Old February 15th, 2012, 03:23 PM   #1
MikeBudd
MikeBudd's Avatar
Motorcycle(s): RED 2010 Ninja 250r
Airbox removal + Kleen air removal?
Hey Everyone,
SO I removed the airbox and got my single K&N air filter installed along with my crankcase vent filter.
Now, I am left over with a number of hoses that go nowhere! Am I supposed to be removing the Kleen air system as well? If so, I guess I will have to buy a plug and some more piping
There is also a hose that connects right on top of the carbs that goes nowhere... (right next to the butterfly valve adjuster) That's not part of the kleen air system, so where does it go?!?
Would love to be helped out so I can get her running again
MikeBudd is offline   Reply With Quote
Old February 15th, 2012, 04:38 PM   #2
indr
This one? http://www.ninjette.org/forums/showthread.php?t=61110
indr is offline   Reply With Quote
Old February 15th, 2012, 06:08 PM   #3
MikeBudd
MikeBudd's Avatar
Well that solves that problem! Thanks!
Now do I remove the kleen air system to get rid of the extra hoses that went to the airbox? I can't find a thread on both the airbox and those hoses
Old February 15th, 2012, 06:43 PM   #4
indr
You should remove the kleen air system or atleast plug/pinch it. I believe it has negative suction (suck), so things might get in there. There are block off plates you can install, http://www.slingshotracing.net/catal...ate-p-204.html
There is also a Uni breather filter you can install. But that is no good in the Vancouver rain.
Also, if you decide to order the block off plate, please PM me if you don't mind ordering two and splitting the shipping cost to Canada (I'm in Surrey).
Here's the DIY thread: http://www.ninjette.org/forums/showthread.php?t=9948
Old February 16th, 2012, 04:48 PM   #5
MikeBudd
MikeBudd's Avatar
Thanks for the help!
I actually ended up removing and plugging it up before you even got back to replying!
I'm actually interested in those block off plates because they seem more "reliable" than a simple plug made of rubber.
I'll pm you about it.
Old February 16th, 2012, 04:52 PM   #6
I'm sure those plugs are just fine in the reliability department. The block-off plates just look better.
Old February 16th, 2012, 04:57 PM   #7
MikeBudd
MikeBudd's Avatar
Probably true.
IMHO it removes a failure point, which is always a good thing, but in reality, it probably is more something I would do for peace of mind and just to have a cleaner install.
KLEEN & CA emission removal? erbarry88 2008 - 2012 Ninja 250R Tech Talk 5 June 11th, 2014 11:39 PM
Post airbox removal questions htsang07 2008 - 2012 Ninja 250R Tech Talk 16 May 23rd, 2013 06:33 AM
Airbox removal and jetting + other questions kamikaze 2008 - 2012 Ninja 250R Tech Talk 3 February 18th, 2012 08:04 PM
OEM Front Seat (no cover), pieces of OEM Seat Material, and Kleen Air Removal Kit nattygirl Motorcycle-related 17 June 8th, 2011 09:48 PM
Kleen air system removal on CA model ninja drumm3r9 2008 - 2012 Ninja 250R Tech Talk 2 August 10th, 2010 08:36 AM
