Bike |
June 21st, 2013, 02:15 PM | #3 |
That is the problem, Steven
The bike needs accruing much more miles quickly !!! May it be this? http://faq.ninja250.org/wiki/Lubing_...edometer_cable
June 21st, 2013, 02:24 PM | #4 | |
sail away
hmm motor mounts seem unlikely now... lol
June 21st, 2013, 02:28 PM | #5 |
It could be anything, but it seems to me that problems associated to long storage, rusted or frozen parts are more likely.
My first idea was the chain, but OP refers to front portion. A way to fine-tune the source would be going down a hill with engine off.
June 21st, 2013, 03:37 PM | #7 |
Join Date: May 2013 Motorcycle(s): '92 GPX 250 (Gone and replaced with '08 V-Strom), 2005 Suzuki C50. Posts: 186
The radiator screen can rattle on these bikes, as can the screen in the lower cowling.
June 21st, 2013, 04:11 PM | #8 | |
Join Date: Oct 2012 Motorcycle(s): 2002 Ninja 250 Posts: 213
Is it a rattle or vibration? maybe the clutch lever? |
June 21st, 2013, 08:15 PM | #9 |
The noise is both during acceleration as mentioned and decel, but only at roughly 5k. It sounds "tinny" like thin metal almost. I've run my hand over parts at speed when I hear it to see if I can make it stop and locate it. I also had it up on the center jack with a block on the front wheel and ran it with clutch engaged to 5k and nothing.
The bike is mint, not that I'd say I bought a bad bike. But this thing was garage kept, tank and carbs drained every winter. The only rust is where the levers pivot, everything else is perfect. I did have it apart to check my carbs a few weeks ago, maybe a wire was left out of place and now vibrates on something? Sorry for the delayed response, I was taking my safety course, passed tonight! |
June 22nd, 2013, 05:33 AM | #10 |
Congratulations !!!
June 22nd, 2013, 05:34 AM | #11 |
It protects the fins from being bent by flying rocks.
June 23rd, 2013, 10:04 AM | #12 |
Clutch lever buzzing? It's common.
June 23rd, 2013, 10:33 AM | #13 | |
Long Time Rider
June 25th, 2013, 05:45 AM | #14 | |
I've been trying to determine if it is, I was able to get the throttle up high enough to trigger the vibration, and took my finger and held the clutch lever stead and the noise continued, so I don't think its the lever although I'm not ruling it out.
So what about chain noises? I noticed my chain looks a little lose, haven't had a chance to check it with a ruler but it has some drop to it. If I hit the throttle harder I feel a lurch forward when the slack is taken up out of the chain, I still think I'm at a normal amount, but even so the vibration I get is both on and off throttle. Any input on this? |
June 25th, 2013, 06:01 AM | #15 |
You sure it's rpm related?
You should be able to get to redline in a parking lot via 1st gear or on a stand. If you can't maybe it's in the drive train and comes/goes as the speed changes. Maybe have a look at; Tire pressure - check it every ride Chain - clean/lubed, check master link while your there and slack should roughly be about 1.5 inches Front/Rear sprocket - torqued and not worn Wheel axles - torqued Wheel bearings - put it up on stands and check for any side to side movement and smooth rolling, grease them if needed Wheel weights/Tire balance - check Rear wheel alignment - may have to really spend some time and do the string method Rotors - straight, check for glazing while your there Brake pads and calipers - not dragging against rotors and bolts torqued to spec, check pads while your there Front fork alignment - search for alignment thread in the tech section, it's stickied I think Stem nut - Torqued to spec Also, you can't really trust the direction of sound when it comes to isolating a vibration. I always start with the bike on stands and turn the wheels slowly by hand and listening. Hopefully your vibration is on the list above and is an easy fix.
June 25th, 2013, 06:07 AM | #16 |
Also, if it is the chain, there should be a pattern to the vibration. If you strongly suspect the chain, spray it with WD40 and go for a short ride to see if the problem goes away. WD40 is a temp fix only but will help diagnose the problem. You can try to soak the chain in gear oil for a day to get a bit more life out of it but maybe it's time for a new chain.
June 25th, 2013, 08:38 AM | #17 | ||
June 25th, 2013, 08:52 AM | #18 |
Sure, it's possible. If it was damaged, improper manufacture or not cared for adequately.
Vibration while idling. | sailorninja | 1986 - 2007 Ninja 250R Tech Talk | 17 | October 9th, 2014 12:04 PM |
Vibration Around 8k RPM | spacemonkey | 2008 - 2012 Ninja 250R Tech Talk | 10 | August 31st, 2014 07:17 PM |
Vibration | singlecoillover | 2008 - 2012 Ninja 250R Tech Talk | 11 | March 3rd, 2011 11:48 AM |
Please help me!!!! - vibration | MikeCG23 | 2008 - 2012 Ninja 250R Tech Talk | 6 | August 27th, 2010 03:51 AM |
Vibration!!!!!! | Gyrene | 1986 - 2007 Ninja 250R Tech Talk | 7 | June 2nd, 2010 10:55 AM |
