Old October 18th, 2014, 07:18 PM   #41
xorbe
xorbe's Avatar
Originally Posted by Linkin View Post
I ordered stock gearing JT sprockets, but found that the rear sprocket was larger, with the same number of teeth - this apparently gives better acceleration? It would explain why I couldn't get the bike above 145KM/h (90MP/h) in top gear.
I don't race or do a lot of highway travel so it seems to work fine
That sounds very wrong ... you are probably wearing the chain out much faster with the wrong link pitch sprocket.
Old October 18th, 2014, 09:59 PM   #42
Ghostt
Ghostt's Avatar
+1/-2 for me I like this combo due to the speeds that go through the twisties I'm right in the power band.
violente et ignorantia
ZX-2R BLOG
Old October 20th, 2014, 09:23 PM   #43
Linkin
Down Under
Linkin's Avatar
Motorcycle(s): Kawasaki ZXR250C Ninja
It's a brand new chain as well.
Please explain how a larger sprocket could wear out a chain.
Linkin is offline   Reply With Quote
Old October 20th, 2014, 09:33 PM   #44
It sounds wrong because a larger sprocket with 45 teeth (same as stock) would have a different pitch between the teeth. Therefor, improperly sized against a stock pitched chain. This is why the number of teeth increase when the physical diameter of the sprocket is larger, vice versa for smaller sprockets.
Bottom line, you're gunna wear out the chain, sprocket or both. Also, it will cause premature wear on your front sprocket as well. Any chance it has more teeth than 45 and you mistyped what you meant? It's easy to check, JT sprockets stamps the number of teeth right on the sprocket. Look for a 40 something number etched into the metal.
Old October 20th, 2014, 09:37 PM   #45
Oh, just wanted to let you know the standard pitch for a 250 chain is 520. Did you change yours? Some riders do this as a weight savings mod. If you changed your pitch to non-stock, this could explain why we are alerting you of a possible issue. Because we are assuming stock sizing.
Old October 20th, 2014, 09:46 PM   #46
NevadaWolf
Certified looney toon
NevadaWolf's Avatar
MOTM Jul '13, Jul '14
Let's see, went up one in the front to a 15T and been cruising on it for several months now. Love that I keep "forgetting" to go up into 6th as 5th feels like normal.
Just ordered a 42T to try for my long rides to eek out a bit more mileage. If it comes in tomorrow, will have it installed with my new tires and tested this weekend.
Ordered JT steel sprockets from the dealer first, and now through Amazon.
<-- Linky
Old October 24th, 2014, 10:35 AM   #47
subxero
dirty boy
subxero's Avatar
MOTM - Apr '14
would say favorite sprocket mod but I was in need of new chain so figured I'd do sprockets to keep everthing wearing together.
I ordered a fancy rear sprocket with stock 45t. They said it would take a week to make it but they did have 43t in stock. 2 weeks later I said I'm tired of waiting give me the damn 43t
Today was the first day I really got to feel it out. Not sure if I like it better or not yet? I can tell a difference even with just a few teeth down in the rear mainly with my shifting.
I'm not getting out of 5th as much as I can wring it out just that little bit more. Will see how it continues to play out. I'm stuck with this setup for a while. I paid too much to go back
Last futzed with by subxero; November 12th, 2014 at 06:20 AM.
Old October 24th, 2014, 10:44 AM   #48
Ghostt
Ghostt's Avatar
Exclamation 2¢ on gears
One must keep in mind that gear it down, decreasing the final gear ratio, that small displacement engines love and need to rev to work effectively, so if you go too far, be ready for that.
I know that when I had my FJ1100 GOING to +1/-2 was no big deal, and I could hardly feel the performance difference, but on the 250 I can feel it for sure.
ZX-2R BLOG
Old October 27th, 2014, 03:15 AM   #49
ninja250r81
ninja250r81's Avatar
Motorcycle(s): 2012 ninja 250r se
aussie std 14/43 (3.07)
changed to 15/43 (2.87) over a year ago and not going back.
