Old March 31st, 2011, 06:13 PM   #1
kashun84
kashun84's Avatar
Motorcycle(s): 2010 Lime Green 250R
Help on Clutch Cable
I was lubing the Clutch cable. I think I sliped my cable and I cannot pull it back. My fault, I should invest the cable puller..... Anyway, is there a way to fix this. My clutch cannot move at all........ Need some help on this, I really appreciate it.
Jason
kashun84 is offline   Reply With Quote
Old March 31st, 2011, 06:18 PM   #2
kashun84
kashun84's Avatar
I am looking at the manual, should I remove the clutch cover and redo the clutch release shaft??
Old March 31st, 2011, 06:50 PM   #3
http://www.ninjette.org/forums/showthread.php?t=50404
Old March 31st, 2011, 07:27 PM   #4
Uhh... that's chain lube.
I think you meant to link to your clutch cable lube DIY.
Old March 31st, 2011, 07:40 PM   #5
ooops, sorry, I was doing 2 things at once and copied the wrong link.
besides, after reading his thread again, it seems his clutch arm is not moving down by the engine end, is that right?
Old March 31st, 2011, 08:30 PM   #6
kashun84
kashun84's Avatar
Yea, I manage to get the cable housing into the adjusting knob finally and my clutch can be moved. However, I found my cable seems shorter than before. It's really hard to install the cable on the level end right now and I have less play compare to what I have before I remove them. I checked by starti the engine, pull the clutch all the way in, shift into 1st gear and the wheel will spin. It's like the clutch is still slipping and that's the max play I can gain by adjusting the cable play. Let me double check everything tomorrow. Maybe something get caught on the cable. Anyway, thanks for your help~~~
Old March 31st, 2011, 08:55 PM   #7
did you screw in the cable adjuster as far as it can go on the handlebar end?
Clutch cable Linkin 2008 - 2012 Ninja 250R Tech Talk 5 January 28th, 2015 03:29 AM
clutch cable james250ninja 1986 - 2007 Ninja 250R Tech Talk 2 July 27th, 2013 10:20 AM
Clutch Cable Scootch 2008 - 2012 Ninja 250R Tech Talk 18 March 8th, 2012 02:02 AM
Clutch Cable atomicrm 2008 - 2012 Ninja 250R Tech Talk 2 December 17th, 2011 12:22 PM
clutch cable slackerman 1986 - 2007 Ninja 250R Tech Talk 2 September 3rd, 2011 05:37 PM