Thinking of changing to 15/40 (2.67) setup
This might help
http://www.jtsprockets.com/fileadmin...tgearratio.pdf
http://www.jtsprockets.com/catalogue/model/924
ninja250r81 is offline   Reply With Quote
Old October 27th, 2014, 05:42 AM   #50
Ghostt
Ghostt's Avatar
http://www.gearingcommander.com
ZX-2R BLOG
Old October 27th, 2014, 08:57 AM   #51
xorbe
xorbe's Avatar
Originally Posted by Ghostt View Post
GPS your bike first, as my bike didn't quite match up with the final mph (kph) as suggested by the N I N J A data. You can fudge the data into alignment with the Final Drive Ratio field. Then it should be accurate when playing with the sprocket tooth count.
Old October 27th, 2014, 09:04 AM   #52
Ghostt
Ghostt's Avatar
HELL it's simple math, rear sprocket divide by front sprocket= final ratio
43/15=2.86 see isn't that much easier.
ZX-2R BLOG
Old October 27th, 2014, 10:17 AM   #53
xorbe
xorbe's Avatar
Right, but that's not the intention ... Go gps your bike, and then use the form, and see if they match up ... mine was off by 10% ... so I altered the final ratio as a quick way to play with the sprocket numbers accurately. Maybe the 2008+ data is more accurate than the -2007 data.
Old November 2nd, 2014, 04:54 PM   #54
AyeCapn
AyeCapn's Avatar
Motorcycle(s): 2008 Ninja 250
I have stock at the moment, but hope to get my 15T front sprocket on before the season ends here. First bike, and I've only had it for a month, but I think by now I'll be able to tell if it makes a difference.
Not having to shift when making a left turn would be kind of awesome.
"It's more fun to ride a slow bike fast, than to ride a fast bike slow" -Road test guy
AyeCapn is offline   Reply With Quote
Old November 5th, 2014, 05:47 AM   #55
wardie
Motorcycle(s): 06 KLR 650,12 250 Ninja, 86 DR 125, 07 CRF 100, 09 Tomos Streetmate LEL Record Holder, 88 K100 RT
Gearing
When I bought the bike I switched from 14/45 to 15/41 because I did more highway traveling than anything else and wanted gas mileage and lower revs at 70 mph. The 15/41 is fine accelerates well but I find I cannot max out RPM in 6th gear GPS'd at 93 mph. Think the 15/43 might have been best all arounder gearing.
wardie
wardie is offline   Reply With Quote
Old November 5th, 2014, 08:37 AM   #56
Ghostt
Ghostt's Avatar
Topic Review (Newest First)
Today 06:47 AM
wardie
Gearing
November 2nd, 2014 05:54 PM
A clear cut example/case of what I was talking about.
ZX-2R BLOG
Old November 5th, 2014, 09:25 AM   #57
xorbe
xorbe's Avatar
A stock bike can't max out 6th (125 mph lol) with regular sprockets either, or 5th @ 111 mph. 93 gps'd is not too far off. My older pregen is 91 mph 4th with 15/42, no lead vehicle cutting the wind.
Old November 11th, 2014, 09:28 PM   #58
ascencionalberto
Motorcycle(s): 09 ninja 250r 09 ninja 250r stunt 2011 ninja 250r
On my 09 stunt bike I'm using 13/52 that's was to get out as much torque as I can out of it to pop wheelies easier
ascencionalberto is offline   Reply With Quote
Old November 12th, 2014, 01:46 AM   #59
ninja250r81
What manufacturer makes the 13 tooth front sprocket??
Old November 12th, 2014, 03:23 AM   #60
Swann
Swann's Avatar
Motorcycle(s): 250R
SUNSTAR and XAM makes 13T front sprockets for the Ninja 250R.
Swann is offline   Reply With Quote
Old November 12th, 2014, 06:31 AM   #61
subxero
dirty boy
subxero's Avatar
MOTM - Apr '14
I've been riding the 14t/43t combo for a little bit now. I think I like it. I can definitely tell a difference more so in my shift points as I mentioned earlier, nothing on the butt dyno though. The other day on a long straight up hill on the highway the bike pulled to 93 indicated in 6th, (little bit of a tail wind). With the stock gearing I don't think it would have gone any faster.
43t in the back seems like a good option for people who want to drop the revs just a bit but keep the little bit of get up and go that the bike has.
Old November 12th, 2014, 03:40 PM   #62
ascencionalberto
I have jt sprockets but I got them for an 03-05 yamaha r6 with a 520 conversation everithing matches a ninja250
Old August 1st, 2015, 11:38 AM   #63
johnydecali
johnydecali's Avatar
Motorcycle(s): '12 Ninja 250r
I'm new to riding and all this gear ratio info, I see the numbers diff on gear commander's site... I see a lot of people saying that 15/42 is great, I was thinking of going 14/42. Would there be a noticeable difference by keeping the front sprocket stock?
I'm not imperfect. However my imperfections are what creates my value and makes me unique - johnydecali
johnydecali is offline   Reply With Quote
Old August 1st, 2015, 12:32 PM   #64
Hi John,
Will you notice? Sure but "how much" you notice is the debateable thing. Many riders think the 250 is buzzy at 65-75mph and the 15t front sprocket helps with that by lowering the rpms in that speed range. Ie... it's a calmer feeling ride overall.
You have to address yourself to gauge the value and impact on the bike's performance. I lump everything into 2 categories;
Will it help keep me safe - can I decel and accel in a manner that works with my riding
Will it improve performance - subjective to riding style and personal preferences
First off if you're a heavy rider, the 15/42 will suck at the top end. 85-90'ish mph will be your max speed. Will that work for you?
Do you mostly do alot of downtown city riding?
Do you mostly ride highway?
Do you mostly ride twisties for fun?
Do you want more acceleration vs. top end speed (it takes a long distance to see top end speeds on 250's).
I guess... the major question is "why are you considering modifying the gearing?" If you answer this, we can help you in a better way.
Old August 1st, 2015, 10:21 PM   #65
Yes - you'd be $30 poorer. Going up to 15 tooth in the front (and keeping the 45 in the back) will provide you exactly the same gearing as a 14/42. But a 15 tooth front is much cheaper than a 42 tooth rear.
Old August 2nd, 2015, 12:12 AM   #66
johnydecali
Thanks! Sadly it is time for me to replace my rear sprocket and chain, the teeth are starting to fish hook
Old August 2nd, 2015, 12:19 AM   #67
Ah! Got it. If you need to replace it anyway, makes sense to choose the gearing you'd prefer at that point. But if one sprocket is toast, the other one is relatively worn as well, right?
Old August 2nd, 2015, 09:03 AM   #68
^^^ should be. Same with the chain. Typically I replace them as a set on both motorcycle and bicycles.
Sprockets and chains wear together. Replace them together. Extent of condition.
Old August 4th, 2015, 01:06 AM   #69
johnydecali
Hi John,
Thanks for all the feedback everyone!
I was looking for more top end with minimized loss to acceleration...
Sadly everything has a price. I ride a bit of everything but use my bike as my daily commuter with 2/3 being highway and a third being city. Sometime on my way home I take the scenic route and run down HWY 1 through Stinson Beach to SF. Realized that I'll just need to make more money and have several bikes for all sorts of my moods...
Old August 4th, 2015, 06:22 AM   #70
Aren't we all.... aren't we all.
Old August 4th, 2015, 11:45 AM   #71
Ghostt
Ghostt's Avatar
Go with 15T up front, it's about the easiest way to go. These bike love/need to rev, if you gear it down too much, it will suffer, and you'll be unhappy with it.
I myself went 15/43 which was I think too much, next time I'll go back to 45 but keep the 15
15/43= 2.87 final ratio
15/45= 3.00 final ratio
14/45= 3.22 final ratio(OEM)
While this might not seem as much, to the Ninjette it is.
ZX-2R BLOG
Old August 5th, 2015, 11:54 PM   #72
johnydecali
oh.... hmmm I ordered the sprockets already, got overzealous, going 15/42.... I'll keep the links to the chain and order a 45t just in case...
Old August 6th, 2015, 01:05 AM   #73
Ghostt
Ghostt's Avatar
Hey it's all good, try out the ones you order, you just might like it, worse case scenario, you order the 45.
ZX-2R BLOG
JT Sprocket 42 tooth Rear Sprocket lolibater Motorcycle-related 36 February 25th, 2013 12:30 PM
To mod or not to mod, that is the question... RiderOnTheStorm General Motorcycling Discussion 19 October 29th, 2012 08:21 PM
[roadracingworld.com] - Send Us Your Favorite Road Atlanta Memory Or A Favorite Road Ninjette Newsbot Motorcycling News 0 April 11th, 2012 05:10 PM
what is your favorite mod to your bike!?! kawigirl General Motorcycling Discussion 40 September 5th, 2011 01:28 PM
